Reactolite glasses
Discussion in 'UK Motorcycles' started by nilocp, Jul 31, 2008.
  1. nilocp
    nilocp Guest
    People, I have a problem, which hopefully someone can help with!
    I have worn glasses for over 50 years, and have only ever needed /
    wanted 1 pair of spectacles. For over 20 years I have used Reactolite
    Rapide lenses which do everything I want.
    They are now no longer available, so my optician has supplied
    Transitions which I think are crap.
    They are clear indoors, and not very dark outside, but the worst
    thing for me is they do not work in the car, or behind a visor.
    I spend alot of time in bright sunshine,
    and cannot cope with changing glasses all the time.
    Someone must do a photochromic lens that works in the car.
    Reactolites
    did!!
    Colin
  2. nilocp
    Cane Guest
    I think you're at an age where you should wear some of those tinted
    clip on things that flip up when you don't need them. But in the mean
    time.
    http://www.specsaversdirect.co.uk/special_offers.php?pname=offers/free-reactions
    "F.A.B Gramps"
    Cane, Jul 31, 2008
  3. nilocp
    Grumpy Guest
    Dunno about the car - but for the bike:
    http://www.sportsbikeshop.co.uk/motorcycle_parts/content_prod/82/2726
    Any use?
    Grumpy, Jul 31, 2008
  4. nilocp
    Catman Guest
    My experience is that my old lenses (transitions IIRC) were much better
    than my new ones (Kodak something something or other)
    www.cuore-sportivo.co.uk
    Catman, Jul 31, 2008
  5. Plastic lets less UV through than glass. Glass lets about 10% through.
    Back in the old days, you could get a bit of a suntan through your
    tempered windscreen, but the plastic in laminated screens blocks 99%.
    Hence of course, there will be UV getting through all the non-forward-
    facing windows as they are as far as I know still made with tempered (ie;
    cheaper) glass.
    Paul.
    CBR1100XX SuperBlackbird (Buen mueble de patio)
    And a pushbike of some sort.
    BOTAFOT #4
    BOTAFOF #30
    MRO #24
    OMF #15
    UKRMMA #30
    Ovejas y buitres:
    http://obscuredomainname.org
    Paul Carmichael, Jul 31, 2008
  6. nilocp
    Ben Guest
    You can get different "darknesses" of Transitions. My optician showed
    me a little chart with the darkened colours on when I got mine.
    And I got warned they wouldn't work in modern cars due to windscreens
    having anti-UV coatings.
    Ben, Jul 31, 2008
  7. nilocp
    @4ax.com:
    as Paul says up there, it's the plastic layer in the laminate that blocks
    UV
    wessie, Aug 1, 2008
  8. We were somewhere around Barstow, on the edge of the desert, when the
    drugs began to take hold. I remember Paul Carmichael
    Theoretically, yes.
    You see, that's the dangerous thing about theory - it leads those
    without practical experience of the thing to spout bollocks.
    For that reason, probably.
    Certainly, Reactolites I've had have worked fine in cars.
    GS850x2 XS650 SE6a
    "It's a moron working with power tools.
    How much more suspenseful can you get?"
    - House
    Grimly Curmudgeon, Aug 1, 2008
  9. nilocp
    nilocp Guest
    nilocp, Aug 21, 2008
