removing alternator with stripped starter clutch
Discussion in 'Motorbike Technical Discussion' started by Andy, Oct 3, 2007.
  1. Andy
    Andy Guest
    Howdy folks,
    As you know, I have removed the engine from my 91 CB750 nighthawk and
    installed a newer one. The old engine has a stripped sprag-style
    starter clutch. However the new engine did not come with an
    alternator, so I am trying to get the alternator off of the old
    engine. Problem is I cannot get any torque on the central bolt that
    holds the alternator onto the alternator shaft, because the shaft
    turns freely (due to the faulty starter clutch).
    Can you guys think of any way to keep this shaft from turning short of
    splitting the crankcases, which is what I was trying to avoid in the
    first place?
    thanks again,
    Andy
    Andy, Oct 3, 2007
  2. Andy
    paul c Guest
    this may not help with your exact problem but i'll mention my experience
    swapping '82 cb750 rotors in case it helps once you get that nut off.
    (also, I'm not sure why the starter clutch matters.) all I did was put
    the two engines in top gear and a couple of bursts with a cheap electric
    torque wrench did the trick. but the rotors were still tightly pressed
    on. a tip on another group mentioned that the rear axle can be used as
    a substitute for the factory puller. again a couple of short bursts and
    the rotors came loose.
    paul c, Oct 3, 2007
  3. Andy
    paul c Guest
    oh I just noticed that the '82 and '92 models have quite different
    alternators, sorry if previous post wasted your time, but an electric
    torque wrench might still come in handy if you don't have an air wrench.
    paul c, Oct 3, 2007
  4. Andy
    Andy Guest
    Albrecht and others,
    Sorry if I seem thick, but I am very confused! However I am slowly
    starting to understand this better.
    These are all good suggestions for stopping the crankshaft from
    turning, but that is not the problem. The problem is that the
    alternator just spins independently of the crankshaft.
    The transmission is in gear, and the crankshaft is not turning. The
    alternator still spins freely on its shaft, along with the starter
    clutch. If I try to torque the alternator rotor bolt, it just spins
    freely. The crankshaft doesn't turn at all.
    So it appears that either a) the alternator driven sprocket is
    (contrary to Albrecht's knowlege) connected to the alternator shaft
    via the sprag clutch or b) the alternator drive chain is broken (or
    for some other reason not driving the alternator).
    Any thoughts?
    Andy, Oct 3, 2007
  5. Andy
    Andy Guest
    Any thoughts?
    Andy, Oct 3, 2007
  6. Andy
    Andy Guest
    Any thoughts?
    Andy, Oct 3, 2007
  7. Andy
    Andy Guest
    I don't know why that posted three times, sorry about that.
    Andy, Oct 3, 2007
