Re: Harley Davidson Dyna ride height
Discussion in 'UK Motorcycles' started by Wicked Uncle Nigel, Dec 10, 2005.
  1. Wicked Uncle Nigel
    Vito Guest
    You're right. So do pendulums and damping frame flex isn't the ONLY thing a
    steering damper absorbes.
    Vito, Jan 11, 2006
  2. Course not!
    Can't figure it out myself either. Probably the same self-flagellating
    characteristic which causes me to continue living like a hamster on a
    wheel in New York City.
    But maybe it's a matter of pride too. Melikes the supersports and I am
    compelled to spread the gospel according to Valentino.
    Greek Shipping Magnets, Jan 11, 2006
  3. Wicked Uncle Nigel
    Vito Guest
    I tried. I recalled how much fun I'd had as a kid, when we were able to pretend
    that Ms Smith's front porch was a space ship and how all that had been taken
    away by an older kid proving that it was merely an old front porch. So I do
    understand how hard it is for you to accept that the 4-stroke stuperbike you
    have let yourself believe handles like a real race bike in fact is little more
    than a dolled up tourer, or that factory attempts to make it handle like a race
    bike have made it treacherous. If you want to continue your fantasies simply
    ignore my posts and instead listen to the 2-wheel NASCAR crowd.
    Vito, Jan 11, 2006
  4. Wicked Uncle Nigel
    Vito Guest
    You are right. It reduces the *effects* of frame flex. I never said it prevents
    the flex. But one effect of frame flex is steering oscillation. So why are we
    argueing?
    The frame is connected to the ground thru a stiff swing arm at the rear but thru
    a hinge (the steering head) at the front. When flexed it acts like any spring
    and oscillates, or tries to. This oscillation tries to shake the fork assembly
    via the 'hinge' encouraging it (and the bars) to flop back and forth - the
    dreaded wobble! A damper across that "hinge" (between frame and fork) damps out
    that oscillation just like your rear shocks damp your rear springs'
    oscillations.
    Again consider what happens when a front tire strikes a bump whilst heeled well
    over, say 30-45 degrees. The bump tries to drive the tire/wheel straight up.
    This 'pulse' of energy gets divided into two vectors depending on the lean
    angle. One goes into the suspension where it is absorbed as it would be were the
    bike vertical. The other tries to both throw the tire/wheel upward and if the
    frame is completely rigid the tire momentarily looses contact and traction. If
    other bumps follow the front end of the bike "chatters" out and down you go.
    Enough springiness is built into a proper frame to mitigate this. The vertical
    componant of the bump's force, amplified by the leverage of the forks, twists
    the frame at the steering head whilst trying to hurl the tire off the ground.
    The frame then rebounds like a spring pushing the tire back down and minimizing
    the "chatter". However, like any spring it has stored this energy and must
    dissipate it else the frame will continue to oscillate.
    Because of the "hinge" these oscillations appear to the rider as oscillations of
    the bars and, depending on the natural frequency of the front end assemble, may
    even grow into a "tank slapper". If a bike has this tendency at the speeds it
    is ridden we buy a "steering damper".
    No, this does not say that hitting a bump while heeled over is the ONLY thing
    that causes frame flex. A rutted road might have the same effect and having
    more power than one's frame could handle was a common source of tank slappers
    into the 80's.
    Vito, Jan 11, 2006
  5. Wicked Uncle Nigel
    Vito Guest
    Since you thoroughly believe all this try an experiment. Head down a nice
    straight road at 40 or 50 MPH. Put your hands on the tank and stand on the
    pegs. Now shift your weight quickly from peg to peg shaking the frame. Since
    frame movement doesn't effect the forks you won't generate a wobble and fall on
    your arse will you? Bwahaha! But no, please do not try this .....
    Vito, Jan 11, 2006
  6. Wicked Uncle Nigel
    Vito Guest
    354 pounds DRY according to advertisements which are always optimistic. Have
    you actually weighed your bike? How about Greek's Kawasaki?
    IIRC a TZ weighs some 170# wet. I'll stick to my statement.
    Vito, Jan 11, 2006
  7. Wicked Uncle Nigel
    A 600ujm doesn't weigh over 400lb. Have a look at the specs and then
    come to terms with reality.
    Utter bollocks. Have another look at the specs for the litre class and
    you'll see they've changed dramatically in the last 5 years.
    Bwahahaha. Get fucking real.
    I don't think Kenny Roberts was World Champion in the 125, 250, 500
    and MGP classes. In fact Rossi is the only person to hold have managed
    that feat so how does Kenny Roberts manage to have won a greater
    variety of races? You can even add Snr & Jr versions of KR together
    and you won't beat Rossi's titles.
    Andy Bonwick, Jan 11, 2006
  8. Wicked Uncle Nigel
    Bollocks. You're backtracking because you're wrong.
  9. Wicked Uncle Nigel
    Vito Guest
    Sorry, I'm used to the bikes raced here that are not limited by artificial
    rules. The last TZ I actually saw weighed on a scale was a TZ- 250D with an
    aftermarket Brit aluminum frame and wheels. IIRC it weighed 170 wet - with fuel
    ready to race. I must assume that it would be easy to make one even lighter
    today.
    In any event niggling over 24# does not change the point - a 600 is far too
    heavy to handle like a TZ.
    Vito, Jan 11, 2006
  10. Wicked Uncle Nigel
    Because aluminium is more prone to stress fractures.
    Why am I telling you when you already knew that? It's that thick ****
    Vito who needs educating.
  11. Wicked Uncle Nigel
    A lot of steering dampers aren't even attached to the frame so how the
    **** they can damp anything bar the steering I don't know.
  12. Wicked Uncle Nigel
    Vito Guest
    Hmmm ... that may enable them to turn comparable lap times despite the handling
    disadvantage?
    Your Kawasaki has all these things??
    I do not owe you an education. If you wish to fantisize that your 600 handles
    just like a real racer be my guest. I don't argue with NASCAR fans who think
    their cars are just like the ones on the track, nor with Jesus freaks who think
    the rapture is coming any day now. Like I said, I had similar illusions when I
    was about 7 years old.
    Vito, Jan 11, 2006
  13. Wicked Uncle Nigel
    Vito Guest
    Personal attack is the last refuge of those living in fantasy land when faced
    with irrefutable truth.
    Vito, Jan 11, 2006
  14. Wicked Uncle Nigel
    Vito Guest
    That too Robert. But a roadracer doesn't expect any such bumps.
    Vito, Jan 11, 2006
  15. Wicked Uncle Nigel
    WavyDavy Guest
    You dopey ****.
    Read the fucking sig. The 4-stroke *is* my tourer.
    So not only are you delusional about your knowledge of physics, metallurgy
    and motorcycles, you can't read, either........
    WavyDavy, Jan 11, 2006
  16. Right, you said: "AFAIK the 750 Suzi was unique in that it had a
    car-like pump injecting oil directly into the crank and thence to the
    bearings just like a 4-stroke (the difference being it was 'total loss'
    like the old bikes). I never, ever heard of one failing but that doesn't
    say it never happened of course. Other 2-strokes, including Suzi's
    smaller bikes simply injected oil into the inlet air stream an were
    indeed less reliable. The context was that 2-strokes can be made as
    reliable as 4-strokes."
    And the oiling system was *not* similar to a four-stroke's either, you
    mental defective.
    From this, and your use of the phrase "the context" it is reasonable to
    infer that you were crediting at least most of Suzuki's reliability to
    its (you thought) unique oiling system.
    This was simply incorrect. It was *not* unique. This has now been proven
    to you, and I note that you studiously ignored the evidence, which makes
    you look something of a plonker.
    Your statement that there were only three touring bikes worth a light
    has now been qualified to include Harleys, Gold Wings and further
    qualified to include only machines sold in the US, and *further*
    qualified to exclude Guzzis because they didn't have enough dealers for
    you. And you ignored the reference to the Z1.
    This also makes you look a plonker.
    When you are *wrong* on usenet, it's best to fess up, and everyone moves
    on. Instead, you've dug yourself a massive hole in front of a global
    audience. Which is amusing to see.
    Just one question - do you now accept your claim that the GT750's oiling
    system was unique to be nonsense?
    The Older Gentleman, Jan 11, 2006
  17. You know that, I know that, everyone knows that, except Ryvita[1] whose
    ignorance is simply serving as group amusement.
    [1] "He takes the biscuit"
  18. Wicked Uncle Nigel
    Vito Guest
    Oh .... OK
    Vito, Jan 11, 2006
  19. Wicked Uncle Nigel
    Ben Guest
    My bike weighs around 400 lbs wet.
    And it's got 160bhp.
    Ben, Jan 11, 2006
  20. Wicked Uncle Nigel
    Hank Guest
    In previous posts, Vito informed us that bu$h's illegal
    and immoral terror attack on the people of Iraq wasn't
    motivated by Iraq's vast oil reserves, and that the bu$h
    regime hasn't tortured anyone.
    For his sake, I hope he's just trolling...
    http://www.physics.byu.edu/research/energy/htm7.html
    Ever wonder who benefits from the 150 MILLION
    U.S. taxpayer dollars spent each DAY in Iraq?
    http://www.commondreams.org/views04/0223-08.htm
    http://www.corpwatch.org/article.php?list=type&type=21
    "They are waging a campaign of murder and destruction. And
    there is no limit to the innocent lives they are willing to
    take... men with blind hatred and armed with lethal weapons
    who are capable of any atrocity... they respect no laws of
    warfare or morality."
    -bu$h describing his own illegal invasion of Iraq.
    http://www.robert-fisk.com/iraqwarvictims_mar2003.htm
    Hank, Jan 11, 2006
