RD400 to IOM
Discussion in 'Classic Motorbikes' started by Hog, Jan 29, 2007.
  1. Hog
    Dustbin fairing.
    platypus
    "Merely corroborative detail, intended to
    give artistic verisimilitude to an otherwise
    bald and unconvincing narrative."
    platypus, Jan 30, 2007
  2. Using the patented Mavis Beacon "Hunt&Peck" Technique, Lozzo
    The prosecution presents exhibits one through twenty-nine. M'lud, you
    will observe these are all RD400 logbooks.
    We ask for the harshest possible treatment of the defendant.
    Wicked Uncle Nigel - Podium Placed Ducati Race Engineer as featured in
    Performance Bikes and Fast Bikes
    Wicked Uncle Nigel, Jan 30, 2007
  3. Using the patented Mavis Beacon "Hunt&Peck" Technique, platypus
    *Unmounted* dustbin fairing. Dance, boy, dance!
  4. Hog
    Wicked Uncle Nigel says...
    I have nothing to say in my defence, I couldn't hear the charges through
    this darned tinitus.
    It's ok, I've ridden two of them already.
    Lozzo, Jan 30, 2007
  5. Hog
    Mounting is overrated. I'm retaining flexibility of application, and
    waiting for the right bike.
    platypus
  6. Hog
    Pete M Guest
    In
    The later Vauxhall Novas used to have a worrying fault where if you removed
    the hazard light switch, turned it upside down and "switched on" the Hazards
    the ignition would come to life.
    Luckily, that has quite often had the happy side effect of removing quite a
    few Novas and "joyriders" from existance simultaneously after a few miles.
    Pete M - Using the Scouse Side of the Force -
    Golf GTi,
    Mercedes 190E Auto
    OMF#9
    Ok, I admit it, I like Renault 5s.
    Pete M, Jan 30, 2007
  7. Hog
    Excellent!
    Hog, Jan 30, 2007
  8. Hog
    No and I had forgotten it too until you reminded me in Flitwick.
    Hog, Jan 30, 2007
  9. Hog
    Heh.
    I had actually gotten it into my head that it was a C while it
    languished with WUN, **** knows why. One can't really miss the seat
    nacelle. I bought a D because mine was a D and I bought it in the same
    year as this one is registered. Of course my original wasn't yellow,
    tastes improve over time.
    Hog, Jan 30, 2007
  10. Hog
    So what are you going to come over on WUN?
    Hog, Jan 30, 2007
  11. Hog
    So presumably the switch was supposed (when fitted normally) to break
    the main loom power connection to the indicator switches, thus
    preventing power from flowing back up through the indicator switches
    to the main loom and powering the car without a key. It's the only
    reason I can see for plumbing main loom power (or the relay
    excitation, anyway) to the hazard switch.
    In other words, it was designed to prevent the very security problem
    that reversing the switch got round.
    They could have simply put an isolating relay onto the main loom or a
    separate set of contacts onto the ignition lock for the indicators.
    Pip Luscher, Jan 30, 2007
  12. Using the patented Mavis Beacon "Hunt&Peck" Technique, Hog
    Haven't quite decided. Head says "Pan", heart says "V-Max".
  13. Hog
    Pete M Guest
    In
    Something like that, yep. I always just thought they'd cocked up with the
    permanant live for the hazards.
    Almost every Nova GSi ended up with an expensive immobiliser system just
    because the hazard light problem made them so easy to steal they were
    uninsurable.
    Golf GTi,
    Mercedes 190E Auto
    OMF#9
  14. Hog
    Hog suggests Oilfield
    Hog, Jan 30, 2007
  15. I reckon you should take the basmati rice-burner.
    Austin Shackles, Jan 30, 2007
  16. Hog
    Oh look. Like my DG heads weren't sexy enough
    YAMAHA RD 400 FAHRON Item number: 160079988116
    Hog, Jan 30, 2007
  17. Using the patented Mavis Beacon "Hunt&Peck" Technique, Austin Shackles
    What is this, a fucking conspiracy?
    No chance.
  18. Hog
    Conspiracy? don't be silly
    <calls sharon>
    Hog, Jan 30, 2007
  19. Hog
    Hog says...
    Oh you ****. I had a Fahron kit that I sold, a new one complete with rad
    and everything required.
    I really do have a medical need for another RD400, a 'how I would have
    built one had I been wealthy enough in the late 70's' style one. Fahron
    top end, TZ 'E' frame, Campagnolo wheels, Gibson pipes, Lockheed brakes
    etc etc.
    Failing that, an RD400 bottom end with the top end from a 350 LC can
    easily be done. Gives 430cc and is dead reliable. You just need the
    waterpump/clutch casing from an early TZ350.
    Lozzo, Jan 30, 2007
  20. Hog
    TOG Guest
    It would be worth buying that basket case, and then clagging the bits
    onto a decent RD400 acquired from another auction.
    TOG, Jan 30, 2007
