rear brakes sticking on 2000 SV650?
Discussion in 'Motorbike Technical Discussion' started by Eldon Tyrell, Aug 18, 2004.
  1. Eldon Tyrell
    Eldon Tyrell Guest
    Hi All,
    i just replaced a leaking rear master cylinder on this bike, and since
    then ive had a couple of panic stops in traffic.
    both times, the rear wheel locked up, but STAYED locked up even after
    i removed my foot from the pedal, then released spontaneously maybe 3 to
    5 seconds later.
    the new rear master cylinder and pedal appear to be in perfect condition.
    the pads are pretty thin and im thinking maybe one of the caliper
    cylinders is jamming because its close to the end of its travel?? any
    ideas? ive already ordered new pads.
  2. Eldon Tyrell
    Eldon Tyrell Guest
    thanks, sounds like worn out pads and/or corrosion..
  3. Eldon Tyrell
    Mark Olson Guest
    Make 100% sure the new master cylinder isn't binding due to being installed
    wrong. The only thing you touched is pretty likely to be the culprit if
    you haven't changed anything else...
    That said, it's not unknown for calipers to jam up due to corrosion,
    especially if you've ridden in the winter and gotten salt on the caliper.
    I'd take off the caliper, strip and clean and reassemble. If you find any
    hint of corrosion, I'd do the same to the front calipers as well.
    Mark Olson, Aug 19, 2004
  4. Eldon Tyrell
    Page Guest
    Uncover the relief port and it should be back to normal. Pretty usual
    if you screw the linkage in too far.
    Page
    '01 FXDWG, NTXNS
    "Happy Hour" starts one twist of the throttle past neutral!
    Remove the 123 to reply.
    Page, Aug 19, 2004
  5. Eldon Tyrell
    Eldon Tyrell Guest
    On Thu, 19 Aug 2004 17:15:46 -0500, Page wrote:
    huh? whats the relief port? are you describing something on the master
    cylinder or on the caliper?
    Eldon Tyrell, Aug 20, 2004
  6. Eldon Tyrell
    Page Guest
    It is in the master cylinder. If you noticed when you pulled the
    plunger out, there was a tapered spot on the shaft followed by an rubber
    seal. The relief port is a tiny hole in the reservoir that allows the
    fluid to return to the reservoir when the handle is released. If the
    plunger is slightly pushed in because the cable is too tight or the
    linkage is screwed in too far, it blocks the hole and doesn't allow the
    pressure to release the calipers so the next time you squeeze the handle
    the calipers keep getting tighter and tighter until it locks the wheel.
    The spring in the master cylinder could also be weak. The only thing
    that causes your calipers to retract when you let off the handle is the
    seal. When the piston in the caliper is pushed out by the hydraulic
    fluid it distorts the seal outward. Since it is rubber, when pressure
    is relieved then the seal goes back to its neutral position pulling the
    piston back with it. So, if the pressure is never relieved, then the
    seals never have the chance to pull back. This will cause the
    conditions you described and pre-mature brake pad ware. Left set long
    enough, the fluid will slowly be pushed back up into the reservoir.
    Take the top off the reservoir, work the brake, you should see a little
    spurt of fluid coming back up into the reservoir with each pump as you
    release the brake. Be careful though the brake fluid will eat through
    any paint it gets on in a hurry, I don't think you can wipe it up fast
    enough, unless you are using DOT 5, it shouldn't hurt the paint.
    The relief port could also be clogged. Spray compressed air through it
    to clear the blockage.
    Page
    '01 FXDWG, NTXNS
    Page, Aug 21, 2004
