Queston About Syncing Carbs
Discussion in 'Motorbike Technical Discussion' started by Steven Schnell, Feb 22, 2004.
  1. I have an '02 Honda 750 ACE Deluxe on which I've recently rejetted the carbs. Now, as part
    of the maintenance schedule I need to check/adjust the carb sychronization. Question: Even
    with different-sized jets installed in the two carbs do I still need to have the vacuum
    pressure identical in both carbs?
    This will be my fist attempt at synching the carbs and I'm looking to purchase the Carbtune
    II kit. Is this a good kit?
    Thanks in advance,
    Steve
  2. Steven Schnell
    James Clark Guest
    Shorter intake runners. Less volume between the carb and the valves.
    James Clark, Feb 23, 2004
