RD400E buying advice, anyone - Lozzo?
Discussion in 'Classic Motorbikes' started by Timo @ work, Apr 16, 2004.
  1. Timo @ work
    Timo @ work Guest
    Yes, it'll go bang at some point but that can be said of just about
    any vehicle^W^Wanything I own. Anyway, I've stumbled over an ad for a
    400E for very reasonable money so I might well have a look at it
    later.
    Anything that's 400 specific? I was under the impression that they're
    the most robust of the aircooled RDs...
  2. Timo @ work
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, "Timo @ work"
    My first suggestion is: have a whip-round.
    There's people who'll pay good money to see you own an RD400...
    Nigel Eaton, Apr 16, 2004
  3. Timo @ work
    I imagine the betting will be a bit one-sided though...
    Ace, Apr 16, 2004
  4. Timo @ work
    Steve Parry Guest
    In
    weeks ... days .... hours ... minutes ... .even seconds of use?
    Steve Parry
    http://www.gwynfryn.co.uk
    K100RS SE
    F650
    (not forgetting the SK90PY)
    Steve Parry, Apr 16, 2004
  5. Timo @ work
    WorkTOG Guest
    <fx: holds head in hands>
    Timo! NOOOOOOOOOOO!
    WorkTOG, Apr 16, 2004
  6. Timo @ work
    Timo @ work Guest
    The real question is of course - will it survive the test ride? Or
    will it break down within minutes of me phoning the current owner?
  7. Timo @ work
    Timo @ work Guest
    I think the breakdown people might not be on that list...
    <thinks>
    Hmm. Monthly short column in Classic & Motorcycle Mechanics detailing
    the previous month's breakdowns with special attention to "funny, I've
    never seen any of these go wrong"-type failures?
  8. Timo @ work
    Timo @ work says...
    Timo......DON'T, just DON'T!
    Lozzo, Apr 16, 2004
  9. Timo @ work
    Lozzo was seen penning the following ode to ... whatever:
    Right, that's two 'nays' from sensible people and one 'yay' for the
    sheer amusement value.
    <goes off looking for a C90>
    Timo Geusch, Apr 16, 2004
  10. (MCN 21 April 2004)
    "Honda's longest-running and top-selling bike, the immortal C90
    stepthru, is subject to a worldwide recall.
    Honda UK say they are not entirely sure of what is causing the problem,
    which so far has seen thousands of C90s, of all ages and models, explode
    into thousands of tiny pieces.
    "It were terrible," said plumber Ernie Grunge, aged 176. "One moment I
    were riding along, like, on me way to the Flangefeelers Social Club, and
    the next, I were sitting on me arse in middle of t'road while bits of
    bloody 'Onda fell about me ears.
    "Funny thing were, they landed in t'road, and clearly spelled out
    letters. but Ah've nay blinking idea what a bloody Timo is."
    In Asia, it has been reported that C90s have been refusing to start for
    absolutely no apparent reason. In Germany, Europe's biggest motorcycle
    market, there have been accounts of commuters refusing to ride their
    C90s after Adolf Titzhandler, a retired lederhosen maker, watched as his
    C90 took off by itself and, accoprding to onlookers, committed
    mechanical suicide by burying itself in the side of an old Alfa Romeo
    75.
    Honda technical staff say they are baffled, but they have plotted all
    cases of exploding C90s on a giant map, and say that they form a perfect
    circle whose centre appears to be a street in North London...."
    The Older Gentleman, Apr 16, 2004
  11. Timo @ work
    The Older Gentleman was seen penning the following ode to ... whatever:
    ROFL
    <wipes tears from eyes>
    This is so beautiful I had to print it out. Thanks mate, I really
    needed this kind of distraction from my current attempts as screwing
    up my life completely.
  12. IME:
    Ensure engine, exhausts, air filters are either standard or proper
    replacements/modifications properly fitted. Improper carburation makes
    them explode.
    Ensure the crank doesn't wobble up and down where the points are fitted.
    This throws the timing off and makes them explode.
    There are probably other things which make them explode but those are the
    ones I have found. Oh hang on, yes, trying to ride it slowly. It only
    works between 6-8000 rpm. Too much use out of that range turns the petrol
    into heat instead of power and makes it explode.
    I had one with K&N filters, bodged exhausts and shagged mains and it was
    constantly exploding. My friend had one which was completely standard with
    good main bearings and it never did. It wasn't any slower either and
    was much nicer than mine. She doesn't have it any more but she knows the
    person who does and I believe it is still running. And it does get used:)
    They are, however, great fun when they're not exploding. Better than
    the 350LC IMO. The same friend used to have a YPVS LC too, and I found
    that rather bland and uninspiring although obviously it was faster and
    better suspended. The power band makes them feel faster than they really
    are and they're so light that the crap chassis doesn't matter over much.
    Mine used to handle fine with 1/4" sideways movement at the back wheel and
    some shocks off an R80 fitted (with a hammer. After they wouldn't hold the
    R80 up adequately any more).
    But all in all the advice to run away sounds the most sound to me, given
    the reputation you appear to have. These are not reliable machines. They
    are easy to work on though. Very simple. When they explode, you can get
    them running again fairly quickly in most cases. In mine, the first three
    times IIRC. The fourth time the explosion took a bit of crankcase and
    barrel with it and was a bit fatal; the piston didn't co-operate, instead
    of melting it disintegrated and sprayed bits of itself liberally
    throughout the engine.
    Electrics aren't over hot either. The only peice of RD400 I still possess
    is the doorstop in this room, which started life as an RD400 alternator.
    It is an excellent doorstop I must say.
    At one time I was using the RD to get to work, but I had to give this up
    as it was threatening my job security. Managers don't wear "it's not my
    fault I'm late, the bike did xyz" more than once a week. I bought a
    CB250N. I kept the RD for weekends of course.
    Regards, Ian
    Ian Northeast, Apr 16, 2004
  13. Timo @ work
    Fr Jack Guest
    The varlet known as The Older Gentleman did proclaim to all assembled:
    ROFLMAO&PMP!!!!
    You owe me a new keyboard, monitor and bottle of Hobgoblin, you bugger!
    Fr Jack, Apr 16, 2004
