Recommends on Servicing
Discussion in 'UK Motorcycles' started by Antoine, Oct 9, 2004.
  1. Antoine
    Antoine Guest
    The VN is close to needing a sevice - being an import, is actually reading
    kph with a mph overlay - given that it is at about 5400 km its not quite due
    for the 4k miles service but close.
    I was wondering if anyone had any recommendations on a Kawasaki dealer in
    Warks area that was good value and effective?
    I am not too sure whether "skimping" (I don't really believe this is the
    case having done a lot of my own work) by doing it myself is worthwhile -
    more for the service stamp point of view ( I didn't let the fact the very
    careful owner changed oil and filter himself stop me from obtaining the bike
    though).
    In my area the major bike distributors are Frettons, Nightingales and
    Drayton Croft but I'd equally take it to a reputable small factor?
    According to the service chart - at 4k it's due:-
    Spark plug clean and gap
    Air Suction Valve
    Brake Light Switch Check
    Brake Pad Wear Check
    Brake Fluid Level Check
    Clutch Adjust
    Steering Check
    Drive Chain Wear Check
    Spoke Tightness and Rim Runout Check
    Tyre Wear Check
    Engine Oil Change
    *most of this is within my capabilties with a Haynes or similar (except
    maybe rim-runout to any accurate level - and maybe I shouldn't really go
    into spoke tightness either - but seeing as I just managing to true my
    really wobbly cycle wheel I'm not that bad)
    The other thing thats bothering me is what could be related to the
    drivechain or engine - a sort of thrum - thrum - thrum - noise that doesn't
    really speed up or slow down much but can be noticed most around 25-40mph I
    think[1]. A little disconcerting especially if its from the engine - so I
    might be best to have it down a dealers anyway to take a look.
    Also I was thinking of getting a scottoiler like Playpus for the chain
    anyway - I don't think the chain has seen that much wear BUT its a little
    dry and might be contributing to the problem above *[1].
    Cheers
    Antoine
    VN800 Drifter
    Skoda Fabia Classic in "Skip" camouflage
  2. Antoine
    Martian Guest
    Antoine wrote:
    [snip minor service list]
    I reckon Thrum thrum thrum is the chain = lubing or replace.]
    the rest is an afternoon of relaxed fettling = time to learn about your
    bike.
    OR
    Cash in a dealers grubby mit.
    I know what I would do.
    Martin:
    VTR1000 Firestorm
    Martian, Oct 10, 2004
  3. Antoine
    Antoine Guest
    Cheers, that puts it in some perspective. It was meant to be a "fill in" but
    I think I can see myself wanting to keep it for a "while" so I guess it only
    makes sense...
    Antoine, Oct 10, 2004
