removing decals..
Discussion in 'Motorbike Technical Discussion' started by ninja.rider, Oct 12, 2003.
  1. ninja.rider
    ninja.rider Guest
    what's the best way to remove decals from a metal tank without damaging the
    paint?
  2. ninja.rider
    bowman Guest
    If, which is unlikely, they don't have clear coat over them, try some WD40
    or one of the special purpose removers.
    bowman, Oct 12, 2003
  3. Heat them up with a hairdryer[1] and peel them off gently.
    [1] Not a Lambretta
    The Older Gentleman, Oct 12, 2003
  4. ninja.rider
    Gizzmo Guest
    Angle Grinder
    Gizzmo, Oct 12, 2003
  5. ninja.rider
    deadmail Guest
    You are truely a master of wit. I bow down at your capacity for
    inducing side-splitting laughter whilst ignoring norms like following up
    at the bottom of the post.
    I guess the masturbation is going well with you, build up those muscles.
    deadmail, Oct 12, 2003
  6. ninja.rider
    Gizzmo Guest
    Many thanks. Its nice to know that ones efforts are appreciated.
    It is hard to bottom post whilst typing one handed.
    Brian
  7. ninja.rider
    Rein Guest
    usually they are covered with clearcoat and you will mess up more than
    you'd like to...
    if there's no clear coat over it; a hairdryer will make it real easy
    to get the stickers off.
    Remove NO-SPAM from email address when replying
    Rein, Oct 14, 2003
  8. ninja.rider
    ninja.rider Guest
    thanks for the comments guys. here are a few pics:
    http://jjjacobs6.home.mchsi.com/zx-7r_decal/index.html. there is a coating,
    but the decal is damaged so i might be able to get wd40 or decal remover
    underneath to help get it off. i started doing this with gas but stopped
    when i removed a few spots of paint (now touched up). that is how this all
    started. the bike was blown over and leaking gas dissolved part of the
    decal.
    when i get it off, should i repaint the whole tank then apply new decals and
    clear coat? does the paint need to be stripped first and what kind of paint
    and clear coat should i use? and has anyone used an airbrush (like for
    model cars/airplanes) to do this? thanks.
    ninja.rider, Oct 14, 2003
