repairing a motorcycle seat
Discussion in 'Motorbike Technical Discussion' started by Matt, Aug 12, 2005.
  1. Matt
    Matt Guest
    The seat of my 1976 motorcycle has a tear that I would like to patch. I
    am thinking that if there is such a thing as black vinyl with adhesive
    backing, it would be a good way to fix it. Does anybody have experience
    with such a repair? Where would I find that material?
    Matt, Aug 12, 2005
  2. Matt
    Cees Keyer Guest
    In the Netherlands we go to a shop wich does car seats etc.
    Maybe taht is a better choice to go to such a place in youre vicinity.
    Cees Keyer, Aug 12, 2005
  3. A patch secured with any rubber adhesive will just move around when the
    sun heats the vinyl up. You might have people snickering behind your
    back and pointing to the patch that's stuck to your butt...
    Maybe you could find a piece of black vinyl in an upholstery shop and
    superglue it to the seat. I don't remember exactly where I got the
    rolls of
    naugahyde I used to recover my seats, it may have been from a fabric
    and foam supplier in Burbank...
    Does the CJ360 have the same seat as the CB360T?
    www.denniskirk.com has an aftermarket seat cover for a CB360T P/N
    61-801 for $57.00...
    krusty kritter, Aug 12, 2005
  4. Matt
    Sunny Guest
    You might can find vinyl at a hobby or sewing center. Use contact cement
    (like that used by shoe repair shops) and follow the directions. I would
    let it dry at least 48 hours though.
    Or if you want to go the extra mile, buy more vinyl and a sewing awl.
    Remove the seat cover and take it apart. Use the old seat cover as a
    template for a new cover and stitch the new pieces together with the awl, or
    if you have a heavy duty sewing machine, that will save time. While you're
    at it, you might want to add some extra padding to the seat. If you get
    proficient at this, you can start your own business. ;)
    Sunny, RCOS #7, ISRA #7123, EOB #000000000001
    '02 XVS650A "Deerslayer"
    http://www.pkriders.org/nartpartypics.htm
    "God does not deduct from one's allotted hours, the time spent on a
    motorcycle."
    Sunny, Aug 12, 2005
  5. Matt
    Matt Guest
    Thanks. The way to think of the CJ is that it is a cheapened version of
    the CB and that they made a lot fewer of them. It has a simpler seat
    that was cheaper in '76 but that is harder to find now ...
    I think you are using the DK hardcopy catalog---I can't find that seat
    cover online, although I found it right away in my hard copy.
    Matt, Aug 12, 2005
  6. Matt
    Matt Guest
    I found the ebay ID seatsandcovers. Is that him? Here is one of his
    auctions:
    http://cgi.ebay.com/ebaymotors/Hond...iewItemQQcategoryZ6755QQitemZ4567528021QQrdZ1
    Matt, Aug 12, 2005
  7. Im in Canada and I just tagged along with my wife to the local
    Fabricland one day and in the back they had rolls of 54" "skidoo" vinyl
    regular price $25 canadian for a meter, I got it on sale for $8 a meter.
    It doesn't have any type of adhesive, but Im going to make cover for my
    project bike and just pop rivet it to the existing leather which is fine
    around the edges.
    jellybean saint, Aug 12, 2005
  8. Matt
    Polarhound Guest
    I bring my seats to the little Korean guy that runs the leather/shoe
    repair shop down the street from our store. He normally charges about
    $30 or so for a recovering.
    Polarhound, Aug 13, 2005
  9. Matt
    Bryan Guest
    Yep, took the old Yamaha seat to "Joe's Do-it-all". $45 for marine grade
    "sticky" vinyl. They did an excellent job, including new high density foam.
    Bryan
    Bryan, Aug 13, 2005
  10. Matt
    Matt Guest
    Matt, Aug 13, 2005
  11. Matt
    mike Guest
    Two things can/will happen. The patch will flex and fall off.
    The rest of the seat is rotten and some other part will tear.
    I just get some material from the fabric shop and wrap it around the
    whole thing. Attach it with a staple gun right into the plastic
    part of the seat bottom. Not perfect, but works great.
    mike
    Return address is VALID but some sites block emails
    with links. Delete this sig when replying.
    Wanted, PCMCIA SCSI Card for HP m820 CDRW.
    FS 500MHz Tek DSOscilloscope TDS540 Make Offer
    Wanted 12" LCD for Compaq Armada 7770MT.
    Bunch of stuff For Sale and Wanted at the link below.
    MAKE THE OBVIOUS CHANGES TO THE LINK
    ht<removethis>tp://www.geocities.com/SiliconValley/Monitor/4710/
    mike, Aug 14, 2005
  12. Matt
    Matt Guest
    Matt, Aug 14, 2005
