Recommended air filter cleaner?
Discussion in 'UK Motorcycles' started by Timo Geusch, Oct 22, 2004.
  1. Timo Geusch
    Time to service the Husky[1], which has a reusable air filter
    element. Which basically means I need both some cleaner and some
    filter oil - anybody got any recommendations as to what's good and
    what isn't?
    [1] Shaddup.
  2. 10/40 engine oil (clean!) is fine.
    The Older Gentleman, Oct 22, 2004
  3. Timo Geusch
    and paraffin to clean it in.
    Muck, Oct 22, 2004
  4. Timo Geusch
    Preston Kemp Guest
    Paraffin/white spirit to clean it, followed by warm soapy water. Proper
    foam filter oil to oil it (Silkolene etc). It's mega sticky so doesn't
    drip out leaving a pool in the bottom of the airbox like engine/gear
    oil do. It's also much better at keeping water out, should you take the
    bike mud-plugging.
    Preston Kemp, Oct 22, 2004
  5. Timo Geusch
    Catman Guest
    K+N cleaner kits. <GBP10 from Halfrauds. Looks like it will last for ages.
    www.cuore-sportivo.co.uk
    Catman, Oct 22, 2004
  6. Timo Geusch
    Preston Kemp Guest
    I wouldn't use K&N filter oil on foam filters. It's designed for a
    single thin layer of material, not a thick lump of foam.
