replacing carby intake manifolds
Discussion in 'Australian Motorcycles' started by Damien, Aug 19, 2006.
  1. Damien
    Damien Guest
    I was just wondering if anyone has any tips/tricks for getting the
    carbies back on after replacing the manifolds? The replacement
    procedure itself was pretty easy, but getting the blasted things to
    seat properly has been anything but! I can't really see any reason for
    them to be so fiddly, so if anyone has any advice that could help
    avoid too much wasted time working it out, it would be greatly
    appreciated.
    Damien
    GPX250 -> CBR600 -> F650/R1200GS (when the $$$ are there!)
  2. Damien
    James Guest
    Remove the Manifolds and soak them in Armourall. Softens em up well.
    James, Aug 19, 2006
  3. Damien
    Boxer Guest
    Silicone spray.
    Boxer, Aug 19, 2006
  4. Damien
    J5 Guest
    they are likley to be very hard with age , try silicone as suggested below ,
    you could combine this with a soak in hot water as well
    i went through this with a ZZR250 last week
    my method was the manifolds on the carbs 1st then the airbox on the carbs
    and then the carbs on the head
    your methods may vary :)
    fucking big screwdriver also helps ;)
    J5, Aug 19, 2006
  5. Damien
    Damien Guest
    The manifolds are actually new, which is why I had the carbies off,
    but I will try the silicone spray and see how that goes. Thanks guys.
    Damien
    Damien, Aug 20, 2006
  6. Damien
    Directing a hair dryer or fan-blower type heater on the rubber boots
    keeps them soft while you're getting them all attached to their proper
    carbies, but they're always pricks of things to line up.
    Much easier on a GPX250 than a CBR600 of course, only half as many of
    them! ;-)
    BT Humble, Aug 20, 2006
