Rake and ruin.
Discussion in 'Australian Motorcycles' started by Knobdoodle, Jan 4, 2009.
  1. Knobdoodle
    Folks,
    I can't get my Trump to turn in tight corners. It seems to be a great
    swooping affair that sees me run out over the white line more often than not
    and also sees me dragging my toes on the tarmac.
    I've jacked the ride height up to the max at the back and dropped the forks
    through the triple-clamps 17mm (the maximum) at the front to try and get
    maximum ground-clearance.
    Should I have gone the other way at the front? Should I have dropped the
    triple-clamps on the forks to steepen the rake? That'll make it turn
    quicker but will the leant-over ground-clearance be worse?
    What's the theory here? IK?
    Thanks ..... Clem
  2. Knobdoodle
    Sounds like you've turned it into a cruiser! Will the sidestand still
    hold it up, or do you need to put a block of wood under the foot to
    stop it falling over? ;-)
    Seriously, I'd have tried dropping the triple clamps maybe 5-10mm and
    maybe using a different foot position on the pegs. Or possibly riding
    a bit slower. ;-)
    BT Humble, Jan 4, 2009
  3. Knobdoodle
    a bit slower. ;-)
    Bike leans over a bit on sidestand but not dramatically so.
    Try as I might I can't get my left foot onto tippy-toes while riding and
    changing gears. (I've got a 2" shortened boot from turn-2 of a ride-day at
    Eastern-Creek 12 years ago to show this isn't a recent problem!)
    I think a set of rear-sets from a Daytona/Speed-triple would get my foot
    higher and further-back while still in touch with the gear-lever though.
    (It's the moving back and forth that kills me)
    I think I'll try the original 17mm-lower triple-clamps position.
  4. Knobdoodle
    jl Guest
    Understeer (running wide) indicates you need to steepen the rake. I
    always get confused with the wording of what people mean when
    specifiying it- so to steepen rake you move the triple clamp down the
    forks towards the dirt. AKA moving the forks up through the triple
    clamp. Yes you'll lose a smidgen of ground clearance but on most bikes
    it should be neither here nor there.
    The running out of ground clearance is quite possibly slow turn in
    causing you to need more lean angle by the time you get it tipped in -
    again fixing the rake will help there.
    The only other thing to consider is whether the springs are stuffed /
    shock is shot / no oil in forks etc - deceased suspension will give you
    a wallowy ride and bottom in the corners. If not you might want to
    consider upping the spring rate - is it pogo-ey ? How far is your static
    sag and loaded sag ?
    JL
    jl, Jan 4, 2009
  5. Knobdoodle
    smack Guest
    lose some fucken weight you fat ****, always blaming the bike..... :p
    pssst, try the correct pressure in the tyres
    smack, Jan 4, 2009
  6. Knobdoodle
    CrazyCam Guest
    Bloody 'ell, you are a hard man to please.
    Can't you just be happy the thing goes at all? :)
    Jacking up the back end is good, jacking up the front, isn't.
    You might try sliding the fork tubes up through the triple clamps to
    improve the bike's turning in abilities.
    As for the toe dragging on the tarmac, what worked for my Street Triple
    was fitting the peg mounting assembly from a Daytona 675. Perhaps there
    is a Triumph similar enough to yours, which might have higher set pegs?
    regards,
    CrazyCam
    CrazyCam, Jan 4, 2009
  7. Raise the back, lower the front and learn to hang off a little, not quite
    Stoner Style where you need elbow sliders, just a little, enough to make you
    look like a wannabe.
    Bum crack on the seat edge, loose a little weight, buy another pair of boots
    and wahallah problem solved.....maybe
    Capt. A. L.
    Capt.about_lunchtime, Jan 5, 2009
  8. Knobdoodle
    Boxer Guest
    Just come over some time and I will give you some riding lessons.
    Boxer
    Boxer, Jan 5, 2009
  9. In aus.motorcycles on Mon, 05 Jan 2009 04:17:50 GMT
    First Gerry, now you. Can't complain you aren't getting any Clem!
    Zebee
    Zebee Johnstone, Jan 5, 2009
  10. Knobdoodle
    knobdoodle Guest
    [clouds part] I think you're right JL!
    This is the bit that was eluding me as I was thinking of the corner as
    being a constant-radius arc when in reality it's an ellipse as I'm
    blowing the entry and then having to pull the bike down mid-corner to
    stay on the road (and running out of ground-clearance in the process).
    Another drink I owe you.
    knobdoodle, Jan 5, 2009
  11. Knobdoodle
    Diogenes Guest
    <splutter/choke/splutter...wipes coffee off monitor>
    A double-ender? Ooooer...
    Onya bike...
    Gerry
    Diogenes, Jan 5, 2009
  12. Knobdoodle
    PostmanPat Guest
    How big must the _rest_ of the seat be?
    Postman W. Pat
    PostmanPat, Jan 5, 2009
  13. How big must the _rest_ of the seat be?
    Postman W. Pat
    A "Buddy Seat" from an early 1950's Harley should almost qualify to be a
    "Racing Seat " for the knobless one
    George W Frost, Jan 5, 2009
  14. Knobdoodle
    I tend to find that your pillion doesn't really like it when you start
    Jean-Phillip Ruggia - style elbow-scraping!
    Knobdoodle, Jan 5, 2009
  15. That'd be the first thing I'd be looking at, too... right after
    setting the forks flush with the top surface of the top triple clamp -
    pulling the front end up on the forks is a pretty radical geometry
    change for a big, long, top-heavy old bus like a T3 Sprint. The usual
    reason to do it is to get weight over the back end to aid traction...
    the last time anyone worth listening to told me about running such a
    setup was in 2005, the last time I spoke to Daron at some length, and
    he talked about setting the TKA ZX-10R-C so it would stop lighting up
    the rear tyre.
    The damping could've departed stage left from the suspension at both
    ends to the extent that turning in and the onset of cornering forces
    sit the bike down far enough for it to deck out.
    intact.kneeslider, Jan 6, 2009
  16. Knobdoodle
    knobdoodle Guest
    Thanks for the advice all (well... most anyway!)
    Just to clarify as there seems to be some confusion about what I have:
    The standard forks sit with the top of the tube protruding 17mm above
    the clip-on on top of the triple-clamp. I haven't really ridden the
    bike like this as I bought it with badly bent forks but I remember my
    other Sprint of 10 years ago which would've had similar geometry.
    When I installed new forks I put the tops flush with the clip-ons thus
    making the bike sit 17mm higher at the front. I did this
    intentionally in an effort to increase the Sprint's atrocious ground
    clearance but have since found that I can't get the thing into tight
    corners.
    By my standards the front suspension is "as new" and I have both the
    damping and preload adjusters on the minimum.
    The rear is not quite as pristine but certainly tolerable by my
    standards.
    The last three bikes I've ridden on these same roads were a 160,000km
    XJ900, a 220,000 km K75 and a 150,000 km R1100GS so I'm used to big
    soft wallowy bikes but the Sprint is behaving in a manner I'm unused
    to.
    Next move is to return the forks to their original position, maybe
    increase the damping at the rear a tad and then persuade gNat to come
    for a ride with me again. (so I can replicate the test conditions).
    Thanks
    Clem
    knobdoodle, Jan 6, 2009
  17. Knobdoodle
    smack Guest
    Not when it's gNats elbows.
    smack, Jan 6, 2009
  18. In aus.motorcycles on Mon, 05 Jan 2009 10:20:07 GMT
    Especially when it's a prelude to knee scraping, shoulder scraping,
    and being scraped off the road.
    Zebee
    Zebee Johnstone, Jan 6, 2009
  19. Knobdoodle
    knobdoodle Guest
    No... gNat seems oddly wary of such things...
    [shrugs] Women!
  20. Knobdoodle
    Yeebok Guest
    You going to (pre) order gNat one of them shirts ? :)
    Yeebok, Jan 6, 2009
