Rebuilding brake calipers
Discussion in 'UK Motorcycles' started by Ben, May 29, 2009.
  1. Ben
    Ben Guest
    So, what's the best way of getting the pistons out if you don't have
    access to an air line?
    Ben, May 29, 2009
  2. Ben
    Ben Guest
    Obviously, when one doesn't still have the lever connected to the
    caliper...
    Ben, May 29, 2009
  3. Ben
    Dave Emerson Guest
    Block banjo bolt vhole with solid bolt.
    Apply grease gun to (opened) bleed screw.
    Apply pressure with grease gun.
    Use wood blocks (or WHY) to hold back first piston that moves until others
    catch-up.
    Dave Emerson, May 29, 2009
  4. Ben
    Dave Emerson Guest
    This only works if the greasegun is full of grease, that's the point.
    You will have to clean the grease out of the calipers afterwards but then
    you were rebuilding anyway...
  5. Ben
    Ben Guest
    Ahah, now a greasegun I do have. Unfortunately, it's filled with
    grease. Another thing to clean out.
    Ben, May 29, 2009
  6. Ben
    Eddie Guest
    What he said, but slightly alternatively: I've molished[0] an adapter so
    I can attach the grease gun to the banjo bolt hole.
    [0] At least, I think I remember molishing an adapter; I can't remember
    where it is now.
    Eddie, May 29, 2009
  7. Ben
    Eddie Guest
    If you're feeling *really* pikey, you can scrape most of the grease out
    of the calipers and re-use it. I wouldn't use it anywhere important,
    mind, since it'll be contaminated with brake fluid.
    Eddie, May 29, 2009
  8. Ben
    Ben Guest
    I'm having a Friday Afternoon Blonde Moment. Thanks Dave.
    Ben, May 29, 2009
  9. Ben
    Alex Ferrier Guest
    Drop it round to Champ. He *loves* rebuilding calipers.
    Alex Ferrier, May 29, 2009
  10. Ben
    Ben Guest
    Yeah, but they're not 6 pot Tokicos.
    They're 4-pots ones :)
    Ben, May 29, 2009
  11. IIRC you're a cyclist? I've used a track pump for that job.
    Cheers
    nickw
    nick.wilson.67, May 29, 2009
  12. So it will still have the gaylord purple hoses on then....?
    Beelzebub_on_Mac, May 29, 2009
  13. Ben
    Big pliers have always worked for me[1], with a bit of old innertube to
    protect the piston.
    [1] At least they did before I got a compressor.
    Krusty
    '03 Tiger 955i
    '02 MV Senna (for sale) '96 Tiger (for sale)
    '79 Fantic Hiro 250 (for sale) '81 Corvette (for sale)
    Krusty, May 29, 2009
  14. Ben
    Ben Guest
    As I said in the email, that's pretty much my plan for these first.
    Apparently they've got a new master cylinder as well as new discs, so
    with a bit of luck that should cure the sponginess.
    If not, then I'm sure I have Lozzo's email address round here
    somewhere...
    Ben, May 29, 2009
  15. Ben
    Ben Guest
    On Fri, 29 May 2009 06:58:10 -0700 (PDT),
    Oh, yeah, good plan. That should fit over the bleed nipple nicely and
    blocking off the banjo as Dave suggested with a bolt should do the
    trick.
    Ben, May 29, 2009
  16. Ben
    Ben Guest
    Well, I thought that but having seen the price of new pistons, I
    really didn't want to risk scratching them.
    Mind, they may already be fucked.
    Ben, May 29, 2009
  17. Ben
    Heh - wuss.
    Aye, if you stick to the bit that never meets the seal, you can beat
    the **** out of it without any problems, as long as you don't leave any
    lumpy bits that might catch the caliper bore.
    Krusty
    '03 Tiger 955i
  18. Why?
    I've rebuilt a fair few calipers and not really had any problems. I
    think the worst was drilling out a corroded pin in a rear Bandit
    caliper.
    Never done a 6 pot caliper though.
    mike. buckley, May 29, 2009
  19. I've got a mityvac somewhere if you have problems when you reassemble.
  20. Ben
    Eddie Guest
    You've obviously never re-built a Tokico 6-pot.
    Ha! Luxury!
    I've got two pairs here that you can practice on. One of the pairs might
    best be described as "slightly bent", so if you get to the inevitable
    stage of wanting to throw the cheap and nasty piece of shit at the
    garage wall, there's no harm done.
    Eddie, May 29, 2009
