Reliability of Chargers
Discussion in 'Motorbike Technical Discussion' started by Bob, Jun 24, 2009.
  1. Bob
    someone Guest
    X-No-Archive: yes
    no.
    someone, Jun 29, 2009
  2. Bob
    R. LaCasse Guest
    On Mon, 29 Jun 2009 20:34:49 GMT, wrote:
    |>X-No-Archive: yes
    |>>On Mon, 29 Jun 2009 05:17:53 GMT, wrote:
    |>>|>> 2-3 amps is not too much for a semi quick charge on most M/C
    |>>|>>batteries....
    |>>|>i use 10 amps for 20-30 minutes on 12n's without problems.
    |>> Do you remove the Battery Terminals?
    |>no.
    NO??? That's pretty freaky if your running a highly computerized
    M/C Scooter like a Yamy Majesty 400, I used to do it your way on the Honda
    CH250, but today's bikes have too much computerized things to go wrong if
    the Main Fuse doesn't catch it....
    The Main Fuse catches any anomaly in power surge, but there's
    always that 1-->1,000+ times.....again computerized side stands and storage
    box lights may be at risk of a surge....
    Bob
    R. LaCasse, Jun 29, 2009
  3. Bob
    someone Guest
    X-No-Archive: yes
    sorry, but i never said i had a scooter. they annoy me unless it's an old
    vespa or guzzi. i don't think i would appreciate a computerized scooter or
    bike. hmmm, i gues the list would help
    3 1978 yamaha sr 500's. a rat , a custom and a hot rod
    1 1966 yamaha yr1 350cc street.
    1 1966 honda 305 chopper
    1 1969 triumph tr6r
    and various assorted stuff.
    someone, Jun 30, 2009
  4. Bob
    Who Me? Guest
    Geezzz......fuses don't "catch anomalies", they go open when presented with
    a substantial overload. They generally don't "care" about spikes. They
    certainly don't care about voltage spikes as a fuse "works" on excessive
    current flow.
    Equipment that is turned OFF doesn't care about spikes either.
    Who Me?, Jun 30, 2009
  5. Nonsense.
    The Older Gentleman, Jun 30, 2009
  6. Bob
    R. LaCasse Guest
    |>>>> no.
    |>current flow.
    Witty dissection, what I meant by Surge isn't a spike, but a
    Battery Charger (Current) Overload.
    Oddly the Yamy Shop Manual says not to use Auto or constant AMP
    chargers since they will damage the MF GTB9-4 "wet" SLA battery. and that
    means ALL of the Battery Tenders on the Market, doesn't it.
    I have since switched to an AGM hybrid, were I can quick Charge
    with no Damage to 12v/5amps.
    Bob
    R. LaCasse, Jun 30, 2009
  7. Bob
    R. LaCasse Guest
    |>Nonsense.
    Shear rubbish. pip pip and that blighty wanky concept to toss out.
    I agree that a side stand like the (Helix cn250-1990 and Yamy
    Majesty 2004--->2009) with a starter cutout is a bit awkward, and the
    underseat storage box with the light can drain a battery if it's low....
    Yep that part is nonsense!
    Bob
  8. Bob
    Who Me? Guest
    I wouldn't have to be so "witty" with my "dissection" if you would be
    clearer in your declarations.
    How do you connect the battery charger so that it goes THROUGH the main fuse
    as it is charging ???
    I don't think I've ever seen it done that way before. ;-)
  9. Bob
    Themotorman Guest
    My two bits, get rid of the lead acid battery and put in a niMH you
    can charge these in 30 minutes form dead with no problems. Lead acid
    batteries are a hassle, they simply cannot be fast charged as the
    voltage rises and they produce gas. ( Sounds like me at a fast food
    place!!) Another alternate for this kind of problem is to have two
    batteries and make a quick change system so you can get it in and
    out. Anderson connectors are fantastic for this kind of job. Keep one
    charged and change them over as needed.
    Themotorman, Jun 30, 2009
  10. Bob
    Bob Guest
    Well, If you use the (0) terminal rings with your
    Optima/C-tec/Battery Tender, and you accidentally forget to disconnect the
    (-) terminal and are in a hurry to see if your charger has done the
    job....it'll pop the main fuse for sure....
    The Main fuse and battery is only accessed through the ignition
    switch...right...
    Then there's your "taillight" brown wire, which is always alive, you
    can pull that too if your doing a more than 10 amps charge.
    I remove the (-) terminal if I'm going to use some zap above the
    rectifiers 14.9v, it's mostly for peace I guess, so many strange circuits in
    different bikes, like the yamy Majesty side stand ignition cutout, interior
    storage box..and some days your mind isn't so clear.
    Bob, Jun 30, 2009
  11. Bob
    Themotorman Guest
    Just a thought , put in an extension from the battery terminals to a
    Anderson connector, put leads to a Anderson connector on a spare
    battery , something you can lift with one hand, Then just wait till
    you want to start , plug the connectors together, start the bike and
    go. Unplug first!!
  12. Bob
    R. LaCasse Guest
    |>go. Unplug first!!
    I use 2 older $214 Yamy Majesty GS "wet cell" SLA MF on a UPS
    "opz/inverter/converter" float all the time to Jump Start with regular car
    cables when the battery get's too low because of the alarm or temporary
    neglect.
    I just use one battery at a time so far, but these Specialty
    Batteries are pricy, and are finicky/sensitive to charge because of hi-vrla
    internal resistance so the El Cheapo "AGMs" are better with less internal
    resistance, at least the "AGMs" are better pricewise.
    R. LaCasse, Jul 1, 2009
  13. Bob
    SoCalMike Guest
    I fabricated my own harnesses with the standard "trailer" type 2-pole
    plugs, and they work great. The plugs are available at just about any
    auto parts store, add wire, splice/solder/shrinkwrap, add rings on the
    end, solder, shrink wrap and youre done. Just double check the polarity,
    though. :)
    SoCalMike, Jul 1, 2009
  14. Bob
    Sporty Guest
    http://batterytender.com/why_batterytender.php
    Various charging algorithms are available to acommodate the wide range of
    lead acid battery styles: Flooded, Sealed, VRLA, GEL & AGM. Check with the
    factory for the combination of power, current, voltage and battery style
    that best meets your needs. Battery Tender battery chargers are equipped
    with a variety of safety and interconnect options, not available on all
    models.
    I own 3 Battery Tender Plus units and NEVER had a battery damaged, I even
    left one battery hooked up for 2 years.
    Sporty, Jul 2, 2009
  15. Bob
    Bob Guest
    On Thu, 25 Jun 2009 22:34:37 -0700, Dennis Lee Bieber
    |>OTOH: it is time for me hook up the intelligent charger for a few
    |>hours -- just to ensure the battery hasn't sulfated (the charger has a
    |>desulfate mode which attempts to desulfate a battery by using high
    |>amperage pulses at around 15-16 volts)
    How long does it the charger stay in "desulfate mode" for at 15-16
    volts.
    My shop manual says to charge at 16-17 volts for 5 hours at
    ..8amps... it says a lot of MF AUTO Chargers may no works, and may damage the
    battery....onthe other hand THAT battery said 12v/.8amps only......
    The chinese AGM battery I have now says 1 hour at 12v/4.5amps or
    regular charge 12v/.8 amps 5 hours.....
    All these batteries say something different, because they are all
    somewhat different IE: Wet/MF/SLA/VRAL/GEL/AGM,........But most any cheapo
    batteries are just a HYBRID of that, a bit of all those, so an intelligent
    charger can ping the battery to see what it can handel. it takes longer but
    is the best method for most.
    Bob, Jul 3, 2009
  16. Bob
    Bob Guest
    |>models.
    That's pretty exce$sive battery charger for me, 4 bays?
    I don't doubt that, I've had some on for 3 years and they still work
    as good or better as when I installed them, no muss no fuss....
    Oddly, (by no choice of my own), I rent 2 residences and I have to
    park in a parking lot with NO Electrical Outlets for a Battery
    Charger/tender/warmer, so I rely on the "charge and let sit" for a duration
    of time, then "charge and let sit" all over.
    The trickle charge method I use is good for ppl who don;t have a
    life, and can pay attention to the battery charging process.
    Even then, we are dealing with all sorts of MF/AGM type hybrid
    batteries and doing the math and watching the logic is a bit tedious for
    most, so I say the "Battery Tender Plus" is a must, especially the 5 stage
    desulphation one if you afford it.
    Bob, Jul 3, 2009
  17. Bob
    paul c Guest
    There's lots of opportunity for confusion on the internet, Ctek, Battery
    Tender and Schumacher (I didn't check Optimate) sites all seem to suffer
    from specifications or advice that needs assiduous attention to be
    clearly understood. I get the impression, perhaps wrongly, that the
    various small chargers are a compromise, 14.4 volts at 0.8 amps isn't
    too hard on gel batteries and is close enough to do a reasonable job on
    agm batteries. Also, they all seem to aim for about a charge of about
    80% of capacity, to go higher means leaving the charger connected for a
    number of days. Of course, it's likely not entirely the manufactuers'
    fault since many readers might confuse voltage, which is just an energy
    to charge ratio, with current capacity.
    Yuasa's site says NEVER fast-charge, but the labelling on their
    batteries says otherwise! I know of dealers who aren't aware that a
    fast charge is only a surface charge, enough to get the bike started on
    the assumption that hours of riding with the alternator charging will
    produce a deep charge. Suspect this is partly to please people who buy
    a new battery on Saturday morning expecting to ride the bike away before
    noon. I know people with electric bikes (obviously no alternator) who
    use fast chargers on them and are always complaining about miniscule range.
    The Ctek chargers that have 'motorcycle' modes don't offer an AGM
    voltage, that setting (14.7 volts if I've got it right) is only
    available for the higher current modes to be used with larger batteries,
    ones with about 50AH or more capacity.
    I doubt if de-sulfation on a bike battery which are nearly always 20AH
    or less involves a high current and a high voltage, more like a low
    current and intermittent high voltage, approaching 15, but would be
    grateful if anybody could correct me.
    (As far as I know Yuasa's 'MF' means AGM. They've had two types of MF
    for years (plus a couple of new ones) but as for the traditional ones,
    the older kind is where the user installs the electrolyte and the other
    one is where the mix is factory installed, it is the latter kind of MF
    that is intended for non-vertical installation.)
    This pretty much exhausts my knowledge!
    paul c, Jul 4, 2009
