Reflex tester
Discussion in 'UK Motorcycles' started by Whinging Courier, Feb 20, 2004.
  1. Whinging Courier
    Ben Blaney Guest
    It'll close the active window.
    Ben Blaney, Feb 20, 2004
  2. Whinging Courier
    I can understand a muppet like Gorman now being aware of the Alt+F4
    combination, but I thought you were at least partially technically
    competant.
    Alt+F4 is the keyboard short cut for File->Close, and merely shuts
    down the active window; for pop-ups triggered by onUnload events, you
    need to be quick off the mark and close the opened window before the
    javascript engine kicks in.
    darsy, Feb 20, 2004
  3. Whinging Courier
    flashgorman Guest
    Its nice to see you practising your conviviality ahead of your court
    appearance.
    flashgorman, Feb 20, 2004
  4. Whinging Courier
    deadmail Guest
    Yes, I know.
    I was suggesting if you had multiple pages of porn open, as one might,
    that it'll only close the top one- potentially exposing heaven only
    knows what horrors below.
    deadmail, Feb 20, 2004
  5. Whinging Courier
    deadmail Guest
    See response to Blaney.
  6. Whinging Courier
    flashgorman Guest
    Anglegrinder YKIMS.
  7. Whinging Courier
    deadmail Guest
    Well, I thought more along the lines of the monitor switch...
  8. Whinging Courier
    flashgorman Guest
    I wonder if people working for porn companies have the reverse problem. i.e
    Boss comes in and sees a load of non-filthy images on your screen
  9. Whinging Courier
    The 'Show Desktop' icon is a god-send :eek:)
    CT, Feb 20, 2004
  10. Whinging Courier
    S.M Guest
    Where are you finding that shit! quick Alt+F4 works best to close those
    little buggers down if you get them anyway. At the risk of preaching to the
    educated - why not modify your host file. End of problems.
    http://accs-net.com/hosts/get_hosts.html
    I just downloaded Hoststoggle today akcherly. Works fine for the odd site
    where ad blocking makes backspacing a pain.
    S.M, Feb 20, 2004
  11. In uk.rec.motorcycles, said:
    Try ctrl + w :)
  12. Whinging Courier
    Top tip : use the keyboard instead of the mouse. Ddefinitely saves a
    few 1/100s
    Champ, Feb 20, 2004
  13. Whinging Courier
    flashgorman Guest
    Have you tried a custom made Spondon racing keyboard, pre drilled for
    lightness.
  14. Whinging Courier
    The popups and extra windows happen all the time here at work. It even
    happen when I'm opening up a local file. I don't have nearly as much of
    a problem at home.
    Good idea. Cheers.
    CT, Feb 20, 2004
  15. Whinging Courier
    Christofire Guest
    0.329 over a vnc session, and about .17 the rest of the time.
    Christofire, Feb 20, 2004
  16. Whinging Courier
    Christofire Guest
    Google for, download and install Proxomitron. Set it to load when
    windows does (it's only small) and never see popups again. For that
    matter, never see ads, javascript nasties, page counters, animated gifs,
    etc.
    Problem over.
  17. Whinging Courier
    That's fucking superb - just what I wanted and will also be installed
    at home later. Cheers, Chris.
    CT, Feb 20, 2004
  18. Whinging Courier
    Dynamic Guest
    I just got 0 seconds :p
    Fluke again though :-(
    Dynamic, Feb 20, 2004
  19. Whinging Courier
    Ben Blaney Guest
    Windows + D.
  20. Whinging Courier
    Previously on usenet, Whinging Courier said...
    A couple of .188 secs, but mainly in the .21 - .23 range.
    Lozzo, Feb 20, 2004
