Racing gear change - clutchless gear change
Discussion in 'UK Motorcycles' started by Dave Swindell, Aug 13, 2004.
  1. When I bought my XJ900S Diversion I was told that it liked a "racing
    gear change". But never having raced seriously, what is it?
    I tried clutchless gear changing, but somehow the bike wasn't happy with
    it. I've done it from time to time over the years when pushed, or when
    playing, but it was always a bit clunky on older bikes, though with my
    Enfield Bullet it was invaluable when the clutch cable broke (kick-down
    neutral, then clutchless change up to the necessary gear).
    Now back to the Diversion. The gear box was knackered after 75,000
    miles of clutch-enabled gear changing, so I replaced it, and clutchless
    gear changes are now really lovely. It's quite like the mechanical
    pre-selector gear boxes you used to get in cars many decades ago, and it
    even changes down as well.
    But! Is it wise to do clutchless gear changes, even though they feel so
    sweet? Is it likely to damage anything? Or is it the "racing gear
    change" I was told about and I should have been doing it all along and
    not doing it contributed to the knackered original gear box? GRRRRRR!
    Dave OSOS#24 Remove my gerbil for email replies
    Yamaha XJ900S & Wessex sidecar, the sexy one
    Yamaha XJ900F & Watsonian Monaco, the comfortable one
    http://dswindell.members.beeb.net
  2. Dave Swindell
    TomTheKraut Guest
    If a mechanical thing like disengaging one set of cogs and at the same
    time engaging a different set of cogs (a.k.a. shifting gears) *feels*
    slick, then it is not putting any undue stress to the mechanical parts
    concerned. Fortunately, these old-style mechanical components give
    quite a good feedback if they "like" something or not.
    Besides, your clutch mechanism receives less wear.
    Tom :{)
    BOTAFOT#105 COFF#02/ OSOS#15 KwaSoH#2
    SR500(.de), SRX-4(.jp)
    Make it idiot-proof and someone invents a better idiot...
    Hiroshima pics: http://makeashorterlink.com/?C12E12B97
    TomTheKraut, Aug 14, 2004
  3. Dave Swindell
    Sean Guest
    Clutchless upshifting, when you get used to it, places less stress on
    the gearbox, is smoother and it allows for a seamless progression of power.
    The bike is 'disturbed' less as you are not off and on the power as you
    would be with the clutch. It is also very useful when you have a
    passenger as you get less head clonking, due to the smooth upshift.
    Unless you were really hamfisted with the clutch, I can't see clutched
    shifts contributing to wearing the gearbox out to a significant degree.
    Like you said, it is like using a pre-selector gearbox :)
    Personally, I rarely use the clutch for upshifts other than 1st to 2nd,
    and usually use it for downshifts. In 21 years of riding bikes on the
    road, the only worn out gearbox components I've ever had was on my
    XJ650, and that was the selector drum grooves, not the shift forks or
    engagement dogs. Oh yeah, I have only ever replaced one clutch. I think
    the two are connected.
    Hope that little ramble helps.
    Sean, Aug 14, 2004
  4. In message <cfkhju$j3r$1$>, Sean
    Interesting. That is my experience too since the short time I have been
    trying it. There seems to be circumstances where the higher gear simply
    doesn't engage when in first or second. I haven't worked out what the
    circumstances are yet, though my working hypothesis is that it is when I
    am giving it a tad too much power.
    I'm surprised I can do a clutchless down-change, and it feels as smooth
    as the up-change. Just shows my ignorance of the mechanics involved
    (yes, I know, but the day we stop learning is the day we are dead ;-)
    Certainly did. Many thanks.
    Dave Swindell, Aug 14, 2004
  5. Dave Swindell
    Ferger Guest
    Sean secured a place in history by writing:
    What he said. I've never really wanted to downshift without the clutch,
    'cos you can't blip the throttle to use the engine braking smoothly.
    Ferger, Aug 14, 2004
