Replacing Fork Seal(s)...
Discussion in 'Motorbike Technical Discussion' started by NA, Apr 25, 2005.
  1. NA
    NA Guest
    One of my fork seals has blown, and it is leaking oil slightly.
    The last time this happened was 3 years ago with the *other* fork seal.
    At that time, I'd the dealer do the repair--costing over $160. The
    mechanic recommended that both seals be replaced so I OKed the work.
    Since the current leak is with the *opposite* seal, I'm suspicious now
    as to whether this seal was ever replaced back then--might just be a
    coincident but it does make me wonder...
    This time, I am going to replace the seal myself. Anyway, what is the
    best practice--replace the leaking one or both seals?
    Any input would be greatly appreciated.
    NA, Apr 25, 2005
  2. Both fork tubes go up and down at the same time don't they? Wear on the
    seals' lips will be about the same and the one you don't replace will
    probably start leaking sooner than later...
    Since you have to hoist the front end of the bike off the ground and
    remove the front wheel, why do that work twice? Replace both seals at
    the same time...
    krusty kritter, Apr 25, 2005
  3. NA
    NA Guest
    Thanks for your inputs! These were the same rationale that the mechanic
    made three years ago for doing both seals at the same time. I already
    have two seals on hold for me so I'll be replacing both tomorrow.
    Thanks again!
    NA, Apr 25, 2005
  4. there is a bushing in top of the lower fork tube. right below the
    seal. replace it also same time as seal. you'll be glad you did.
    Motorpsycho Jim
    Motorpsycho Jim, Apr 26, 2005
  5. What he said.
    The Older Gentleman, Apr 26, 2005
  6. NA
    NA Guest
    Thanks for useful advice guys!
    Actually, there are two sets of bushings: outer tube guide bushing
    located at top of outer/lower tube, and inner tube guide bushing located
    at bottom of inner/upper tube. Should I replace both sets too, or just
    the pair of outer tube bushings?
    Thanks again!
    NA, Apr 26, 2005
  7. Troo.
    'Snot a bad idea if the forks are a bit ancient, though.
    The Older Gentleman, Apr 27, 2005
