I need a recommendation for a good and inexpensive Valkyrie Tuner (mechanic). Or, if my problem is a common one, perhaps some things to check myself. I'm reasonably handy and have a pretty complete metric toolset. It's a 1998 Valkyrie with about 4,500 miles. I bought it new, as very-old unsold inventory, in 2002. I generally only ride it around on weekends. After sitting for a week or so, I always need the choke for a few minutes. After warm-up, the choke can be gradually opened and the engine pulls strongly. Recently, after about a two-week layup (just couldn't handle sitting at lights in 104-degree weather), I started up the bike and noticed a glitch in the way it's running. Even after warmup, the engine stumbles when the throttle is cracked just above idle. And when I pull away from a stop, I have to keep the revs up more than usual to keep the engine from trying to stall. It seems to pull strong when I open the throttle more fully. Also, it used to idle around 850 RPM when hot, but now it idles around 650-700. Finally, when I roll off the throttle to slow down (engine braking), I hear some exhaust popping (not a real backfire, just popping) from the right-side exhaust only. It reminds me of the way my Yamaha 650 twin used to run if I got the two carbs way out of synch, but I can't imagine how that would happen to this bike while it slept in the garage. I've put about 100 additional miles on it now, and no change in the way it's running. Any and all suggestions welcome!
