Radial tires
Discussion in 'Motorbike Technical Discussion' started by Ted Bennett, Aug 12, 2003.
  1. Ted Bennett
    Ted Bennett Guest
    Many new bikes, especially high performance ones, now have radial-cord
    tires, as cars have for many years now. What advantages accrue, and are
    they less significant than for non-leaning cars?
    If there are real advantages, why has it taken so long?
  2. This is utter, utter rubbish. Radials are *slower* wearing, mph and bhp
    for mph and bhp.
    I think this is utter rubbish too, because when radials first appeared
    they weren't being fitted as OE. The Pirelli MP7 was claimed to be the
    first radial (its plies were set at 80 degrees to the tyre rather than a
    true 90, so it wasn't... quite...) and I attended a factory test day
    where we sampled the tyres on a variety of bikes. This has happened
    since as well.
    I think you're thicker than natural rubber, myself. either that or you
    are confusing bikes with cars.
    Look, car tyre sidewalls are intended to flex. Bike sidewalls aren't,
    because you want the tyre shape to retain its integrity as the bike
    leans on it, or you have some very odd handling and a nasty crash.
    Cross-ply tyres achieve that.
    Radial tyres run cooler, last longer, etc etc etc. The technical trick
    was getting radial tyres on a bike that *didn't* deform their sidewalls.
    It's now been achieved but for this reason they tend to be very low
    profile tyres (as you, obliquely, said) because it's still tricky making
    a radial tyre that doesn't deform.
    The Older Gentleman, Aug 12, 2003
  3. Why? Because he says you're wrong?
    And this you know for a fact, having done exhaustive tests? Don't make
    me laugh.
    Anyone who gets 30k miles from a tyre on a Wing must ride like a nun and
    never get it out of bottom gear.
    Oh, right, so an overheard conversation is the same as technical press
    briefings from (at the last count) three separate tyre manufacturers, is
    it?
    That is a straightforward CYA warning. Nothing like "on no account" or
    anything. Radial tyres were being fitted to bikes not designed for them
    nearly 20 years ago.
    Where I will agree, of course, is the recommendation not to mix x-ply
    and radial on the same vehicle.
    I *do* remember a Pirelli tech briefing in which they said that,
    interestingly, wear rates for radial and x-ply were working out roughly
    similar because the improved characteristics and grip of radial meant
    that people were actually pushing the tyres harder.
    This was at a Pirelli factory radial tyre test day in Italy, in which a
    dozen different motorcycles were served up for our delectation, in
    pairs, one bike being shod with x-ply and its identical twin shod with
    radials, so we could asess the difference.
    But obviously this never happened because Pirelli would never put
    radials on bikes not designed for them.
    The Older Gentleman, Aug 13, 2003
  4. You *are* spitting your dummy, aren't you? Just because somebody told
    you (and not impolitely) that you were spouting nonsense.
    Now two other posters have also told you that you're spouting
    nonsense...
    And like I said, if you're riding a 100+bhp 700lbs+ motorcycle, and you
    get 30,000 miles out of a rear tyre, you are riding it like a nun.
    Quote from Michelin, at a press do: "Any tyre will last forever, if you
    push it along the road with your hand...."
    You're missing the point here and everywhere else: there are very hard
    long-wearing tyres, and there are very soft fast-wearing tyres. Radial
    tyres allow you to use a softer compound than would normally be
    acceptable (in wear terms) because, by their nature, they last longer.
    You're trying to compare sports bikes with Gold Wings. You, sir, are not
    being very bright here.
    Ah, here we go. The old get-out.
    At every press conference I've attended
    Once again you display your ignorance. we were on a race track because
    it is unsafe to do this sort of testing on public roads. The bikes
    available ranged from Kawasaki sports bikes, through BMWs, to large
    Japanese tourers.
    No! You haven't been saying this at all!
    Now you're changing your tack to "touring radials".
    And here I'd agree. Radial development has been mainly done on sports
    bikes. And, yes, it's time the better wear rate of radial tyres was put
    to good use by developing more touring oriented tyres.
    But you have now shifted your position, haven't you? And what became of
    your assertion that radials shouldn't be fitted to bikes designed for
    x-ply?
  5. I bet you he won't be....
  6. Well, yeah, obviously. If you can't find a tyre to fit..... ;-))
    The Older Gentleman, Aug 15, 2003
