Rear disk - question 2
Discussion in 'Australian Motorcycles' started by DJB, Aug 17, 2003.
  1. DJB
    DJB Guest
    It's been a while since I've been on aus.motorcycles, good to see there's
    still a wealth of info out there. Assuming I get the old disk off (thanks
    for all the responses), I'm still a bit suss on the new one. I had to order
    it in but stupidly left the shop without checking it out first. The rear
    disks I've had previously on the FJ1200 were all the solid type, whereas the
    new one I've got is the type with all the holes in it. I've only ever seen
    this type on as front disks. It looks like it will fit ok, but just
    wondering if this type of disk would normally go on a rear or has the wrong
    disk been ordered.
    DJB, Aug 17, 2003
  2. DJB
    Fwoar Guest
    It's a Ventilated disk
    Should be ok as pretty much all disks are like that nowadays
    daron
    Fwoar, Aug 17, 2003
  3. DJB
    glitch1 Guest
    It's most proabably not an OEM-Yamaha part, but aftermarket (nothing wrong
    with that).
    As long as the bolts fit, the diameter and thickness match, you'll be fine.
    cheers
    pete
    glitch1, Aug 17, 2003
  4. DJB
    No; it won't fit.
    Tell you what; you send it to me and I'll send you an almost-new ventilated disk as a replacement. (Only done
    145,000km)
    I'm only doing this 'cause you're a mate......
    Knobdoodle, Aug 17, 2003
