R1 electrical fault
Discussion in 'UK Motorcycles' started by sinik, Feb 24, 2004.
  1. sinik
    sinik Guest
    Can't find my manual, rev counter indicates 7,000 drops to zero does this
    every 10 secs, could someone look up their manual and tell me what fault
    this is indicating, heap o junks not charging so I guess the it'll be
    something to do with that. cheers.
    sinik, Feb 24, 2004
  2. Have you taken the tank off for any reason? If so there's a connector
    underneath for the fuel level. IIRC not reconnecting this gives the
    symptoms you describe.
    Boots Blakeley, Feb 24, 2004
  3. sinik
    sinik Guest
    Never had the tank off until today, I know the connection you mean, all in
    order, alternator connection also ok, started to snow so never got a chance
    check alternator output.
    sinik, Feb 24, 2004
  4. sinik
    HedgeHog Guest
    This means your EXUP valve is sticking, but hasn't fucked the servo yet....
    Get the EXUP valve stripped and greased pronto
    HedgeHog AKA Paul Hendrick
    YZF750R Bultaco Sherpa
    BONY#3 BOTAFOT#101
    Remove KHH to reply by email
    HedgeHog, Feb 24, 2004
  5. sinik
    Ben Blaney Guest
    Are you now a pacifist?
    Does this mean that the fatwa against darsy has now been cancelled?
    Ben Blaney, Feb 24, 2004
  6. sinik
    Cane Guest
    Why did he have a fatwa against sweet little, wouldn't say boo to a goose,
    keeps himself to himself, easy going and open minded darsy?
    Cane, Feb 24, 2004
  7. sinik
    Ben Blaney Guest
    I'm confused too.
  8. sinik
    sinik Guest
    shite Scottish weather to blame no doubt, 3 weeks out of warranty too.
    sinik, Feb 24, 2004
