Question to those who know a bit about mechanics/auto electrics
Discussion in 'UK Motorcycles' started by Dundonald, Feb 4, 2007.
  1. Dundonald
    Dundonald Guest
    My CBR600F (1998) as reliable as it normally is stopped starting just
    before Christmas. Only just got time today (and only an hour at that)
    to take a look. Symptoms are that bike doesn't start (!) and
    sometimes after hitting the ignition switch there is a clicking sound
    other times not. So far I have charged battery, two batteries in
    fact, tried them both and have the same symptoms. I then checked the
    relay (took it off, gave it a good clean because there were some blue
    powder deposits on the relay unit connections and I also tested it in
    isolation using a couple wires to a spare battery and the relay
    clicked like a good en). Next I'm assuming I need to tackle the
    starter motor.
    But I was wondering before I go ahead checking the starter motor if
    1. anyone in here knows of a common fault on the CBR600F (like the
    reg / rect that I had to replace last year - that going is very common
    on this bike) that I can also check and
    2. does anyone know why when everything is connected as normal after
    hitting the ignition switch sometimes I can hear the relay clicking
    and other times when I hit the ignition there is no sound?
    Ta
  2. Dundonald
    Check the earth bonding. On a nine year old bike I bet one of the earth
    straps is corroded.
    Simplest way to check is to take a jump start lead directly from the
    battery negative to the casing of the starter motor. Press the starter
    button and I bet the motor fires up.
    wessie, Feb 4, 2007
  3. Dundonald
    deadmail Guest
    Good advice... but my money would be on the motor spinning rather than
    firing for a while...
    deadmail, Feb 4, 2007
  4. Dundonald
    wrote in 4ax.com:
    better now, Mr Picky?
    wessie, Feb 4, 2007
  5. Dundonald
    deadmail Guest
    Absolutely spiffing, thank you.
  6. Dundonald
    Dundonald Guest
    Thanks fellas I'll check. Nice little earth test trick, nice one.
    I'll let you's know.
  7. What Wessie says, plus the chance of the relay contacts being burned so
    there's no proper connection to the starter. Short out the contacts with
    a screwdriver and see if the starter spins.
    If nothing happens, and you're sure the connections are all good, both
    pos and earth, at the relay and the starter, then you're looking at a
    buggered/jammed starter.
    Grimly Curmudgeon, Feb 5, 2007
  8. Dundonald
    Pete Fisher Guest
    The OP says that they have tried two batteries. On ca only presume at
    least one of them was a known good fully charged example.
    I have done this many times without damaging anything but perhaps I am
    just lucky. Before I sussed a problem with the Nordwest needing a softer
    plug and careful setting of the air gap between the alternator rotor and
    the CDI ignition sensor it was often the only way to persuade it in to
    life. The extra amps of a car battery would spin the HC big bore motor
    over quicker.
    Care must be taken with polarity naturally. I know of at least one hill
    climb bike (Ducati) which is started from an external car battery via a
    quick connector of the type used on forklift trucks (this technique is
    also used a lot on the big single seater cars).
    | Pete Fisher at Home: |
    Pete Fisher, Feb 5, 2007
  9. Colin Wilson wrote
    Yes and no.
    steve auvache, Feb 5, 2007
  10. Dundonald
    I concur.
    Don't have the car engine running like you would with a car to car jump
    start. The superior output from the car alternator might overwhelm the
    regulator in the bike, especially on a Honda...
    Either have the car battery as a free standing slave or ensure the engine
    is off. I've done this quite a few times, especially on my CBR600 in
    winter.
    wessie, Feb 5, 2007
  11. Dundonald
    Dundonald Guest
    Sorry fella what do you mean by shorting out the contacts? The relay
    has a positive connection in from the battery, for the sake of
    argument on the right, then another cable out, again for the sake of
    argument on the left and I think this is out to the starter motor.
    But then at the top is the 4 pronged clip with the fuse inside - it
    was two of those prongs that I bridged with a pos and a neg from a
    battery to force it to click. Which contacts are you referring to
    please?
    Talking to a lad today and he reckond I could bridge the gab between
    the left and right connections with a screwdriver as a test to see if
    the engine starts.
    Dundonald, Feb 5, 2007
  12. That's it exactly. Short out the two main terminals.
    Grimly Curmudgeon, Feb 6, 2007
  13. Dundonald
    Dundonald Guest
    Here's an update. Freshly charged battery. Disconnected the two main
    terminals from the relay solenoid (+ from battery and cable to starter
    motor) and touched them together. Sometimes when I connected the
    terminals together nothing would happen (apart from a spark or two!)
    but other times I could hear the starter motor *labouring* to turn
    over then it would stop. Just to make sure there was no way there
    could be a lack of power from the battery I connected my battery
    charger to the battery on the bike. The same *labouring* sound in the
    starter motor.
    So, next task for me is to learn what possible things could be wrong
    with the starter motor in the haynes manual. But a question - if I
    could sometimes hear the starter motor at least attempting to turn but
    then stopping, could it be a bit of dirt or other crap that's possibly
    stopping it?
    Dundonald, Feb 7, 2007
  14. Dundonald
    Pete Fisher Guest
    Connecting just a charger while trying to crank it over won't help. Are
    you sure the freshly charged battery is actually any good?
    Pete Fisher, Feb 7, 2007
  15. Dundonald
    Dundonald Guest
    I'm almost certain as I have tried other tests with two batteries and
    the one in particular that I used tonight is only 6 months old. But
    to make sure I could do another test tomorrow where I could put the
    jump leads from our car battery on to my bike (just in case both
    batteries might be damaged).
  16. Dundonald
    Dundonald Guest
    Wessie, thanks. Your earth bonding test was on my list to check after
    doing a couple more tests on the relay solenoid. On the final test I
    connected the + battery terminal straight to the starter motor
    terminal and I could hear the starter motor attempting to start,
    albeit in a *labouring* way, i.e. I could hear it turn slightly then
    stop. A some other times I would put the terminals together and
    nothing would happen. Just to make sure that both the batteries I'm
    using in the test aren't nackered I'm gonna run jump cables from my
    car battery to my bike, see if that makes a difference.
  17. Dundonald
    Have you ruled out the dodgy earth yet? The above process of connecting +
    volts to the starter motor is still relying on a return path to the battery
    via the bike's earth cabling.
    wessie, Feb 7, 2007
  18. Dundonald
    Dundonald Guest
    Aye Wessie mentioned that I can test the earth by running a jump cable
    straight from the outside of the starter motor to the negative
    terminal of the battery. Definately next on my list. Thanks Champ.
  19. Dundonald
    Dundonald Guest
    Aye fella just replied to your (original) post letting you know that's
    next on my list tomorrow. Only had an hour spare when I got back at
    gone 9pm tonight and it was too frickin cold in the garage to carry
    on. Next test tomorrow. Need to pull more fairing off. Joy.
  20. Dundonald
    Ah, you got in before me.
    You'd think he would've got the message after I suggested it days ago and
    others of an electrical bent agreed.
    After checking battery condition & terminals it is always the next check on
    my list as it is so fucking easy to do! And usually the problem, unless
    it's a BMW[1]
    [1] I diagnosed a fellow traveller's faulty starter motor on an R1100R on
    the shores of Lake Garda by swapping the unit from my bike to his.
    wessie, Feb 7, 2007
