Removing the wheel off a Shaftie ?
Discussion in 'Australian Motorcycles' started by Jason Burton-Woods, Jan 16, 2005.
  1. Having never played with a shaft drive before, when the mate across the
    road came over asking for advice on how to remove the rear wheel of his
    Honda Deauville (NTV650 I think) I had to say I dont know how to help.
    Anyone else know if removing the wheel off something like this should be
    straightforward? I'm hoping its a case of loosening the axle and whipping
    it out one side, but how does the drive go back together? Easy to line up
    the cogs?
    Thanks in advance
    JasonBW - Wollongong
  2. Jason Burton-Woods
    Matt Palmer Guest
    Jason Burton-Woods is of the opinion:
    Don't know the Deauville in particular, but my GT750 was straight and
    simple. Remove the axle, slide the wheel away from the diff, and then the
    wheel just comes straight out. I don't even remember aligning the teeth on
    the wheel to put it back together, the wheel just fit straight back on and
    the axle went through. Drop the brake caliper back on, and awaaay we go!
    - Matt
    Matt Palmer, Jan 16, 2005
  3. In aus.motorcycles on Sun, 16 Jan 2005 19:01:49 +1100
    That;s how it works on Guzzis. The drive box is attached to the
    swingarm, and stays there while you pull the wheel off.
    To replace, you offer up the wheel and rotate and wiggle it till the
    cogs mesh and the wheel slips hard up against the bevel box.
    Zebee
    Zebee Johnstone, Jan 16, 2005
  4. Thanks Matt and Zebee, I'll let him know I'm armed with the knowledge (and
    dangerous)
    Thanks
    JasonBW
  5. Jason Burton-Woods
    SmeeR11S Guest
    even easier on the bmw
    loosen and remove all 4 wheel nuts
    remove the brake caliper and the wheel comes off
    SmeeR11S, Jan 16, 2005
  6. In aus.motorcycles on Sun, 16 Jan 2005 22:20:07 +1100
    But first you have to get the jack out from the boot right?
    Zebee
  7. On the K, you don't even have to touch the caliper. Just undo 4 wheel
    studs, and off she comes. :)
    Cheers
    PeterC [aka MildThing]
    '81 Suzuki GS450-s
    '87 BMW K100RT
    www.dmcsc.org.au
    Peter Cremasco, Jan 16, 2005
  8. Jason Burton-Woods
    SmeeR11S Guest
    Centre stand is a wonderful thing:p
  9. Jason Burton-Woods
    Conehead Guest
    So is the BMW's ability to balance on front wheel & centrestand when rear
    wheel is removed, and vice versa.
    Conehead, Jan 16, 2005
  10. Jason Burton-Woods
    david Guest
    ....snip...
    I've always wondered how to support the front of my K1200RS if I needed
    to remove the front wheel.
    Now I know.
    Ta
    David
    david, Jan 17, 2005
  11. Jason Burton-Woods
    Boxer Guest
    I have to jack up the rear wheel on my K100 and remove the rear guard to get
    the wheel off.
    Boxer
    Boxer, Jan 17, 2005
  12. Well, I did on my sidecar.
    Al
    Alan Pennykid, Jan 17, 2005
  13. Seems to work on R's but not K's in my experience.
    Al
  14. Don't you mean removing the Shaftie??
    Sell it to some other sucker....
    Sorry no malice meant just don't like being shafted??
    Mark Donoghoe, Jan 17, 2005
  15. Put a 2" (ie 5 cm) thick plank under the centre stand (makes it a _bit_
    hard to put onto the centre stand though) and the wheel comes away
    without having to remove the rear guard.
    Cheers
    '81 Suzuki GS450-s
    '87 BMW K100RT
    www.dmcsc.org.au
    Peter Cremasco, Jan 17, 2005
  16. Jason Burton-Woods
    Boxer Guest
    I removed the centre stand when I attached the sidecar.
    Boxer
    Boxer, Jan 17, 2005
  17. Jason Burton-Woods
    smack Guest
    well you'd be a fuckkwit then
    smack, Jan 17, 2005
  18. Jason Burton-Woods
    Conehead Guest
    K's aren't proper BMW's
    Conehead, Jan 18, 2005
  19. Jason Burton-Woods
    david Guest
    ....snip..
    Time to get a pack of popcorn and sit back to watch the show.
    This should be interesting ...
    David
    david, Jan 18, 2005
  20. Jason Burton-Woods
    Moike Guest
    oilheads aren't proper BMWs
    Moike
    (nor, to some are /7s)
    Moike, Jan 18, 2005
