Rear footpegs
Discussion in 'UK Motorcycles' started by Ovenpaa, May 1, 2004.
  1. Ovenpaa
    Ovenpaa Guest
    We are off to DK for a holiday run in July and it now looks like I will be
    riding the T595 with partner on back, she says the rear pegs are too high
    and are uncomfortable after a while, (probably very true) however she would
    be happy if they could be moved down and forward by a couple of inches or
    so.
    Has anyone come across a fitting that extends down the peg from the bracket,
    or is it off to a friendly fabrication shop?
    TIA
    /d
  2. Ovenpaa
    Ovenpaa Guest
    Neat, so you are volunteering to design/make them then?
    Cheers
    /d
  3. Ovenpaa
    Robbo Guest
    Only ones I have ever seen were for my Goldwing. I reckon a friendly
    fabrication shop will make them up exactly to suit.
    Take her along and get the measurements sorted right first time. Then she
    can't moan about it.
    Robbo
    BMW K100 RS 1984
    BotaFOF #19. E.O.S.M 2001/2002/2003.
    B.O.S.M 2003/4.FURSWB#1 KotL..YTC449
    PM#7
    Robbo, May 1, 2004
  4. Ovenpaa
    Molly Guest
    You can tell you're an engineer, a beautiful solution is a simple one.
    Molly, May 1, 2004
  5. Ovenpaa
    charles wright
    Oct 26, 2013
    1
    0
    m4
    Hi
    just blundered onto this forum noticed you have a matchless m4. (1925/ 1926?)
    not many of these about, is yours on the road?
    mine is theoretically on the road, but i found a sidecar for it and i am in the process of restoring it
    charles
    charles wright, Oct 26, 2013
