Rear disk is stuck
Discussion in 'Australian Motorcycles' started by DJB, Aug 16, 2003.
  1. DJB
    DJB Guest
    So much for a relaxing weekend. I went to change the rear disk on my FJ1200
    this morning and two of the bolts holding the old disk on are jammed, the
    rest came off okay with a bit of CRC and some effort and swearing. I got a
    bit heavy handed with one of them and now the allen key type head is stuffed
    (or at least very close to it). Anyone got any suggestions on how to remove
    it, or get the other one off. I've heard of people who drill out bolts that
    are stuck but the last thing I want to do is stuff the thread where the bolt
    connects to the wheel.
    DJB, Aug 16, 2003
  2. DJB
    DaZZa Guest
    Use a hacksaw, and cut a decent sized slot across the head of the screw - then
    use a flat bladed screwdriver instead of an allen key.
    If you're really game, you could try and cut a cross so you can use a posidrive
    or big phillips, but you have to be dead sure of your angles.
    DaZZa
    People can be divided into three classes.
    The few who make things happen
    The many who watch things happen
    And the overwhelming majority who have no ides what has happened
    Picked up from a web site, author unknown
    Address in header is spamblocked. ROT13 the following for email replies
    DaZZa, Aug 16, 2003
  3. DJB
    Boxer Guest
    You need to put some heat on it a small gas torch should do it.
    Boxer
    Boxer, Aug 16, 2003
  4. DJB
    Mike.S Guest
    I woulda gone the sunlight and magnifying glass route myself *shrug*
    Mike.S
    Mike.S, Aug 16, 2003
  5. DJB
    Dr.Shifty Guest
    If the head is sitting proud of the disc you can cut a slot in it. But if the
    head is almost level with the disc, such as a countersunk screw, you can put the
    allen key in the damaged hole, then hammer a centre punch near each flat around
    the key. This will close the hole up tightly around the key. Then heat the thing
    and give it another go.
    Kim
    Dr.Shifty, Aug 16, 2003
  6. DJB
    smack Guest
    split the cases and come at it from behind
    smack, Aug 16, 2003
  7. DJB
    CoRkS Guest
    golly that sound s rewd or illegal
    CoRkS, Aug 16, 2003
  8. DJB
    Dave Mojo67 Guest
    Clem that translates to: Over which the Bumsen is sharkeys, which is
    completely sigfile?
    What exactly are you getting at there champ?
    Cheers
    Dave (Mojo67)
    Dave Mojo67, Aug 16, 2003
  9. DJB
    sharkey Guest
    I think it's Clem's way of asking what the **** my .sig is on about?
    -----sharks
    sharkey, Aug 16, 2003
  10. DJB
    Errm... I think it was "what the **** is Sharkey's sigfile about?" or somesuch, Dave... (but I can't get that
    to directly translate anymore...)
    Knobdoodle, Aug 16, 2003
  11. DJB
    atec77>> Guest
    looks like wasting bandwidth (in the long version) , or is it wasting
    capabilities.. been a while
    atec77>>, Aug 16, 2003
  12. DJB
    Ding!
    You win a pick of the bored.....
  13. DJB
    sharkey Guest
    Yeah, "You are wasting bandwidth (lit: Transmission capacities)" ...
    I just like the sound of it.
    -----sharks
  14. DJB
    Tux Guest
    *Sigh* bring it over to my shed, and I'll give it a seeing to. ;-)
    Tux, Aug 18, 2003
  15. I don't see how "spraying" it will help...
    Postman Pat
    Pat Heslewood, Aug 18, 2003
  16. I hear the "spraying substance" has some quite useful "lubricating
    properties"...
    big
    Iain Chalmers, Aug 18, 2003
  17. Cum spray away,
    Cum spray away,
    Cum spray away with me (you guys)
    Cartman Pat
  18. DJB
    Hmmm, two fishies - although they're both a bit undersized. Back you go fellas!
    *splish!* *splash!*
    :-D
    BT Humble, Aug 18, 2003
  19. Hmmm, two fishies - although they're both a bit undersized.
    Thats a hell of a size limit you've got down there in Cantberra! I mean
    I can understand Pat being "undersized", but me???
    big
    Iain Chalmers, Aug 19, 2003
  20. DJB
    Size limits aren't based on weight Big, they're all nose-to-tail measurements. ;-)
    BT Humble, Aug 19, 2003
