Rebuilding koni motorcycle shocks
Discussion in 'Motorbike Technical Discussion' started by Eric, Mar 23, 2007.
  1. Eric
    Eric Guest
    Hello,
    I put some old steel-bodied winged logo Koni shocks that I got at a
    swap meet on my Norton Commando. They were a big improvement on my
    worn out NJB's, but they're still a bit mushy I'm thinking they could
    use a change in oil. Good news is that they don't appear to leak at
    all.
    I asked someone at IKON about getting parts for them, they said that
    the design of Koni shock they were reproducing were a bit later, so
    they couldn't supply seals, etc. They recommended using 5 wt oil, but
    didn't say how much. It looks like I could probably just take the
    springs off the shocks unscrew the top of the shock body and change
    out the oil by turning the shock upside down and pumping it out.
    Has anyone done this before? Not sure how much to add. I was
    thinking that I could measure the amount of oil that comes out of each
    shock and put in whichever has more in it, if they have different
    amounts, due to slight leakage over the years.
    Thanks,
    Eric
    Eric, Mar 23, 2007
  2. It's quite commonly done. You really need a shock compressing tool, to
    compress the spring so that you can remove the split collets that hold
    it to the body. It is *exactly* like compressing a valve spring to
    remove the collets on that. Only bigger.
    Measuring the oil will be difficult, because you always get some left
    in the shock. Better to mark the oil level with a small scratch mark
    on the inside and refill to that level.
    chateau.murray, Mar 23, 2007
  3. Eric
    Eric Guest
    But how do I know how much oil to add? You mean look at where the oil
    level is , before I dump out the old oil?
    -Eric
    Eric, Mar 23, 2007
  4. Er, yes, duh.
    The Older Gentleman, Mar 23, 2007
  5. Eric
    Gene Cash Guest
    Yes, just like with forks. There's a motion-pro tool to do this, which
    is a long metal tube that clips to the side. You set the clip to the oil
    distance from the top and the tool sucks out oil until it's down to the
    proper level.
    It's overkill unless you're doing a couple dozen bikes, but it does
    illustrate the idea.
    I use a wood dowel and stick it in and mark the wet line and the line
    where the wood sticks out the top of the fork/shock.
    -gc
    Gene Cash, Mar 23, 2007
  6. But he doesn't *know* what the correct level or volume of oil
    should be, so your suggestions are useless, as is TOG's idea
    that he should scratch a line on the inside of the shock body,
    because the OP doesn't know how much oil has wept out of the
    the shock over years of the rod stroking in and out of the seal.
    This shock may be a dual cylinder unpressurized air-over-oil
    type, with a piston on the end of the rod stroking up and down in the
    center cylinder, pushing oil oil of that cylinder through a hole
    connecting the center cylinder with the outer cylinder.
    The piston might have a rebound control valve on it, restricting oil
    flow as the shock extends and a foot valve attached to the bottom of
    the
    inner cylinder that blows off excess pressure on compression.
    How much oil would a shock like that need? I would think that filling
    the
    shock until the oil was up to the top of the inner cylinder would be
    work just fine.
    When the piston is inserted and pushed slowly to the bottom
    of the center tube, oil shouldn't overflow the outer tube, there
    should still be an airspace above the oil...
    Potage St. Germaine, Mar 24, 2007
  7. Except he says they aren't leaking, duh.
    The amount of oil lost by the rod going in and out of the seal will be
    so small as to be immeasurable.
    In other words, guess. Not a good call.
    The Older Gentleman, Mar 24, 2007
  9. There has to be a significant air space over the fluid, or the air
    spring effect builds up too rapidly.
    There is .pdf file that has a cutaway drawing of an air over oil twin
    cylinder shock at the Koni distributor's site, I think it's www.konia-na.com
