R1 Brakes & winter.
Discussion in 'UK Motorcycles' started by PDannyD, Feb 12, 2004.
  1. PDannyD
    PDannyD Guest
    I say R1 brakes because that's what I've been told are fitted to my
    Fazer.
    This last week or two I found the bike to be struggling occasionally a
    few minutes after setting off, like carb icing, but it was totally
    smooth as though the engine suddenly decided to ignore the throttle.
    Got back last night. Loss of power seemed to come in soon after braking
    for a corner. Things soon returned to normal but still seemed to be
    slightly down on power.
    Once safely home, put finger on brake disks even though I'd hardly
    braked in the last 3 miles. Smell of bacon, hissing sound, slight pain
    in end of fingers.
    That'll be binding brakes then. Bugger.
    Book of words says remove brake pads, pump pistons out slightly to check
    surfaces. If ok then just smear a little brake fluid on them, clean up
    the excess and re-assemble (which is *of course* the reverse of
    disassembly)
    The little Suzuki GS125 which has sat outside and been ridden hard (one
    blown engine later) for the last 3 years has had virtually **** all
    maintenance other than chain and engine oil n tyres yet still has piss
    poor brakes but at least they dont seize.
    FZS600 - silver/black
    GS125 - black/rust
    '81 Bobtail - vaguely green (FOR SALE £800)
    CAAD7 - black
    LTS2 - blue, not black
    OE6 + Quotefix
  2. PDannyD
    Klaatu Guest
    snipabit
    Surely that should read "copper grease" not "brake fluid" ?
    Klaatu, Feb 13, 2004
  3. On Thu, 12 Feb 2004 23:00:33 -0000, "PDannyD" wrote:
    [off fazer brakes]
    They do suffer from binding, I given up on the rear it doesn't seem
    possible to keep it functioning fully for more than a few days.
    Fortunately it sticks in rather than out, the fronts are OK if cleaned
    and greased with coppa-slip a couple of times a year.
    Boots Blakeley, Feb 13, 2004
  4. PDannyD
    Jim Ingram Guest
    No. Copper grease is not specified as being compatible with brake
    seals (although I don't know if its been demonstrated to be
    incompatible). I wouldn't worry about getting it on the dust seals
    (they are crap on m/c calipers and you need something to keep the
    water out) but I wouldn't want it on the hydraulic seal. Castrol make
    a 'Red brake grease' for brake seals but its almost impossible to
    find in the normal motor factors etc.
    Jim
    Jim Ingram, Feb 13, 2004
  5. PDannyD
    Bollocks. I'm sorry, but that is utter bollocks. If you want a tin
    of it, my local little motor factor will do you 0.5 or 1.0 kg tins off
    the shelf - or little sachets from under the counter.
    Or look here:
    http://www.mgocaccessories.co.uk/acatalog/MGOC_Accessories__Grease_176.html
    almost at the bottom of the page.
    Pip, Feb 13, 2004
  6. Jim Ingram wrote
    It is night on impossible to find a normal motor factors these days.
    Having Snowflake in the family has been a revelation. I mean, apart
    from having to live with the frustration of being comprehensively out
    accelerated by *every* **** on the road, I have also found out that all
    the motors factors in SE Essex have closed down. The one down Pound
    Lane in North Benfleet is still there though.
    steve auvache, Feb 13, 2004
  7. PDannyD
    Ben Blaney Guest
    The one opposite Mark Nicolson's place?
    Ben Blaney, Feb 13, 2004
  8. Ben Blaney wrote
    Who?
    steve auvache, Feb 14, 2004
  9. PDannyD
    Ben Blaney Guest
    Italian car genius.
    Ben Blaney, Feb 14, 2004
  10. Ben Blaney wrote
    Hmmm as extensive and comprehensive an explanation as ever I have heard.
    Thanks for that.
