R6 Gear Selection problems
Discussion in 'UK Motorcycles' started by Rocket, Jun 7, 2004.
  1. Rocket
    Rocket Guest
    My girlfriend bought a V reg R6 private (1) and 1500 miles later it will
    only select 1st or 2nd gears. Would I be right in thinking she has bent the
    common selector fork as they are soft as shite and built to win the race and
    do a cooling down lap? What else could it be?
    (1) Poor girl been after one for ages and after finally making her dream
    happen it knackers after 3 weeks. She is distraught.
    Rocket, Jun 7, 2004
  2. Rocket
    Rocket says...
    Check the gearchange ratchet/pawl detent spring behind the squareish
    case where the splined gear lever shaft is. Breakage is a common fault
    on early R1s, and I'm led to believe the R6 can suffer the same. The
    parts cost about a fiver and it's easy to repair, but make sure you get
    all the old bits of broken spring out.
    Lozzo, Jun 7, 2004
  3. Rocket
    Dr Zoidberg Guest
    Was that what went on Bear's R1?
    Alex
    "I laugh in the face of danger"
    "Then I hide until it goes away"
    www.drzoidberg.co.uk
    www.upce.org.uk
    Dr Zoidberg, Jun 7, 2004
  4. Rocket
    Dr Zoidberg says...
    Yep. Heard of R6s doing the same, but not seen one myself. It took me
    half an hour to sort on the R1 and cost a fiver for the spring and
    gasket. The symptoms the OP is describing are the same as Bear had with
    his, so it's worth looking at before anything else. If anything, looking
    at this is relatively cheap compared to pulling a gearbox apart.
    Lozzo, Jun 7, 2004
