Re: Harley Davidson Dyna ride height
Discussion in 'UK Motorcycles' started by Wicked Uncle Nigel, Dec 10, 2005.
  1. Wicked Uncle Nigel
    Vito Guest
    By the riders who did a lot of cross-country tours.
    Name them then. Only one comes to mind: Harley Davidson. The smaller jap bikes
    were too uncomfortable and could carry too little baggage and the Brits were too
    unreliable. Oops, I forgot - to y'all "cross country" means 200 miles.
    No it was not - at least not here in the states. The smaller Suzis injected oil
    into the air stream just behind the carbs.
    When did I attribute its reliability ENTIRELY to its oil pump. Are you claiming
    that injecting oil (vs premix) onto the bearings had no effect on reliability?
    Pure conjecture.
    I'll take that as a compliment coming from a man foolish enough to ride a 1200
    Trophy.
    Vito, Jan 10, 2006
  2. Wicked Uncle Nigel
    Vito Guest
    Sorry, I thot you had been riding for a few years and had perchance experienced
    a tank slapper or two. If you had you would know that a steering damper is
    intended to dissipate the energies that lead to them before they become
    dangerous. Now where do you think these oscillations come from? Hint: a spring
    will oscillate unless it is damped. What spring does a steering damper damp?
    Vito, Jan 10, 2006
  3. Wicked Uncle Nigel
    Vito Guest
    The metalurgists tell me otherwise.
    Vito, Jan 10, 2006
  4. Wicked Uncle Nigel
    Vito Guest
    Jeeze, how to explain even the simplest most obvious concept to a man who cannot
    comprehend what he reads?? I never said that a damper "alters frame rigidity".
    That is a inherent function of design and materials. I said that a frame has
    some springiness - an irrefutable fact. The amount also depends on design and
    materials.
    Vito, Jan 10, 2006
  5. Wicked Uncle Nigel
    WavyDavy Guest
    <snip>
    You are now (or rather have been for some time) getting very dull.
    You obviously have *some* knowledge but please, for the sake of everyone
    else, keep it to yourself from now on 'cos you don't have enough knowledge
    and it's just not funny seeing how you twist and turn in your many and
    varied vain attempts to try to prove you are the only one who can ever be
    right.
    Give up.
    Get a distraction or a hobby.
    I dunno, invade a small country or something.
    Just please stop being so aloof, sanctimonious and dull.
    Thank you.
    WavyDavy, Jan 10, 2006
  6. Wicked Uncle Nigel
    Mups Guest
    A steering damper does what it says on the tin. A damps oscillations in the
    steering not in the frame. It can't damp oscillations in the frame because
    its only attached to the frame at one point. It might reduce the effects of
    frame flex but it doesn't and cannot stop the frame from flexing.
    Mups, Jan 10, 2006
  7. Wicked Uncle Nigel
    Ben Guest
    Ben, Jan 10, 2006
  8. Wicked Uncle Nigel
    Ben Guest
    Better let the entire bicycle industry know then.
    Ben, Jan 10, 2006
  9. Wicked Uncle Nigel
    Mups Guest
    No it doesn't, it weighs 102KG[1] which is 224 pounds in English. Even if
    you could get one under 200 pounds it would be below the MotoGP minimum
    weight.
    [1] 2003 model
    Mups, Jan 10, 2006
  10. <snip>
    OK, then. Just about any Japanese bike around 500cc. Honda CB450, Honda
    CB500 Four, Honda CB550 Four. Suzuki GT550. Yamaha XS650. God knows how
    many Moto Guzzis - T3, California, Le Mans, Spada. Laverda Jota, Mirage.
    And let's not forget one of the greatest - the Kawasaki Z1 and its
    derivatives.
    I will agree with your generalisation about Brit Bikes.
    NO THEY FUCKING DIDN'T, YOU TWONK! Have a look. Actually, do some
    research instead of posting your nonsense. Virtually all Suzuki
    two-strokes were fitted with this (admittedly excellent) oiling system.
    The triples. The twins. The singles. Shit, I've *owned* most of them. Go
    on, check.
    No, **** it - I'll do it for you.
    http://www.ozebook.com/compendium/t5002.htm
    http://www.vjmw.org/tests/T305_raider.htm
    ""Posi-Force" engine lubrication has been a Suzuki trade-mark for some
    years now, but on the Raider the system takes a step forward efficiency.
    It now is similar to methods introduced on the X-5. Pistons, connecting
    rod small ends, and cylinder walls. now are provided with a separate
    supply of lubricant. Previously, these components had to rely on oil
    thrown upward from the crankcases The engine-driven oil pump - which
    also is mated to throttle opening - delivers oil through a pair of
    tubes, each of which divides into two. Thus, two pipes divert to the
    left side of the engine, and two to the right side."
    This is talking about the 250cc and 305cc twins that pre-dated the GT75-
    by some years.
    No, I'm not, You are, and you've implied it was the only reason for its
    reliability. I suggest that a very mild specific power output - and the
    benefits of water cooling - were rather more effective. If you note, I
    have always praised Suzuki's two-stroke oiling system. You will also
    note that O have pointed out it was fitted to many other, less
    reliable, Suzukis. *And it was*.
    No. Simple fact. You increase power, and you lose longevity and
    reliability. Take this to its logical extreme - Formula One race engines
    go like dingbats, and are as tough as they can make them, but still need
    rebuilds every race. OK?
    Ah, yeah, right.
    The Older Gentleman, Jan 10, 2006
  11. Succinct and to the point.
    Saves me posting it.
    The man's an imbecile. Thinks the Suzuki GT750 was the only Suzuki
    two-stroke with forced lube to the crank....
  12. Nope. The new R6 weighs about 110 pounds more. On a streetbike which
    can be cut down further when you remove the fluff. With nearly double
    the power output.
    Read:
    I am an ignorant old fool who knows not what they speak.
    Fly-by-wire throttle, pressure cast aluminum frames, USD forks, radial
    brakes, fuel injection, the list goes on... all within the last five
    years.
    Typically, roughly, blahblahblah...
    You've never once weighed the components therefore are talking out of
    your ignorant ass again.
    I want actual specs. Head weight of the TZ racer vs. the assembly off
    a latemodel supersport. Chop chop!
    No, the context was your estimations of 4-strokes. Which have been
    proven to be heresay, secondhand info from others and no direct
    experience whatsoever save for an outdated motorcycle over a decade
    old.
    I think Rayvan, our resident Harlie queen has more useful input on
    what supersports are capable of than yourself.
    Greek Shipping Magnets, Jan 10, 2006
  13. <snip nicely scientific explanation I couldn't hope to equal>
    Now sod off, Vito, and come back when you've learned something....
  14. The spring in your head, by the sound of it.
    Grimly Curmudgeon, Jan 10, 2006
  15. Wicked Uncle Nigel
    mb Guest
    Then they're wrong. Why do you think we don't see springs made from
    aluminium?
    mb, Jan 10, 2006
  16. Blast. Ginged. Oh well, I'll let my posting stand ;-)
    The Older Gentleman, Jan 11, 2006
  17. He's a worthy successor to the late lamented Hoyt McKagen[1], IMHO -
    some knowledge, but completely overwhelemed by his ignorance and, as you
    say, arrogance.
    [1] aka The Carbon King
  18. You're pretty corect in the latter.
    Quite a few bikes had them fitted as standard, though - like a lot of
    BMWs. Some early Guzzis.
    Kawasaki's 750H2 two-wtroke triple, one of the most, erm, abrupt
    motorcycles of all time, came from the factory with *two*.
  19. Wicked Uncle Nigel
    Please tell me it hasn't really taken you this long to work that out?
    I mean, it was fairly obvious weeks ago, and I cannot for the life of
    me see why you're bothering to argue with him.
    _______
    \`\ | /`/ GSX-R1000K3
    Ace, Jan 11, 2006
  20. Wicked Uncle Nigel
    Vito Guest
    Not over here. Altho they were fine commuter bikes the smaller Japs were never
    popular with the 1000 in 1 crowd because they lacked the power to push a Vetter
    fairing and tote luggage. Guzzi also made good bikes but had too little dealer
    support - a problem they still have here. Even the CB750s fell out of use with
    the advent of the Gold Wing and BMW had to copy the 'wing to stay in business.
    Americans rightly or wrongly prefer huge machines for touring.
    On the contrary. I replied to a poster who claimed that 2-strokes were
    inherently unreliable by citing Suzi's 750 Water Buffalo as a very reliable bike
    with oiling similar to a 4-stroke. Obviously that is not the only reason. I'm
    sorry you inferred otherwise.
    OTOH my wife's TZ-125 made 45HP at the rear wheel. An equivalent 750 would make
    270HP! Yet I only replaced rings every other race weekend and pistons every 2
    or 3 ring jobs. The lower ends never *needed* replacement altho I usually did
    so every other season. And this was essentially 1970's technology and
    metalurgy - ie when 100,000 miles was considered worn out on a car or bike. So,
    with modern lube and development I believe that Suzi's 750 could be making say
    150 HP in a 250# bike that handled like a TZ-250. That what started this all
    Vito, Jan 11, 2006
