Rejetting Carby
Discussion in 'Australian Motorcycles' started by Sandgroper, Nov 6, 2003.
  1. On 7/11/03 9:15 AM, in article
    They don¹t? Please explain...... I look forward to some back pedaling....
    Hammo
    Hamish Alker-Jones, Nov 8, 2003
    #41
  2. Sandgroper
    sharkey Guest
    You'll never get up the damn hill going backwards!
    -----sharks
    sharkey, Nov 8, 2003
    #42
  3. Sandgroper
    Charlie Guest
    methinks a read of the basics of engines and gearboxes at
    howstuffworks.com would be of assistance to you...
    Charlie
    Charlie, Nov 9, 2003
    #43
  4. Sandgroper
    Sandgroper Guest
    Well OK , I hope people did get some amusement out of my post and made
    them feel a bit better.
    :p
    After doing a test run along a stretch of road that I know the revs at a
    certain speed , I got the same revs of 80Kmh @ 5200rpm and going back
    the other way against a 25 - 30 knot head wind I got 80Kmh @ 5400rpm.
    So the suggestion that I was in the wrong gear when I first made the
    post proves to be true.
    I know that the final drive gearing can't change , it just one of those
    things I didn't think about at the time .
    Since I made the initial post , I have inadvertently found myself using
    4th gear instead of top a couple of times.
    This goes to show that after the rejetting the carby with bigger jets ,
    the performance has improved to the extent that the 4th gear feels like
    the top gear in smoothness and engine noise.
    Generally the bigger jets on the CB250 has a reasonable marked
    improvement with smoother acceleration , particularly under load or
    going up hills , quicker to get up to speed and better cold starts.
    But the noticeable improvement is at speeds at 60Kmh and over ,
    everything just runs smoother and it's quicker on acceleration.
    So I would say that if anybody has a CB250 and uses it to commute along
    freeways or open roads , then get the bigger jets .
    Now I will have to wait a few days to see how much fuel these bigger
    jets will use , if they use too much , then I will have to go back to
    the stock standard jets.
    BTW , for the pedantic , I will be getting a service done on the bike in
    another 800Ks , so I will get the mechanic to check that the bigger jets
    haven't done any damage .
    Sandgroper, Nov 9, 2003
    #44
  5. Sandgroper
    Nev.. Guest
    But but but.... if you had received such significant performance improvements
    from rejetting, rather than 4th gear feeling like 5th gear, 5th gear would
    feel like 4th gear, and rather than settling for 4th, you'd be searching for
    6th.
    Nev..
    '03 ZX12R
    '02 CBR1100XX
    Nev.., Nov 9, 2003
    #45
  6. Sandgroper
    Sandgroper Guest
    Now , now , don't over analyse the thing , suffice to say that the
    second top gear felt like the top gear and that I could have used an
    overdrive after the top gear.
    The first bottom gear , the second bottom gear and the third bottom gear
    was all accounted for and ran OK.
    ( 4 < 5 .... 5 > 4 .... 5 = maximum )
    Sandgroper
    2002 CB250
    #46
  7. Sandgroper
    Goaty Guest
    GYAFWN ....
    Cheers
    Goaty
    Goaty, Nov 9, 2003
    #47
  8. Sandgroper
    Damien Guest
    No one here would EVER take the piss about anything, we all have far much
    respect for our fellow man! *cough* *cough*
    Good to hear that you have finally given in to the laws of physics though -
    that's a pretty tough battle to win, you know.
    Damien
    GPX250 (stolen) -> CBR600
    Damien, Nov 9, 2003
    #48
  9. Sandgroper
    sharkey Guest
    Hush, Nev. So long as he's happy, it's okay. Reality is what you
    can get away with.
    -----sharks
    sharkey, Nov 10, 2003
    #49
