[RBR] Wales, in a day and a half. (Long)
Discussion in 'UK Motorcycles' started by SD, Aug 29, 2006.
  1. SD
    Can't you fit him into both categories?
    platypus, Aug 29, 2006
  2. SD
    SD Guest
    The buffet service on the Wing was more than adequate over the
    weekend. Apart from the humbugs.
    | ___ Salad Dodger
    |_\_____/_| ..83466../..22358.../..31893.
    '^' RBR Clues: 52 Pts:1005 Miles:3416
    SD, Aug 29, 2006
  3. SD
    Bah. I managed to assault the battery on Monday, and went home by other
    means.
  4. SD
    SD Guest
    I heard. Diagnosis pending?
    When mine played up - it turned out to be shitty connections at the
    battery terminals.
    Well, I cleaned them up, and it's been faultless for a year since.
    | ___ Salad Dodger
    SD, Aug 29, 2006
  5. SD
    We got an AA man to jumpstart it. It ticked over for a couple of minutes
    and then died. He restarted it and checked the voltage while I revved it.
    Steady 8v was what it looked like. I would have preferred a charge.
    Anyway, the battery is currently hooked up to the electron infuser. I'd
    have had a go this evening, but I got home from work quite late.
    I fucking hope it's just dirty terminals.
  6. SD
    SD Guest
    so do I, cos that sounds like the CBX on the way back from Chimay.
    | ___ Salad Dodger
    SD, Aug 29, 2006
  7. SD
    You can probably remove the alternator on the CBX without removing the
    engine.
  8. SD
    SD Guest
    You can on a proper Wing, too.
    | ___ Salad Dodger
    SD, Aug 29, 2006
  9. SD
    May all your pingfuckits fall down your camchain tunnel.
    platypus, Aug 30, 2006
  10. SD
    SD Guest
    Camchain? Wossat, then.
    Ta for reminding me, the cambelts need changing in another 16500
    miles.
    | ___ Salad Dodger
    SD, Aug 30, 2006
  11. Honda Civic (IIRC) use the same belt.
    Get 2 of them cos them is half the price.
    Check the prat number tho...
    Mr Alun Davies, Aug 30, 2006
  12. Hmmm, if I could get it in the shed I'd keep it.
    Erk and more erk
    I leave *that* habit to other more qualified people of this NG like DFVs and
    the resident Gays...
    You're a star.
    If you still have my mobile number txt me to let me know when and I'll
    ensure the kettle is on and I'm in.
    Otherwise deposit it in the tin box at the rear between the two cottages.
    Many thanks
  13. SD
    I'm talking about your CBX, which has a camchain tunnel and a
    pingfuckit-rich top end.
    I probably ought to inspect mine sometime.
  14. SD
    Scraggy Guest
    SD wrote:
    snip
    Two things really;
    1.Rain, in pockets, *on a Wing!* How's that work then?
    2. I know we had a converstion 'bout phones, but in the spririt of improving
    Sirs communication experience, phone numbers programmed into a phone tend
    not to go the way of Humbugs[1] & paper.
    [1] Bah
    Maybe next time mate.
    Scraggy, Aug 30, 2006
  15. SD
    SD Guest
    It was *very wet* and I was going all slow and everything.
    Two things I noticed:
    1. there's a footpath up the side of the A5 - I couldn't see it at
    night - I don't know how close I must have come to clipping the kerb
    2. The screen on the Wing "lights up" from underneath - I suppose
    stray light from the headlamps catches the perspex "edge-on", iyswim -
    it was like sitting behind a giant HUD, with no data on it.
    Oh, they are in the 'phone *now*.
    | ___ Salad Dodger
    SD, Aug 30, 2006
  16. SD
    zymurgy Guest
    Camchain, I wish. I've been told the primary chain is on its way out on
    the FJ :-(
    Andy, how long has it rattled for ? 'da man' reckons it should rattle
    for another 20K miles or so !
    P.
    zymurgy, Aug 31, 2006
