Remove fuel tank - Honda Shadow
Discussion in 'Motorbike Technical Discussion' started by Richard, Jul 25, 2005.
  1. Richard
    Richard Guest
    03 VT750CD
    I need to remove my fuel tank to find out where a hose clamp fell off from.
    I can't tell looking in from underneath, so I think this is the best way to
    get a view of it all.
    The tank is nearly full and I'd rather do it without emptying it, if
    possible.
    Clymer gives the procedure for removing the tank and says you only need to
    disconnect a) the fuel hose from the valve and b) the fuel tank breather
    hose.
    Can this be done without losing fuel all over the place? Or am I better off
    siphoning it all out first?
    (Yes, lots of questions, but I'm a newbie - I'm learning!)
    TIA
    Richard
  2. Richard
    Richard Guest
    I'm open to that, but of all the places a clamp could fall from, what's the
    worst that could happen from riding without first identifying that problem?
    I think it's manual. I only has ON, OFF, and REServe.
    I'll pull that first, then. It shounds like that would be an easier check.
    After two years and almost 2500 miles? I guess anything is possible. The day
    before I washed and dried the bike by hand. I suppose it could have shook
    something loose while I was trying to get in all the crevices.
    Thanks a lot!
    Richard
  3. Richard
    Lushy Guest
    Cough splutter and the engine stops or you get a sudden drop in power there
    is a filter in the tap as well (normaly) and this may clog - i wouldnt worry
    to much mate while its working dont stuff with it LOL
    Lushy
    Lushy, Jul 30, 2005
