Rear suspension under load
Discussion in 'UK Motorcycles' started by Stoneskin, Jul 28, 2004.
  1. Stoneskin
    Stoneskin Guest
    I've been reading Twist of the Wrist 2 and it mentions that when hard on
    the throttle the rear of the bike *rises*. And when braking the rear of
    the bike will drop.
    I'm curious as to why this is. Surely under acceleration there is
    additional weight on the rear of the bike which would make the
    suspension compress. So why does the rear of the bike rise?
  2. Stoneskin
    I would agree, and can't help but think that you've misread the book.
    I've not got TotW2 (only the first one), so can't compare, I'm afraid.
    Champ, Jul 28, 2004
  3. Stoneskin
    mups Guest
    Stoneskin says...
    Shaft drive bikes do this as the pinion tries to climb up the gear drive
    during acceleration and so extends the suspension. I'm buggered if I can
    think of a reason why a chain drive bike would do it, the Fatblade
    certainly seems to squat at the back when giving it some welly.
    mups, Jul 28, 2004
  4. Stoneskin
    Stoneskin Guest
    Champ left a note on my windscreen which said:
    From memory;
    "Most riders don't understand this simple fact. The harder they are on
    the gas the more the rear of the bike *rises*. To test this put the
    front wheel of your bike against a wall and, with it in gear, slowly
    engage the clutch - the rear of the bike will rise"
    The only thing I can think of is that this is amongst other information
    regarding cornering. But I still fail to see why a bike would act in
    this manner during cornering and not in a straight line. The experiment
    which the book suggests doesn't seem to be anything specific to
    cornering either.
  5. Stoneskin
    Porl Guest
    I would think it would rise if the front can't go anywhere. The front would
    compress as the back would try and move forward, be unable to, and rise up.
    If that wall suddenly disappeared the front would lift and the back would
    compress, surely.
    Porl, Jul 28, 2004
  6. Stoneskin
    Eddie Guest
    Ah, I remember that bit now.
    But isn't it followed by some discussion on weight transfer, that
    counteracts this effect.
    But in this case, they're taking about a static bike.
    It's a while since I read it - I lent it to someone and haven't got it
    back - but at some point in the book they mention about how you should
    be on the power through the corner to transfer weight to the back wheel,
    blah-de-blah-de-blah.
    Eddie, Jul 28, 2004
  7. Stoneskin
    Stoneskin Guest
    Porl left a note on my windscreen which said:
    I've managed to find this on the subject;
    http://tinyurl.com/3kheq
    "Let's take an example where you're going through a corner and you find
    that some part of the motorcycle is just barely touching down, at
    maximum lean point at the apex. You determine that you're not really
    applying the steady and continuous throttle roll on throughtout the
    turn, and may actually be at a "neutral" throttle at the apex of the
    corner, right at the point where the bike is bottoming.
    Now approach the same turn, at the same speed, and insure that you're
    applying some throttle at this same leaned over point, and see what
    effect it has on the bike's tendency to drag parts. You'll find that
    the bike will (if the throttle control is done properly, and the bike
    was just barely touching parts down previously), now make it through the
    corner without any interference with the ground. This effect is in
    agreement with what Keith Code implies in his reference to the "rear
    rises" ..... being that the chassis "rises", as the swingarm is brought
    downward away from the frame.
    The reason for this additional clearance, is that the application of
    throttle will cause the rear swingarm to be pulled downward by the chain
    torque action trying to pull these two points (the countershaft sprocket
    and the center of the rear wheel) closer together, resulting in the rear
    suspension actually rising up and giving more ground clearance between
    the suspended portion of the chassis and the ground. This is true, as
    long as the swingarm position is at a point in it's travel where the
    line between the countershaft sprocket center, and the center of the
    rear axle, fall below that of the swingarm pivot. As long as this
    condition exists, any torque on the chain will pull the wheel
    downward, resulting in this suspension extending effect."
  8. Stoneskin
    Porl Guest
    I got lost at the part where it says "Let's"
    Porl, Jul 28, 2004
  9. Stoneskin
    As you apply more power the chain will get tighter (on its top edge,
    as it were) and try and shorten. The centre of rotation of the
    swinging arm is not the same as that of the front sprocket, so there
    will be a tendency to pull the rear towards the front, resulting in a
    downward moment between the centre of rotation ond the rear sprocket.
    No, it's not.
    Ace, Jul 28, 2004
  10. Stoneskin
    Stoneskin Guest
    More gas... chain pulls rear wheel toward centre of bike... swingarm
    goes down... rear of bike goes up.
  11. Stoneskin
    Ben Guest
    I think it's something to do with the chain acting on the swing arm.
    You get a similar thing on bicycles with rear suspension. The pulling
    along the top of the chain causes the swingarm to pull down, acting
    against the shock.
    This fact is actually desirable on some pedal bikes to lock the
    suspension out when pedaling hard to give better power transfer.
    Ben, Jul 28, 2004
  12. Stoneskin
    torque reaction around the front sprocket.
    err...not sure if I agree at all with this statement, unless you just
    mean the rear suspension isn't as extended as under acceleration.
    darsy, Jul 28, 2004
  13. Stoneskin
    Preston Kemp Guest
    Assuming you're talking about chain drives, it depends on the rear
    suspension, & which brake you use. Using the rear brake only will make
    the back of the bike sink, as the force on the rear wheel will try to
    drag the swingarm pivot down (assuming the swingarm pivot is higher than
    the rear spindle). Using the front brake only will make the rear rise,
    for obvious reasons.
    With acceleration, the rear wheel will try to push the swingarm
    forwards, making the rear of the bike rise as the front of the swingarm
    tries to climb over its pivot point. However if you've got a soft
    spring, the back might squat instead, especially if it's set with very
    little rear sag. For example big trailies & off-road bikes will
    invariably squat at the rear when you accelerate hard.
    Preston Kemp, Jul 28, 2004
  14. Stoneskin
    Stoneskin Guest
    darsy left a note on my windscreen which said:
    I haven't got the book with me here but Code states that both the front
    and rear of the bike will drop when decelerating.[1]
    If the back does, indeed, rise when accelerating then the reverse should
    also be true.
    I imagine he isn't taking about braking power which produces monster
    stoppies - just suspension travel.
    [1]I don't think he was specifically talking about Bandits here either.
