quietest helmet?
Discussion in 'UK Motorcycles' started by David, Jun 1, 2004.
  1. David
    David Guest
    Any recommendations out there as to what you consider to be the quietest helmet?
    I have heard good things about the Baehr Sonic and the FM W10.
    I'm looking to reduce the dB levels I'm receiving on the highway with my Shoei R-FR.
    Thanks.
    David
    David, Jun 1, 2004
  2. David
    Ben Blaney Guest
    Earplugs.
    Ben Blaney, Jun 2, 2004
  3. David
    petrolcan Guest
    the **** known as David says...
    Look at google groups, it was covered here within the last week.
    petrolcan, Jun 2, 2004
  4. David
    Dan White Guest
    Shoei R-FR.
    Earplugs? Fitted, custom moulded ones?
    Uvex seem to be very highly rated round here.
    Dan White, Jun 2, 2004
  5. David
    David Guest
    "Earplugs" were covered, not "helmets".
    Thanks for nothing.
    David
    David, Jun 2, 2004
  6. David
    M J Carley Guest
    I got quite a good reduction in noise by fitting a Foggy breath
    deflector thingy, mainly, I assume, because it let me ride with the
    visor closed.
    M J Carley, Jun 2, 2004
  7. David
    Logorrhea Guest
    Shoei R-FR.
    The quietest helmet is the helmet which fits you best. It's a tedious
    matter of trial and error ... and luck ... and judgement ... and your bike's
    aerodynamics ... and money ...
    and, as Ben Blaney said, earplugs. I have a Schuberth, and it works very
    well for for me. Other people swear at 'em, instead of by 'em.
    Logorrhea, Jun 2, 2004
  8. David
    Preston Kemp Guest
    I think this is a pretty pointless question as there are too many
    variables involved. How good a fit the helmet is, how much care you take
    over seating the visor, how tall you are & what bike your ride (I.e.
    head/screen relationship and the angle of your head), what clothing you
    wear (does it channel the air flow towards or away from the base of the
    helmet), how big your ears are, whether your ears are
    high/low/forward/backward relative to your head etc.
    E.g. my Lazer Revolution, which is generally considered a noisy helmet,
    is quieter than my Shoei when riding the Tiger, but louder when riding
    the MV. This is probably due to the vastly different angles of my head
    between the two bikes.
    So I would guess the best recommendation anyone could give is that
    helmet A is quieter than helmet B _for them_ on a _specific bike_. That
    doesn't mean it will be quieter for you on your bike, unless you're the
    same height, with the same preference for fit, and the same shaped head,
    on the same bike.
    Of course if you find the right earplugs for your shaped ears, and wear
    them every time, the helmet noise is irrelevant. If you don't wear
    earplugs, you will eventually suffer hearing loss, unless you ride a
    bike that lets you sit in a bubble of still air behind a screen.
    All imho natch.
    Preston Kemp, Jun 2, 2004
  9. David
    petrolcan Guest
    Does stupidity come naturally to you?
  10. David
    You appear to have mis-spelled "CONT".
    HTH.
    Pip, Jun 2, 2004
  11. David
    serf Guest
    Bollocks, they were. Last week's thread was "Mini Review Aprilia RSV"
    (though why someone on this NG would be interested in a version of the
    Bible is beyond me), and the OP was Milly R. Dunno what bike she rides,
    though.
    serf, Jun 2, 2004
  12. David
    "post of the year".
    darsy, Jun 2, 2004
  13. David
    David Guest
    All good points.
    I have a Suzuki Burgman 650.
    I had a GIVI windscreen, but it got vandalized somehow, and I am
    replacing it with an Ermax. If I were a few inches shorter, I'd be in
    the "bubble", but I actually look over the top of the windscreen. The
    Ermax is taller than the GIVI was.
    I'm leaning towards a Shark RSF helmet at the moment, as they scored
    at the top of the sound insulation rankings.
    Now that I'm enlightened about the need for earplugs, I have a pair on
    order.
    Thanks for the [constructive] comments.
    David
    David, Jun 3, 2004
  14. David
    Dan White Guest
    *A* pair? You may want to get more than a single pair.
    For everyday use I actually find the "Muffles" wax plugs from Boots are very
    good. I can't seem to get foam plugs to stay in my ears for very long.
    Now I've started doing a job where more travelling is required, I'm tempted
    to go for a proper set of custom moulded ones.
    Dan White, Jun 3, 2004
  15. David
    Preston Kemp Guest
    Unfortunately you're about to discover that finding the right earplugs
    for your shaped ear is even harder than finding the right helmet. You
    may have to try several types before finding one that fits properly. You
    can buy selection packs that contain various types, which is probably
    the best way to go. If you're lucky, the type sold by farm/industrial
    suppliers will fit, & you can save a (small) fortune by not buying them
    from a bike shop.
    As you haven't used them before, I'd recommend getting your GP to have a
    quick check in your ears. If you've got a build-up of loose wax, you'll
    go completely deaf when you start using the earplugs as they push all
    the wax in against your ear drum. DAMHIKIJFD.
    Preston Kemp, Jun 3, 2004
