Real buying dilemma
Discussion in 'UK Motorcycles' started by SteveH, Feb 13, 2009.
  1. SteveH
    SteveH Guest
    The top box issue has put doubts in my mind over an Airhead - I was
    really counting on being able to stick a box on it quite easily as a
    back rest and to carry some extra bits and pieces.
    Anyway, there are 3 bikes under consideration:
    R1100RT. N-plate, 27k miles. 3 piece luggage.
    K1100LT-SE. As I recall, an M-plate. Obviously the full 3-piece luggage
    set. Around 60k miles.
    R100RT. K-plate. Only comes with side panniers.
    All 3 are about the same kind of money - the R100RT is towards the top
    of the market for one, as it's from a specialist with service, fresh MOT
    and 3 month warranty.
    I really don't know which one to get.
  2. Ride one first. I had one and it was crap. Ugly. Slow. Uncomfortable
    (for me). Great fairing, to be fair.
    I think they are ugly but that's obviously subjective. I had a K100rs
    16v and it was a great bike. The 1100's supposed to be better.
    I like the sound of this but I've never ridden one. Both guys at my
    local back street garage have one and rate them highly. One of them
    has 1/4 million miles on his.
    Are you commuting a long way on it? If so I'd want ABS.
    Cheers,
    nickw
    nick.wilson.67, Feb 13, 2009
  3. SteveH
    SteveH Guest
    This comes up all the time on google searches - very poor riding
    position due to the slop of the seat. Also found out that mid-90s
    gearboxes have been known to lunch themselves, and valve clearances need
    doing at 6k mile intervals.
    The weight is what has stopped me on this front so far - 300kgs is
    bloody heavy for a shortarse. Although I did manage the one I rode OK.
    I'm still coming down in favour of this one myself.
    Simple, almost agricultural engineering.
    I don't do commuting these days.
  4. SteveH
    You really need to ride all three, as they're all very different. I'd be
    leaning towards the K though if you absolutely need a topbox.
    I like airheads but I'd probably get an R100RS instead of an RT...
    Timo Geusch, Feb 13, 2009
  5. Do you mean slope? I've not googled about it, but the problem I had
    with it was that it's got a huge comfortable-looking seat but it tilts
    towards the front and you wind-up only sitting on the narrow bit. To
    be fair, I kept it for about 4 years and did 80K on it but it was
    always just a tool. I didn't have any feeling for it - unlike all my
    other bikes.
    Cheers
    nickw
  6. SteveH
    SteveH Guest
    Yes, I meant slope.
  7. SteveH
    Yes, but they're a piece of piss to do. I assume you realise that both
    this one and the K have 6k service intervals?
    I don't find the seating position on the RT that much of a problem and
    IIRC the 1150 has a similar if not the same position. Mind ewe, I've
    finally done something about the OEM seat...
    They're OK, but I find both boxers slightly easier to handle. Neither of
    them are as top heavy as, say, the big Triumph barges or a Guzzi Spada.
    They're basic, but not that simple. Keep that in mind when looking after
    it.
  8. SteveH
    SteveH Guest
    6k valve checks on the K, too?
    That's piss-poor for a 'touring' bike - I thought only Suzuki had such
    short check intervals on modern bikes.
    Don't see anywhere near as many complaints about the R1150RT.
    Why do 1100s depreciate so quickly, whilst Ks and 1150s are holding
    value?
    The all-up weight of me, Katie, luggage and bike worries me a tad -
    you're talking around half a tonne.
    I was under the impression they would be one of the few vehicles left
    running after World War 3....
  9. SteveH
    The keyword here being checks, although they may be every
    12k. *Adjusting* the valves on a K is a much bigger job than on an
    oilhead...
    But you'll have to service it anyway? And it's not like you're likely to
    have that done every three months like I do...
    Because the 1150 is the better bike.
    IIRC you're about my size, and I managed a GS Adventure with the 30l
    tank, *decent* expedition panniers and Ann on the back. On gravel and
    on mountain roads in Switzerland.
    So stop wussing about, willya?
    They probably are. But that doesn't mean you can neglect them at
    will, and if you're used to mainly Japanese machinery they're just a
    little quirky.
  10. SteveH
    SteveH Guest
    I'm still far too used to just chucking new oil and a filter at bikes
    every 12 months. Can't remember the last time I had to have valve
    clearances done. Although the Duke will need them, and a belt change,
    this spring.
    Hmmm, I'm 5ft 8in with a 29in inside leg. I can't reach the floor on my
    Hongdou without canting it over to one side.
    Hmmmm. I really don't know what to do.
    I suppose 'buy a Pan' is the answer, really.
  11. Can't comment on the R1100 as it went to above mentioned
    "backstreet"
    guy once a year, but I put over 100K on my K with oil and filter
    changes only
    and it was still going strong when it was killed by a National Express
    coach.
    It wasn't hugely uncomfortable, just disappointing. The seat looks
    very
    appealing but forces your bollocks against the tank. Perhaps my main
    complaint was that it was so slow. An 1100 - even a tourer - should
    have "reasonable" performance. It was *useless*.
    I don't know if the LT is much heavier than the RS. It looks a lot
    bigger but
    I think the difference is in the plastic. But I'm 5'11" and of fairly
    small build
    and really had no probs.
    Cheers,
    nickw
  12. SteveH
    SteveH Guest
    There's 30-40kgs in it, depending on the era of RS - 8v bikes are a fair
    bit lighter than the last of the K1100RS 16v bikes.
  13. SteveH
    (SteveH) wrote in
    So? Once every 3 years for you.
    It's a simple job on the boxer twin as access is very easy. It takes Mike
    at Cardiff Motorrad a few minutes per pot. I usually get Mike to do a
    service on my bike once a year even if I haven't covered 6k. The last 2
    services have been £100 and £157. The latter was for a full monty 12k
    service.
    wessie, Feb 13, 2009
  14. SteveH
    On Fri, 13 Feb 2009 20:42:57 +0000, Timo Geusch
    snip>
    If I decide to get rid of the outfit I'll be looking for a good R100RS
    irrespective of cost. They're by far the best R100 made and they're
    not depreciating any more so it's miles for service costs only.
    Andy Bonwick, Feb 13, 2009
  15. Not this one.
    Maybe this one, of it's in very good nick.
    This one, if it's cheap.
    The Older Gentleman, Feb 13, 2009
  16. SteveH
    Gyp Guest
    As a long time boxer owner, (23 years or so; R80ST then the R80RT and
    R65RS that I've got at the moment) I find that I enjoy the airheards
    over the other bikes. I don't mean that the airheads are in themselves
    better, it's just that I enjoy them more.
    Of the bikes you've listed here, despite my little legs I found the
    R11RT cramped and uncomfortable. While clearly superior to the R100RT in
    terms of performance, ride, handling, steering, braking, I find riding
    them a somewhat detached experience. As mentioned elsewhere there are
    some reliability issues too.
    I've only ridden a K1100LT-SE once. That was enough. Big wobbly
    supertanker of a bike; more like industrialised sailing than biking. The
    fact that the test ride was on country lanes clearly wasn't playing to
    its strengths though.
    The R100RT (actually I can't talk knowledgeably about the R100RT as
    oddly I've never ridden one, but it's not hugely different to my R80RT)
    is an old design, the bike wobbles over white lines, it's not fast and
    generally feels like riding a bike from another era. Because it is.
    What you buy depends greatly on what you want to use it for. The R11 and
    K11 are superb transport; and which I opted for would depend on the mix
    of roads I was likely to encounter. I know a chap that does 1000 miles a
    week on a K and doesn't seem too suffer too much from the experience.
    The R100RT is very enjoyable, you're involved in the experience, and
    it's fun at 60-80 or so. The other two are technically more competent,
    but that IMHO doesn't make them better motorbikes.
    Gyp, Feb 14, 2009
  17. SteveH
    SteveH Guest
    Thanks for that summary.
    It pretty much sums up what my thoughts are in many ways.
    After years of owning Jap. bikes, I found I really don't need the
    performance and find them really lacking character.
    Which is why I went for the 750SS - yes, it's slow, and it really is
    from a different era than the VFR I had before it - but it got me
    enjoying riding again.
    An R100RT would hopefully have the same 'feel good' factor, but with
    enough comfort to take Katie and I on weekends away / trips over to
    Europe - including, hopefully, future French runs. It wouldn't be used
    every weekend, as we have the Ducati for that - but would get used a
    handful of times a year for longer stuff.
    SteveH, Feb 14, 2009
  18. SteveH
    Gyp Guest
    I suspect that the R100 will be slower than the Ducati, but the R100
    will be more suitable for trips away. From your described use however,
    the pairing of the 750ss and K11 might be a sensible one. At least on
    the K you wouldn't get left quite so far behind.
    For long outings on slower A and B roads I'd take the R100 over the K
    anyday, but if my long day was predominantly motorway, especially 2 up,
    the R100 might not be the optimum choice. That said, I've done Lands End
    to John O' Groats on the R80RT 3 times (only once in one go mind) and
    it's taken me to Monaco 2-up and another time to Andorra. Oh, and people
    tend to circumnavigate the globe on R100s without the need for 3 Toyota
    Landcruisers.
    Can I ask a silly question..? Have you actually ridden an airhead RT for
    any period of time? If not, get over to Gloucestershire and take the R80
    out for the afternoon. It's just that they're a bit of a Marmite bike,
    and if you love them they make more sense than any other bike on the
    road. If you don't quite "get" them however, it'll be a slow, wobbly
    disappointment of a bike and you'll end up Nigeing it out and probably
    taking a bit of a financial hit.
    Gyp, Feb 14, 2009
  19. SteveH
    That is true, but it's usually on a R100GS that's been on a visit to HPN
    before the trip.
    Actually, I'd fancy another R100GS...
    Timo Geusch, Feb 14, 2009
  20. SteveH
    Gyp Guest
    Mere details.
    I'd *love* a black and yellow paralever R100GS.
    Gyp, Feb 14, 2009
