relentless carbon fouling problem
Discussion in 'Motorcycle Technical Discussion' started by Matt, Jun 9, 2005.
  1. Matt
    Matt Guest
    And can we say that that is not necessarily because of too much fuel,
    but may be because of fuel not being burned, maybe because of an
    ignition problem.
    I will pursue the idle mixture question, but please let me ask one
    question about ignition.
    There is a wire that supplies +12V nominal to the primaries of both
    coils. When I measure the voltage, it is about 1.2V less at the coil
    primaries than at the positive battery terminal. I claim that those
    voltages should be the same. It would seem to be evidence of faulty
    connections. Somebody please confirm or deny that.
    To test, I would bypass the ignition switch and the kill switch and all
    the wiring in between by running a wire directly from the +12V battery
    terminal to the coil primaries.
    Matt, Jun 11, 2005
  2. Matt
    Matt Guest
    I took the filters out of the airboxes and put in new plugs again. It
    seemed to have very good pep at first, but soon again the performance
    got bad, and the left plug was almost completely black after three
    miles. The right plug looks fine, though.
    I checked the timing after that test ride, and it is still okay.
    Matt, Jun 11, 2005
  3. *Ding*
    The Older Gentleman, Jun 11, 2005
  4. It's true that motorbike engines have critical problems with fuel/air
    ratio requirements because of the low voltage output of their
    relatively tiny coils. The fuel/air mixture has to be richer than
    needed for stoichmetric combustion for two reasons. The first is to get
    a mixture reich enough so that molecules of burnable hydrocarbons will
    randomly be near the spark when it occurs. The other reason is that an
    IC engine needs to waste fuel to cool itslef internally...
    With the relatively weak coils, I would definitely want all the primary
    voltage I could get at the + terminal of the coil. But, with a 1000:1
    turns ratio, if you have 90% of the primary voltage, logic says you
    should be getting 90% of the secondary voltage at the plug gap...
    Well, you certainly don't need my permission to try that experiment. It
    shouldn't hurt anything to try...
    krusty kritter, Jun 11, 2005
  5. Maybe it's better to have a wrong idea than a strong belief that's
    based on a wrong idea. Ideas can be changed, beliefs are obdurate. Who
    was it that said ideas were harmless and beliefs caused wars?
    My answer to your question is based upon my belief in what the
    motorbike magazines and the technical manuals tell me. It's not my own
    idea...
    A CV carb draws a lot of the gasoline it needs to run at cruising
    speeds through the idle circuit. The bigger the engine, the more it's
    running on the idle circuit. Really small engines will be running at
    full throttle, passing little mixture through the idle circuit. If you
    ride a big bore motorbike on the highway, you're only using about 1/8th
    throttle, and running on relatively huge idle jets...
    Performance carb tuning guides disinform shade tree mechanics who
    really don't understand how the CV carb works. They get the impression
    that the idle circuit works from closed throttle up to about 1/4
    throttle and that fuel just quits flowing through the idle circuits
    when the throttle is open more than 1/4...
    But there are published graphs that show the fuel flow through the idle
    circuit continuing up to full throttle. More idle mixture does flow
    through the idle circuit at low throttle openings when vacuum is
    highest at the outlet port. The amount of idle mixture flowing out of
    the idle ports drops as the throttle is opened until the flow
    approaches zero at full throttle when vacuum downstream of the venturi
    approaches nil...
    Fuel flow through the main jet is opposite. Almost nothing flows
    through the main jet at closed throttle, and you don't want fuel flow
    through the main jet. It makes the idle mixture to rich and it's hard
    to tune the idle mixture if fuel is dribbling pass the needle jet/jet
    needle combined orifice. More and more fuel does flow past the NJ/JN
    until the needle is pulled so far out of the hole that the area of the
    main jet orifice and available engine vacuum controls the flow of
    fuel....
    Main jet fuel flow is maximized at full throttle, and idle jet fuel
    flow in minimized at full throttle. If you look at a fuel flow graph,
    you will see that the two fuel flows are equal at some point between
    1/4 and 3/4ths throttle. The point where more fuel flows through the
    main jet than flows through the pilot jet is called the "cross over
    point" and knowledgeable tuners would talk about "cross over" in
    discussions many years ago...
    But, back to the problem of fuel flow dribbling out the critical needle
    jet/jet needle combination orifice. Even if the idle mixture screws are
    set correctly, the float height is correct, the float valves are
    working right and the needle clip is in the 2nd slot from the top, you
    could still run into excessively rich mixtures at small throttle
    openings if your aluminum jet needles have been vibrating against the
    brass needle jet tube...
    Sometimes the needle will have notches worn into it and sometimes the
    brass needle jet will be worn oval and this may not be noticed by the
    newbie shade tree mechanic. Nothing he can do will solve the
    excessively rich off-idle mixture until he notices that the hole in the
    needle jet is oval...
  6. Matt
    Matt Guest
    I'm thinking that the voltage difference indicates a resistance or a
    leak that might cause a bigger voltage difference at load. I will try it.
    Matt, Jun 11, 2005
  7. I did not mention mixture needles in the post that you responded to...
    Theoretically, the jet needle and needle jet are so close to the same
    size that little or no mixture should drool past them to upset the idle
    mixture. In the real world, the jet needle rattles against the needle
    jet and makes the needle jet orifice oval shaped so even more fuel
    drools out of it at closed throttle to 1/8th open...
    The Sports Car Club of America once had an open-wheeled Spec racer
    class called Formula 440. Everything was sealed at the beginning of the
    season so drivers wouldn't "tweak" any part of the engine *including*
    the carburetors. The Kawasaki 440cc snowmobile engines used in Formula
    44 vibrated so badly they would ruin the carbs by making the slides
    loose in their bores and ovalling out the needle jets...
    What were you doing on Christmas Eve of 1968, Brady? I was laying on my
    side in a corner of the lower equipment bay of Apollo 11, safety-wiring
    the
    spacecraft side connectors coming from the umbilical. I was a
    Spacecraft Mechanic. When I wasn't fixing spaceships, I was building
    and racing motorcycles. I didn't exactly fall off the turnip truck and
    roll to a stop in rec.motorcycles.tech. I've been at this a LONG
    time...
    When I was skeptical about drilling out idle air jets, it's because I
    learned a long time ago that one just doesn't go experimentally
    drilling on expen$ive original equipment parts. There are probably 10
    million sets of junk carbs out there in salvage yards to replace the
    set the Matt might roach follwing your recommendation, but if he
    doesn't even begin buggering
    holes, he won't have to go fruitlessly searching for pristine carbs...
  8. Matt
    Matt Guest
    I tried hotwiring it, but it didn't seem to help.
    Matt, Jun 11, 2005
  9. Matt
    Matt Guest
    I adjusted the idle mixture on both sides. The tach is not real
    precise, so I went mainly by ear.
    For the left: Starting from a closed needle valve, the rpm was very
    responsive to adjustment. But after I'd opened the left one 1 3/4
    turns, rpm didn't seem to respond when I opening the valve more. Maybe
    I should have kept opening it until there was a definite slowdown, then
    set it at the average of the range? I just left it at 1 3/4 turns open,
    thinking that less is better and because I've seemingly been having
    overrich problems. That is open about 1/2 turn _more_ than it was
    before I disassembled and cleaned the carbs. Maybe since I've gotten
    the idle mixture closer to correct, I've been able to turn the idle stop
    screw to close the throttle a little?
    For the right: used the same method, leaving the screw open about 1 1/4
    turns. That is about unchanged from where I found it when I cleaned it.
    I was surprised to notice a significant improvement in performance. It
    idles better (more stably). It returns to idle faster when I let go of
    the throttle grip. There is less exhaust noise. Previously when the
    engine was hot, I was sometimes hearing noises like a loose nut rattling
    around in the engine. Maybe that was pinging. Now that noise is mostly
    or completely gone. By the way, I have been using premium gas. The
    left plug now shows somewhat less fouling. The right plug looks fine,
    as before.
    Sorry I am a little weak on terminology. By 'needle' I guess you mean
    the sliding needle controlled by the diphragm. I don't think there is a
    way to adjust that. It seems you wrote elsewhere that vibration can
    wear out that needle and its orifice. It could be that the needles were
    a little flat on the sides when I disassembled the carbs. I see that
    new needles are included in the Keyster rebuild kits.
    Matt, Jun 12, 2005
  10. Matt
    Matt Guest
    Thanks for your ideas.
    I have this possibly dumb question:
    If the bowls don't overflow and the gas is deep enough to cover the
    bottoms of the jets, isn't that good enough? You seem to be indicating
    that heavy floats can cause an overrich condition. I don't know that
    they can't, but I don't see why they would.
    The bowls are not overflowing. You know that each bowl has a little
    standpipe connected to a drain hose---I guess gas would run out of the
    hose if the float valve were stuck or if the floats didn't float at all.
    Matt, Jun 12, 2005
  11. Matt
    Matt Guest
    Matt, Jun 12, 2005
  12. That's what mechanics do, they listen for sounds that tell them what
    the engine is doing. It takes years to experience all the "funny
    noises" and associate them with a particular problem...
    When you turn the idle mixture screw counterclockwise and the idle
    speed stops rising you've turned it far enough, you're just dumping
    extra gasoline into that cylinder to foul the plug. Twin cylinder bikes
    with two mufflers are fairly easy to tune. Rich mixture on one carb
    makes the exhaust sound on that pipe sound dull and thudding. You can
    smell the rich mixture coming from the muffler on that side...
    No, if you turn the idle mixture screw *clockwise* until it slows down
    you're going the right way. Old 2-barrel automobile carbs had two idle
    mixture screws right in fron of the carb. They were easy to set. We
    would set the idle speed about right, and then turn the idle mixture
    screws in until the engine started running rough. Then we would back
    the idle screw out 1/4th of a turn and rev the engine twice and smile
    and slam the hood and go get a beer. You could adjust your motorbike's
    idle mixture the same way, but don't go for the beer. It's hard enough
    to balance a motorbike without a beer in you...
    I guess you're probably still too rich on that cylinder
    That's how the manuals tell you to tune a motorbike engine. Open the
    gas screws to raise the idle speed by richening the idle mixture on one
    cylinder, then turn the master idle knob down a bit to return the idle
    speed to spec. Go to the other cylinder and raise the idle speed again
    by opening the *other* idle mixture screw and then lower the engine RPM
    back to spec by turning the master idle knob down again...
    That's not surprising. If you were the first person to remove the idle
    mixture screws and you count the number of turns out from lightly
    seated, record that information, and re-assemble the same idle mixture
    screws in the carbs the came out of, you should be very close to the
    right idle mixture...
    Soon you will be a carb tuning expert...
    Glowing bits of carbon or sharp metal edges in the combustion chamber
    will cause pingign, which sounds like a very loose valve. Premium
    gasoline burns cooler, so the engine pings less...
    The tapered needle is called the "jet needle". It moves up and down in
    a brass tube called the "needle jet". The main jet screws into the
    bottom of the needle jet. There are two types of needle jets. One type
    is just a brass tube with a hole down the middle. That's called a
    "primary type" needle jet. The other type of needle jet has
    cross-drilled air bleed holes for better mixing of air with gasoline
    before being drawn into the carburetor venturi. That type of needle jet
    is called a "bleed type"...
    To add to the confusion over terminology, old timers call sometimes
    call the float-operated fuel shutoff valves "needle valves" and they
    call the fuel shutoff valve seats "needle valve seats"...
    If you go to the website at www.factorypro.com you can see pictures of
    needle jets that were worn egg-shaped by vibration in only 5000 miles.
    This is particularly a problem in semi-downdraft carbs used on
    sportbikes that have their cylinders laying down at a 45 degree angle,
    like my Yamaha
    FZR-1000...
    krusty kritter, Jun 12, 2005
  13. I see that the kit contains about all the brass parts which might wear
    out over a long period of service.
    The kit appears to contain the following parts that are shown on the
    carburetor fiche at www.partsfish.com
    2. Valve Set Float
    3. Needle Set Jet
    14. Holder Needle Jet
    15. Nozzle Main
    26. Jet #68
    27. Jet,Main #110
    28. Jet, Slow #35
    The jet needle appears to be a non-adjustable type with a fixed head on
    it like a nail. The spring probably pushes on the flat top or on a
    plastic spring seat, I can't tell from the drawing. In order to raise
    the jet needle and make the mid range mixture richer with less lifting
    of the vacuum slide, tuners will put washers underneath the head of the
    jet needle. Sometimes amateur mechanics accidentally install jet
    needles with various associated plastic washers in the wrong order,
    raising or lowering the jet needle radically...
    I don't know what the Keihin designations for your needle jets and jet
    needles are, but I can look up the parts in the Mikuni 33mm smoothbore
    carbs I have on one of my Suzukis. The needle jet has a hole that is
    2.64mm in diameter, and the non-tapered part of the jet needle is
    2.51mm in diameter. So the difference between the two parts is 0.13mm
    or 0.005 inch...
    That's a big gap between the needle jet and the jet needle, but those
    carbs are racing carbs and they are known for always "drooling" fuel
    out of the needle jet. I compensated for that by fitting some of the
    smallest pilot jets available. Before I did that, the engine ran far
    too rich and was always puffing out big clouds of soot at low engine
    speeds...
    If your original jet needles have vibrated against the needle jets and
    made the hole egg-shaped you'd get the same "drooling" of gasoline that
    I experienced. So a visual inspection may be in order...
  14. Matt
    jimmmr Guest
    Heres a question, When you say a number of turns. 1 turn is equal to
    turning the screw 180degrees or 360degrees????
    Jimmmr in Lubbock
    jimmmr, Jun 12, 2005
  15. One turn is 360 degrees...
  16. Matt
    Matt Guest
    By a 'turn', I mean 360 degrees.
    BTW I knew somebody who apparently meant to say that he had changed his
    opinion on a certain topic. He told me he had done "a complete three
    sixty". Very confused guy, I guess. Also referred to his children as
    his ancestors.
    Matt, Jun 12, 2005
  17. Matt
    Matt Guest
    Here's what I think I see in the photo:
    idle mixture screw, spring, and O-ring
    bowl-to-body O-ring gasket
    small package of float-valve parts (needle, seat, O-ring, flat gasket)
    unidentified jet (main jet?)
    Matt, Jun 12, 2005
  18. Matt
    Matt Guest
    I believe I will order two kits and do the rebuilds. I plan to swap
    between the carbs any removable parts that aren't included in the
    rebuild kits (eg the floats). Then if the problem moves from the left
    cylinder to the right, I will be pretty sure it is a problem with one of
    the swapped carb parts.
    Matt, Jun 12, 2005
  19. I didn't spot any paper gaskets in the kit, but it looks like enough
    parts to completely *overhaul* a carb, if that's what you want to do.
    Did you look at your needle jet and jet needle to see if they are
    actually worn out? Do you believe that you need all those parts? It's
    your money, it's up to you whether you buy the kit or not...
    But I remember an incident while working in an electrical accessories
    repair shop in the Air Force. A motor driven alternator called an
    "inverter" was used before solid state inverters could be obtained...
    The inverter needed brushes and the brushes came in a depot-level
    overhaul kit. So I opened the kit and found a whole mess of parts
    besides the brushes and I figured that I really should use as many
    parts as I had and make that inverter just like new...
    The sergeant in charge of the shop saw me spending a lot of time on the
    job and came over to see what I was doing. I told him that I was
    installing
    all the parts from the overhaul kit...
    He told me to just finish installing what I was working on and throw
    the rest of the kit away. I felt bad about wasting all those brand new
    parts, but I trashed the rest of the kit as he ordered...
    That's usually the way it is in carburetor kits. They are cheaper to
    buy than buying worn out parts one piece at a time. And the old rule
    of, "If it ain't broke, don't fix it" applies too. You might bugger the
    body of the carb up while trying to replace a part that you were
    suspicious of, but had no specific reason for replacing...
  20. It's amusing to play "devil's advocate" with a confused person when I'm
    bored. I find something that he firmly believes in, subtly get him to
    adopt the opposite opinion (180 degrees from where he started), then
    debate him back to his original position (360, right back where he
    started). Then I try debate him back to 180. If he has an ounce of wit,
    he'll figure out that I'm yanking his crank, or he'll just adopt the
    position that the true answer to a problem is unknowable...
    Such debate is a way of passing the time of day at a boring job...
