rattles when hot cbr600 1987
Discussion in 'Motorbike Technical Discussion' started by David, Apr 19, 2004.
  1. David
    David Guest
    Has anyone else had a problem with these bikes rattling for 20-30
    sec's if started with a hot engine.
    The engine sounds pretty smooth when started from cold, but if I
    stop the engine briefly mid journey I get this noise for a short time.
    Could this be the camchain tensioner problem I've heard these bikes
    suffer from?
    cbr600fh 30,000 miles
    Thanks David
    David, Apr 19, 2004
  2. Yes
    The Older Gentleman, Apr 19, 2004
  3. David
    David Guest
    Yes
    Yes
    [/QUOTE]
    And is it just a case of unbolting the old tensioner and fitting the
    new one, or is there more to it than that? I mean does it need to be
    primed with engine oil first.
    Thx David
    David, Apr 19, 2004
  4. Yes
  5. David
    Slikboy Guest
    Hey Dave.
    You can buy manual cam chain tensioners from APE. They replace the
    hydraulic one that comes from Honda. They simply swap in and then you
    tighten them to remove the noise. It seems weird that the cam chain would
    only rattle when hot. Mine rattles when cold.
    Jim
    Slikboy, Apr 22, 2004
  6. David
    Brenda Rees Guest
    Yeah, thats what I don't understand, start from cold and it's fine.
    maybe it's the oil thinning out when it gets hot and affecting the
    hydraulic tensioner.
    Thanks David
    Brenda Rees, Apr 23, 2004
