R6 2003 Number Plate Hanger
Discussion in 'UK Motorcycles' started by Matt E Mulsion, Nov 16, 2003.
  1. I have been looking round at the NEC bike show today for a number
    plate hanger for a 2003 R6. The only one I could find was on the
    Harris Performance stand, but I have seen two websites previously
    (Dynomite and Ermax) that also do a number plate hanger/undertray in
    Ermax's case. Has anyone on here got any of these fitted to a 2003
    R6, what are they like in the flesh, or have you got one from
    elsewhere?
    Is it also a legal requirement to have a number plate light fitted?
    Finally before it is suggested I do not want to take a hacksaw to the
    yamaha original in case it ever needs to be fitted back on the bike.
    Cheers.
  2. Matt E Mulsion
    Ginge Guest
    Why not just leave it standard, it doesn't do anything to improve
    performance, looks or handling IMHO.
    Ginge, Nov 16, 2003
  3. Matt E Mulsion
    No.
    At least not on my 1979 machine. I made enquiries, with the police, when
    the rear light unit I was fitting turned out to be a sidecar unit without
    a number plate lens.
    sweller, Nov 16, 2003
  4. Matt E Mulsion
    Dr Zoidberg Guest
    Yes , unless you are riding a moped which you clearly aren't.
    Alex
    SRX 400
    "I laugh in the face of danger"
    "Then I hide until it goes away"
    www.drzoidberg.co.uk
    Dr Zoidberg, Nov 16, 2003
  5. Or No, if you only have a brake light and don't ride at night.
    Old Fart at Play, Nov 16, 2003
  6. Matt E Mulsion
    Not necessarily, and I'm not so sure it doesn't apply to mopeds [1], but
    given the OP stated he had a 2003 R6 then yes.
    I had a minor panic and checked to see if the C&U had changed and my '79
    bike was more illegal than normal...
    From this gov factsheet
    http://www.vca.gov.uk/downloads/files/vca039.pdf
    (c) Lighting Equipment and Reflectors:
    (i) Direction Indicators - on motorcycles first used on or after 1 April
    1986 must be approved to EC Directive 76/759, 93/92, Chapter 2 of 97/24
    or to ECE Regulation 6 or 50;
    (ii) Stop Lamps and Front and Rear Position Lamps - on motorcycles first
    used on or after 1 April 1986 must be approved to EC Directive 76/758,
    93/92, Chapter 2 of 97/24 or ECE Regulation 7 or 50;
    (iii) Rear Reflectors - on motorcycles first used before 1 April 1991
    must comply with the requirements of British Standard AU 40. If first
    used after 1 April 1991 they must be approved to EC Directive 76/757,
    93/92, Chapter 2 of 97/24 or to ECE Regulation 3;
    (iv) Rear Registration Plate Lamp - on motorcycles first used on or after
    1 April 1986 must be approved to EC Directive 76/760, 93/92 and Chapter 2
    of 97/24 or to ECE Regulation 4 or 50;
    (v) Headlamps - the regulations set minimum wattage requirements for
    dipped and main beam headlamps according to the cubic capacity of
    motorcycles. Headlamps on motorcycles are not required to have any
    approval markings, and
    (vi) As a general condition the regulations require
    riders to keep obligatory lamps and
    reflectors clean and in good working order.
    ....my Guzzi is still exempt
    [1] Definitions Motorcycle - a vehicle having less than four wheels and
    weighing less than 410kg unladen. This definition includes three wheeled
    motorcycles and three-wheel mopeds:
  7. Thanks for the replies folks, what about the number plate hanger
    though, has anyone on here got one on their 2003 R6?
    Matt E Mulsion, Nov 17, 2003
