Radiators (central heating type)
Discussion in 'UK Motorcycles' started by rb, Dec 24, 2004.
  1. rb
    rb Guest
    Let's say you removed a radiator for a spot of painting and then when
    you put it back a week or so later you noticed the bleed screw was
    missing, where would you get another one? Would a DIY shed like B&Q
    have them or would you need to go to a plumbers merchants? If you could
    also imagine it's Christmas Eve so you don't really want to be chasing
    around any more than you have to.
    I could be in for a frosty[1] Christmas dinner otherwise.
    [1] YKWIM
    rb, Dec 24, 2004
  2. rb
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, rb
    I think you're going to need to find the original bleed screw, or buy a
    new radiator. I'd be *amazed* if there's any sort of standard for size
    and thread on them.
    BICBW
    Nigel Eaton, Dec 24, 2004
  3. rb
    rb Guest
    I was afraid someone would say that and as it's you I'm even more
    convinced it's time for plan B. Drain the rad in the study and nick the
    screw for the dining room. (And then worry about it all after Chrimbo
    rb, Dec 24, 2004
  4. rb
    _Ginge Guest
    Why not just tap out to the next size up, and use a regular threaded
    allen bolt in the hole?
    Top Bodging.
    _Ginge, Dec 24, 2004
  5. rb
    Buzby Guest
    Wicks - JDAMHIK
    Join the club . . . . . .
    Buzby, Dec 24, 2004
  6. rb
    Did you remove the bleed screw when you were draining the rad to remove it?
    If you did, it's probably on the window sill, or with your tools.
    platypus, Dec 24, 2004
  7. rb
    Nigel Eaton emerged from their own little world to say
    If you live on a legoland estate it's time to visit a noisy neighbour for a
    seasonal greeting. Just have a full bladder before you leave home and take
    a tube of silicon sealant.
    wessie, Dec 24, 2004
  8. rb
    Nigel Eaton Guest
    Good Plan.
    But I did say ICBW, so it might be worth a phone call / trip to your
    local Plumb Centre tomorrow (go early, they'll probably shut at lunch
    time).
  9. rb
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, wessie
    <VBG>
    I likes yer style.
  10. Actualshirley I have a couple sitting in the garage attached to the
    radiators I replaced
    Anywhere near the New Forest?
    Mark
    ZX12R-B1 (Blue)
    CG125 (hers)
    Blata Ninja 3.4
    BOTSWCAW#3
    Mark Derbyshire, Dec 24, 2004
  11. rb
    If you don't want to plunge into the maelstrom of Cribbs Causeway on xmas
    eve, there's a builders merchant in Thornbury that does a lot of plumbing
    kit. GAP Supplies, top end of Eastland Road past the Health Centre, 01454
    412569. They /might just/ be open tomorrow.
  12. rb
    rb Guest
    Keep up, my problem this morning was "Where is the old one?" For
    tomorrow it's "where do I get a new one?"
    The old one could have been rolled up in the old carpet, be out in the
    garden[1], in the garage, or numerous other places. But most likely it
    will turn up when I next get a random tool out and it will then become
    my spare.
    [1] possibly via the dog.
    rb, Dec 24, 2004
  13. rb
    rb Guest
    Excellent, my first port of call before work then.
    I'm really not planning to. At the moment everything is hunky dory as
    the room is finished. She knows the radiator is not on but I've said I
    will do it tomorrow and she is happy with that. Although only a woman
    would think it normal to refill a rad *after* fitting a new carpet but
    there you go.
    rb, Dec 24, 2004
  14. rb
    rb Guest
    I'm not but thanks for the offer.
    rb, Dec 24, 2004
  15. rb
    rb Guest
    Thanks for the tip but I've got to show my face in work anyway and
    Cribbs is only a short hop from Aztec so np.
    rb, Dec 24, 2004
  16. plumb centre will have them , or jayhard
    steve robinson, Dec 24, 2004
  17. rb
    Martin Guest
    try your local dump, they usually have old radiators on them.
    Martin:
    VTR1000 Firestorm
    Martin, Dec 24, 2004
  18. <Shudder>
    Cribbs Causeway - now there's a pointless shopping mall. It doesn't
    even have a bookshop!
    Phil
    Phil Launchbury, Dec 24, 2004
  19. rb
    Andy Hewitt Guest
    Actually there is. You can usually buy all these bits in B&Q Warehouse.
    I got some self bleeding screws for ours in there, and they were only
    about £2 each, all a straight swap.
    Andy Hewitt, Dec 24, 2004
  20. rb
    rb Guest
    Apart from Waterstones in the Mall? And WHSmith perhaps?
    rb, Dec 24, 2004
