Reefton Spur Video
Discussion in 'Australian Motorcycles' started by bob, Jan 19, 2004.
  1. bob said....
    bo> The little camera cost me $219 the Voltage Reg $30, the sig light socket
    bo> $10 all from JCar
    Will that camera work with a DV camera? From the image it appears that
    it has straight analog A/V inputs into the camera.
    Martin Taylor, Jan 22, 2004
  2. bob
    bob Guest
    With the camera I have I notice no lose in quality between the original and
    the Mini Cam was a slight drop in resolution which you can't tell unless you
    put it on a bigger TV over 68cms and really look. The video I posted online
    is allot lower quality than the original, I just don't know how to compress
    it and keep the quality. If you have seen footage from a Digital handycame,
    that's the quality I get around about..
    $309 USD is way to much
    http://www.eyespyshop.com.au/HelmetCameraK2.htm if you must buy online in
    Australia, my camera is $225, I got mine for $219 at JCAR. Don't bother
    about batteries, trust me on this. That big lumpy battery is the last
    thing you would want to carry around and is heavy. You will probably end up
    having to buy a tank bag if you do buy the kit.
    bob, Jan 22, 2004
  3. bob
    bob Guest
    The Sony Camera is DV camera in the picture. You have to make sure your DV
    camera has AV inputs, not just AV outputs. I know all Sonys have it, not
    sure about other brands. If your not sure, just plug your VCR or DVD player
    to your Cam and try and record something through the AV ports.
    You will find all theses types of cameras are AV 12v cameras
    bob, Jan 22, 2004
  4. bob
    Wocka Guest
    My Panasonic DVD camera can only accept an input via its Fire port (used for
    dubbing from camera to camera), But I expect if I plug in an external camera
    into this plug it will accept the images. So I have to figure out how to
    wire the RCA plugs into a Fire plug. I have searched the net and can't find
    the wiring pins of a Fire plug.
    Wocka, Jan 22, 2004
  5. bob
    GB Guest
    You *could* wire it up that way, but it won't work. Firewire is a
    serial digital link, so you'd need a digital video camera with a
    firewire out (like another panasonic dvd camera!) to feed something
    usefull into it. Some of those will also act as a tape drive or a
    dvd burner, accepting digital video from a computer to write to
    the media in the camera.
    The RCA connections on the other hand are for an analog signal.
    That's not a signal that will do anything meaningful if shoved
    up an firewire port.
    G
    GB, Jan 22, 2004
  6. bob
    Wocka Guest
    Damn,
    So I take it I need to get an external camera that feeds digital signals so
    that I can put into my Firewire port on the DV Camera.
    I was going to buy an external camera of Ebay, won't bother now.
    Wocka, Jan 23, 2004
  7. bob said....
    bo> The Sony Camera is DV camera in the picture. You have to make sure your
    bo> DV camera has AV inputs, not just AV outputs. I know all Sonys have it,
    bo> not sure about other brands. If your not sure, just plug your VCR or
    bo> DVD player to your Cam and try and record something through the AV
    bo> ports.
    Yep, mine has this function. It's a small 2.5mm jack that takes A/V
    stereo in/out. If I select "VCR Mode" I can tape to the camera from say,
    a VCR. The camera acts as a passthrough, and via Firewire I can then
    write the vision to hard disk for editing, etc.
    Handy if you want to create (S)VCDs of television shows.
    The AVI file(s) can then be written back to the camera if so desired. We
    (or rather the missus) uses Adobe Premiere. The software that comes with
    the Sony is rather woeful and only allows MPEG-1 (VCD quality) files to
    be created.
    Martin Taylor, Jan 23, 2004
  8. If you want something for editing DV, try Sony's Vegas. I've just
    switched to that after years of Premiere and it rocks. Sony have just
    bought the software from Sonic Foundry and I'm hoping they'll add some
    hardware support for it so I can switch over here and edit to DVCPro
    with Vegas as well. At the moment it only works with DV but doesn't
    need any additional hardware other than your camera.
    Cheers
    Kevin Gleeson
    Technical Director
    Blue Rocket Productions
    Hobart, Tasmania, Australia
    www.blue-rocket.com.au
    Kevin Gleeson, Jan 23, 2004
