Rear shocks stripable (and other questions).
Discussion in 'UK Motorcycles' started by T i m, Mar 6, 2008.
  1. T i m
    T i m Guest
    Hi All,
    I've got my CB Two Fifty in my mates nice warm workshop yesterday and
    have stripped the swinging arm and surrounding bits to give everything
    a de-rust / clean / paint / lube etc.
    I noticed that the damper rod on at least one of the Showa rear shocks
    has quite a bit of rust about 1/3 the way up the exposed rod and it's
    not just on the surface. Are they usually strippable or is it an eBay
    / Hagon job please?
    I can't get the main stand off without removing the lh exhaust (and I
    want to get that off in any case) but one of each pair of domed nuts
    the retain the exhaust clamps on the head are seized. I Plus Gassed
    them last night and again earlier so will give them another go in the
    morning. Failing that freeing them I was thinking of sticking the gas
    torch on them for a bit and or cutting the dome off (or drilling a
    hole in it) and getting some PG in the other end?
    I have removed the cross (balance?) tube clamp nut and clamp and also
    soaked the exhaust joint ready in the hope I can get it all moving but
    what are the chances it will come apart?
    All the best ..
    T i m
    T i m, Mar 6, 2008
  2. T i m
    M.Badger Guest
    Hagon or Shox job usually.
    Heat, an impact driver, PG ( Tips and PlusGas ) and patience. Set the driver
    to tighten, heat the dome thingy and whack it. Set to loosen and whack it.
    Repeat until bored.
    Oh, it'll come apart eventually. This will be accompanied by removing a
    snapped stud, skinning your knuckles, maybe burning them and you'll invent
    new swear words too.
    BTDTGmanyTS
    When you put it back together, use a smear of copaslip or aluslip on the
    threads and the job will be ( marginally ) easier next time.
    M.Badger, Mar 6, 2008
  3. T i m
    T i m Guest
    Ok, thanks. Not ever dealt with Shox, any particular suppler please
    (to avoid any of those 'you paid how much' moments).
    Luckily I've got quite a bit of that, especially as it's often me that
    would be fixing the problems caused by other peoples lack of said. The
    problem is although I don't really want to be spending too much time
    on this particular project I know I won't be able to help myself from
    doing it fairly well (rather than 'thattle do').
    It's only 10mm (6mm thread) so I won't whack it too hard ..
    Nooo, that won't happen ..
    That probably will .. already pinched my thumb with a badly fitting
    chuck key ..
    Why is it we touch hot things to see how hot they still are? Or
    actually fully pick up that bit of bolt we have just cut off with a
    hacksaw ...
    Yeahbut that's the fun bit!
    Ah, I didn't know about Aluslip .. so thanks (I do use Copaslip where
    appropriate though).
    All the best ..
    T i m
    T i m, Mar 6, 2008
  4. T i m
    T i m Guest
    Ok cheers. I couldn't see any obvious way of stripping them let alone
    rebuilding them but though I might have missed something.
    Oh well, if they aren't too expensive a new pair probably wouldn't
    hurt ...
    All the best ..
    T i m
    T i m, Mar 6, 2008
  5. T i m
    T i m Guest
    Thanks very much for that Grant but I think they (or certainty the
    ones on that link) must be for a different CB250 to my 'Two Fifty'
    (Nighthawk) as the end fittings look different (the existing ones have
    cast ally / steel eyes with metal bushed rubber inserts etc).
    I'll give eBay a closer look though.
    All the best ..
    T i m
    T i m, Mar 6, 2008
  6. T i m
    M.Badger Guest
    Shox are just a cheapie brand, one of many I'd guess. Bit oversprung/under
    damped, like most cheapie units. M and P do them, or try Wemoto, or best of
    all, your local dealer. The next step up in terms of ride quality in my
    experience is Hagon.
    When the rear units on my Er-5 decided to piss their oil out, I just went
    for generic cheapies, £50 the pair. By going through the catalogue at the
    dealers, I got a pair with the correct fittings but an inch longer than
    stock. They were a bit harsh, but did the job.
    Aluslip is not as easily available as copaslip. Wurth do their version of
    it, but I can't remember their brand name. I was recommended it for use on
    brakes and for where steel meets aluminium and heat, ie, exhaust studs. I
    had a small tube of the stuff, it lasted about 5 years. Whether it was any
    better than copaslip or not I'd decline to comment, but I didn't get any
    seized studs, so it does work.
    M.Badger, Mar 7, 2008
