Repainting clocks
Discussion in 'Classic Motorbikes' started by M J Carley, Mar 18, 2008.
  1. M J Carley
    M J Carley Guest
    The CB550 rebuild continues. My question now is what to do with the
    clocks. Both could do with repainting and, anyway, David Silver has a
    tachometer but no speedometer. The speedometer has a dent so my plan
    is to fill the dent and repaint the black bits of both. Is there
    anything wrong with my plan and, if not, how should I go about it?
  2. M J Carley
    TOG@Toil Guest
    The CB550 has exactly the same size clocks as the CB750 - same units,
    in fact, except the graduations on the dials are different. There are
    people on Ebay who now sell replacement dial faces: self-adhesive
    stick-on units which (apparently) are very high quality. One of the
    classic rags recently ran a piece on refurbishing old Jap clocks,
    using them. Might have been the VJMC mag: I can't remember.
    Might be worth checking out, anyway. Get an old CB750 speedo, and
    convert it. And refurbish the tacho at the same time.
    The real problem with these clocks is opening the buggers up in the
    first place: that metal sealing ring is rolled on with a special tool,
    and is easily ruined by attempts to remove it, though I have seen some
    very nice repair jobs done.
    TOG@Toil, Mar 18, 2008
  3. M J Carley
    peter Guest
    I had a MPH (MPH/kph) dial made for the Tart by someone in London.
    Even put a Voxan logo on it like the original. I'm sure they could
    redial a CB750 clock to 550 working from the old dial. About 40 quid
    though IIRC.
    http://www.redial-uk.co.uk/custom.html
    peter, Mar 18, 2008
  4. M J Carley
    M J Carley Guest
    I was hoping to avoid opening the things. They work, although the red
    line is a bit faded. Of course, by the time I've done everything else,
    I might decide I want nice sparkly clocks and redo them.
  5. M J Carley
    TOG@Toil Guest
    Now that's a useful website and company to bookmark.
    I don't think £40 is a lot of money for a refurbed clock, actually.
    Sounds like a bargain to me.
    But are the 'before' and 'after' pix on the 'Our Services' section
    identical???
  6. M J Carley
    Hmm sweet, I shall be needing a new tacho dial for the RS when it's
    finished!
    Hog, Mar 18, 2008
  7. M J Carley
    peter Guest
    That was only for a new dial on a working speedo though.
    The after has an inner kph ring.
    PF
    peter, Mar 18, 2008
  8. M J Carley
    TOG@Toil Guest
    Ah! Spot the difference, eh?
