[QUOTE] A lot of riders believe the headlights-on propaganda but if you pay attention and *really* look at traffic especially in the later afternoon and when you're heading towards the sun you'll see that there's many situations where a lit headlight actually makes an oncoming bike less noticeable rather than more noticeable. In a lower-light situation one bright central light just disguises your shape. If you want to be noticed then cover the perimeter of your bike with little pin-point lights like long-haul trucks and emergency vehicles do. (or do as Crazy-Cam wants to do and present a distinct silohette instead!)[/QUOTE] Also, the lit headlight, or two, in the case of the Striple, actually tends to make it harder for folk to judge the speed and distance of the blaze of light. The Striple comes with a fairly small battery, and, when "fiddling" with the mapping in the ECU, you want the ignition switched on, but the engine not running, so you run the risk of flattening the battery. On trackdays, I'd prefer to tape up my headlights, but, if they are on, they'll bake the tape onto the glass. BTW, on the BMW, which I got the on/off switch for, my standard daytime running is side lights on, and a pair of small, 35 watt, "running lights" also switched on. They are visible, but not too bright, and they present something different from most motorcycles on the road. regards, CrazyCam
