Got the bits for the Bantam so time to put it back together. This should be in a FAQ. <rant> Why is it that DIY mechanics like to pry engines apart with a bloody screwdriver ?. Listen up you bunch of cupid stunts To disassemble an engine READ THE BLOODY INSTRUCTIONS. After removing the necessary bolts and screws it should come apart easily with a GENTLE tap from a RUBBER hammer. If it does not come apart you are doing something wrong. NEVER EVER under any circumstances try to pry it open. The crankcase halfs and most covers have specially flat mating surfaces and if you damage them the bloody thing will never hold oil again. Stop messing around and give the bloody job to a professional before you fuck it up. </rant> Goes back to flatplate and plastic metal. Another bodge job.
