Rant no 4[1]. Spare parts for Velorex sidecar
Discussion in 'UK Motorcycles' started by deadmail, Oct 30, 2007.
  1. deadmail
    deadmail Guest
    So... it's failed the MOT on something around the rear shock. I need to
    remove the shock, cut 2" of 'extension' out of the top mount for the
    shock and then put the correct length shock in.
    Only one problem... I can't find anywhere in the UK that sells Velorex
    parts. F2 motorcycles state that they are the UK Velorex importers and
    were completely useless;
    Can I get a shock for a 562?
    "No, we don't stock them"
    Oh, any ideas where?
    "No".
    So... a bit of googling and I find the American importer. And they're
    happy to ship it to me for (about) 100usd all in.
    So I presume it's produced in the far east, shipped to the Czech
    republic, shipped to the US and then shipped to the UK.
    *sigh* madness.
    [1] No 4 in an interminably long list.
  2. deadmail
    Pete Fisher Guest
    Indeed. They were very helpful when I built the Rotarini. They could
    build one to order if you can be sure of the length, mountings and
    spring strength. The spring will be trickiest so long as it has
    conventional mounting lugs (i.e. bolts through bushes). If you are happy
    with the stiffness of the existing item they may be able to match it.
    "Made To Order Shocks
    We can manufacture shock absorbers to your exact specifications if
    required. Provide us with the required open and closed lengths, spring
    rate and damping requirements and the type of end fitments needed. If
    you need help to calculate information such as the required stroke,
    damping etc then please call us and we will be pleased to help. We carry
    all the necessary mounting bushes and fork/loop fittings to provide you
    with a ready to fit product."
    | Pete Fisher at Home: |
    Pete Fisher, Oct 30, 2007
  3. deadmail
    Can it be done manually - what's the exact reason for failure?
    sweller, Oct 30, 2007
  4. deadmail
    Hagon will make stuff up to order IIRC
    Hog, Oct 30, 2007
  5. Try Mick Berrill.
    The Older Gentleman, Oct 30, 2007
  6. deadmail
    Try Mick Berrill.[/QUOTE]
    If he's still in Northampton then underground railway is the way
    forward.
    Andy Bonwick, Oct 30, 2007
  7. deadmail
    Pete M Guest
    Accompanied by the sound of a chisel on slate
    I'll be in the Czech Rep in January and would be happy to pick up whatever
    bits, but I suspect that'll be too late.
    Pete M - OMF#9
    "Save your breath for cooling your porridge!
    W&P Range Rover V8 Turbo
    Scorpio Ultima 24v
    Tatra 805
    Pete M, Oct 30, 2007
  8. deadmail
    deadmail Guest
    message
    I tried him for spokes and they weren't that helpful. Anyway, I've
    committed to $88 plus postage with Velorex USA.
    You know, what I like about dealing with American companies is that they
    actually *want* your business, unlike UK ones.
  9. deadmail
    deadmail Guest
    The exact reason is "Nearside outer rear Sidecar Suspension fouling
    [5/2/2]". With more than about 100lbs in the sidecar (guess)the
    suspension is completely locked up.
    Anyway, this will drop the sidecar by about 2" which will help with
    sharp downhill left hand corners which are a bit scary at the moment.
  10. That sounds a decent deal.
    So true.
    The Older Gentleman, Oct 31, 2007
  11. deadmail
    Not all of them. I've dealt with many over the past year whilst trying
    to source Corvette parts, & have found both extremes. Vette Brakes &
    Products in Tampa have been an absolute delight, & went *way* beyond
    the call of duty to help me get parts as cheaply as possible. Ecklers
    otoh have top place on my list of companies never to deal with again -
    even above a certain NI visor dealer.
    Krusty
    www.MuddyStuff.co.uk
    Off-Road Classifieds
    Krusty, Oct 31, 2007
  12. deadmail
    ivan.ardon Guest
    Do they still have that grumpy old cow answering the phone? Gawdawful
    she was/is.
    fboab
    ivan.ardon, Oct 31, 2007
  13. deadmail
    says...
    You've never called Rick Stringer Motorcycles in Bedford then? Give it a
    go and see what you think.
    Lozzo
    Triumph Daytona 955i SE
    Suzuki SV650 K3
    Honda CBR600 F-W
    Suzuki GSX-R750L
    Yamaha SR250 SpazzTrakka
    Lozzo, Oct 31, 2007
