Quiet helmets
Discussion in 'UK Motorcycles' started by Matt Horn, May 5, 2005.
  1. Matt Horn
    Matt Horn Guest
    Time to get me a new helmet me thinks. I sway neither towards arai or shoei
    size head, both seem to fit me fine and are comfortable, so that out of the
    way, what's the quietest helemt vs price?
    I'm not a fashion following power ranger and I don't care what colour or
    season it came from (in fact I've always bought last seasons pattern cus
    they are normally that much cheaper) hence it needs to be cheap enough but
    quiet enough as I'll be doing 100 miles each day. I'll be using earplugs as
    well though.
  2. well my Uvex WingRS is pretty quiet, especially with earplugs in, and it
    was only £45 at the BMF, thanks to a tiny chip in the paintwork.
    I think that's pretty quiet for the price.
    Lozzo of course gets his cheaper.
    Black YKIMS.
    Dnc
    B1200 - +30bhp ~|~ VS800 - borked
    TS150 - squatting ~|~ V2300 - flat cap and rug
    Doesnotcompute, May 5, 2005
  3. Doesnotcompute wrote
    My Caberg is quiet with earplugs. £99 retail I think. I got mine in
    the sales.
    steve auvache, May 5, 2005
  4. Matt Horn
    With respect, if you use the right type of earplugs for your ears & fit
    them properly, the difference in wind noise between helmets will be
    irrelevant.
    Krusty, May 5, 2005
  5. Matt Horn
    Dan White Guest
    With respect, that is utter bollocks.
    Dan White, May 5, 2005
  6. Matt Horn
    gomez Guest
    Another factor is the seal between the bottom of the helmet and the
    neck. If I use a neck roll then this also makes a big difference.
    gomez, May 5, 2005
  7. Matt Horn
    No, it's not. With your ears properly plugged, even the noisiest of
    helmets on the windiest of bikes just results in a faint background
    whoosh that's nowhere near loud enough to damage your ears.
    Krusty, May 5, 2005
  8. Matt Horn
    muddycat Guest
    IMO Of the two, the Shoei is the quieter.
    Black, man, black.
    muddycat, May 5, 2005
  9. Matt Horn
    muddycat Guest
    No, it is bollocks.
    With the same earplugs properly fitted (laserlite), my Arai is far
    noisier than my new Shoei. With my head in certain positions, the Arai
    will shriek like a banshee.
  10. Matt Horn
    I'd say you need to carry on searching for the perfect earplug for you
    then. I've tried numerous types, all of which worked to a certain
    extent, some of which I though were very good, & then I discovered the
    EarSofts which were a revelation. You could stand 3' away & talk to me
    & I literally wouldn't be able to hear a word you said.
    If I can achieve near silence with a particularly noisy lid (a flip) on
    a bike that directs the airflow straight at my head with the screen on
    the lowest setting, I'm sure anyone else can.
    I'm not saying you won't be able to tell the difference between a noisy
    lid & a quiet one, just that even the noisiest will still be so quiet
    it won't be an issue.
    Krusty, May 5, 2005
  11. Matt Horn
    Dan White says...
    With no respect, it's not bollocks.
    Lozzo, May 5, 2005
  12. Matt Horn
    Pip, May 5, 2005
  13. Matt Horn
    Matt Horn scribbled on the back of a napkin:
    If you've got an Arai-shaped bonce, try a Schuberth S1 - they're
    considerably quieter than both Shoei and Arai IME.
    Timo Geusch, May 5, 2005
  14. Matt Horn
    muddycat Guest
  15. Matt Horn
    Tosspot Guest
    Tis true, but getting one of the little buggers to stay put all day
    without drugs can be a prolem.
    Tosspot, May 5, 2005
  16. Matt Horn
    Tosspot Guest
    Then dont put your head in that position! Errr...what position?
  17. Matt Horn
    muddycat Guest
    I've tried several different type, including the custom fitted kind. The
    laserlites provide the best noise reduction for me. Having said that, I
    have not tried the earsofts but will have a go if I find them here.
    Can you hear traffic though? I mean, it would be nice if you could hear
    horns and sirens.
    8< 8<
  18. Matt Horn
    Dan White Guest
    Hmm, and there I was about to get one of your "This is the quietest lid I've
    ever used" products. And with you telling me that my Schuberth was a really
    noisy lid.
    Should I not bother then?
  19. Matt Horn
    muddycat Guest
    When I look over my left shoulder before changing lanes.
  20. Matt Horn
    No guarantees they'll work for you obviously, or anyone else. For
    example my dad swears by the plastic mushroom type, but they're the
    absolute worst for me ears.
    I can't hear normal traffic noise, or bikes in front unless they've got
    race cans. I don't know about horns & sirens - it's not the sort of
    thing that would stick in my memory. But I'm sure I'd hear them if
    close enough.
    Krusty, May 5, 2005
