Reattaching bits
Discussion in 'UK Motorcycles' started by Mr. Fantastic, Aug 9, 2004.
  1. Anyone know how I can reattach one of those little bolt-holes[1] back to the
    swingarm?
    Bolt-hole-thing seems to be made of ally, not sure what the swingarm is made
    of.
    Cheers.
    [1] Don't know the proper name for it. It's a short, hollow cylinder with
    grooves on the inside formerly attached to the bottom of the swingarm near
    the rear axle. You stick a bolt (bobbin) in it to attach a paddock stand to
    and lift the rear. There's one on each side.
  2. Mr. Fantastic
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, Andy Bonwick
    Nah, bit of Loctite and a couple of cable ties. Gaffa tape if you want
    to be really sure.
    Nigel Eaton, Aug 9, 2004
  3. Mr. Fantastic
    Mr. Fantastic says...
    Used swing arms are dirt cheap because no-one ever buys them from
    breakers. Probably cheaper than having someone weld this bit back on.
    Lozzo, Aug 9, 2004
  4. Mr. Fantastic
    That's a bit of good news as the XS swing arm is:
    (a) corroded
    (b) spindle's still seized
    (c) shortly to be on the receiving end of a powered cutting tool
    sweller, Aug 9, 2004
  5. Ta, but a used swingarm from Barton Motors is £60 + VAT. I'm sure someone
    can weld it for less.
    I would certainly hope so anyway.
    Mr. Fantastic, Aug 10, 2004
  6. Exactly what I wanted to hear.
    Thanks.
