Remember the level crossing posts?
Discussion in 'UK Motorcycles' started by Cab, Aug 4, 2006.
  1. Cab
    Cab Guest
  2. Cab
    Hog, Aug 4, 2006
  3. I don't see why they can't install the missing barriers if wankers are
    going to take the piss. The half barrier crossing was always dependent
    on most (all) drivers being sensible; now it's been shown there's a
    significant % of utter fucking idiots out there it's time to complete
    the cheap and shoddy job that was done.
    Grimly Curmudgeon, Aug 4, 2006
  4. Cab
    Unfortunately, full barriers require different timings to half barrier as
    they take longer to operate and need to start closing earlier before the
    train arrives as there is no escape for a car if it's trapped so it needs
    manual checking.
    For example: Beddingham AHB if it were converted to CCTV full barrier it
    would close the A27 for 40 minutes out of every hour. So isn't really an
    option.
    Separation of road and rail is the ideal, albeit expensive, solution.
    sweller, Aug 5, 2006
  5. Darwin in action, then.
    Taking an individual lane: If the incoming barrier closed before the
    exit barrier to allow egress and if as well as CCTV there was a detector
    system in place that would interlock with a signal up line to slow or
    halt the oncoming train.
    As well as that; any **** stopped on the yellow hatches or found doing
    any weaving between barriers would be utterly castrated by the courts.
    Grimly Curmudgeon, Aug 6, 2006
  6. Cab
    Any signalling system to protect the crossing will need to be operative at
    least two miles in advance of the crossing - dependant on line speed.
    Hence:
    "full barriers require different timings to half barrier as
    manual checking."
    sweller, Aug 6, 2006
  7. Cab
    Cab Guest
    If it were that simple. The fuckers risk the lives of others as well as
    their own.
    Cab, Aug 6, 2006
  8. Cab
    Meant to add: it does that now.
  9. Ok, fair enough. That leaves wilful stupidity/recklessness as the main
    causes.
    I encountered a level-crossing survey team the other day in the
    boondocks. Just a single track manned country crossing where they were
    asking drivers about convenience, regularity of use, etc. It's one I use
    about twice a week and I'm surprised it hasn't been automated by now -
    although maybe that's on the cards. There's a lot of manned crossings in
    RoI and it probably costs a fair bit - but the accident rate on them is
    tiny.
