Question on spark plugs
Discussion in 'Motorbike Technical Discussion' started by Paul Harris, Jul 15, 2004.
  1. Paul Harris
    Paul Harris Guest
    I have a 2003 Kawasaki Voyager. The manual does not specify any
    interval for actually replacing the plugs, it only says to inspect,
    clean & adjust gap, or replace as necessary, every 5,000 km.
    I'm pretty sure that I know when a plug needs replacing from the look
    of it. However, something that has always concerned me is the plug
    comes with a compression washer, and after it's been installed and
    removed once, the washer is permanently compressed. I always worry
    about re-tightening it again, and how much force to use. I'm scared of
    stripping the threads.
    Any guidelines on this would be appreciated.
    Paul Harris
  2. Paul Harris
    Quincy Guest
    You *should* replace the washer and torque it to the manufacturers specified
    setting - the torque setting will be in the workshop manual.
    Q.
    Quincy, Jul 16, 2004
  3. My experience is with cars, and recent models basically don't
    touch the plugs for ages (I think my previous car, a Plymouth Laser RS
    Turbo may have had one plug change in the 12 years I owned it -- 43K
    miles).
    A decent four-cycle engine probably doesn't need much checking
    of plugs... OTOH, unless you've got a 6-cylinder engine, plugs aren't a
    major cost factor on a motorcycle -- are they?
    Dennis Lee Bieber, Jul 16, 2004
  4. Paul Harris
    Charlie Gary Guest
    The torque spec in your book should be all you need. If done right each
    time, there won't be any undue stresses on the threads to worry about. The
    biggest enemy here is probably dirt between a crushed washer and the seat.
    Some folks say replace the washers, but they never seem to mention where to
    buy new ones without spark plugs already attached. Maybe I'll actually ask
    for them next time I step into an auto parts store. I might be surprised.
    Charlie Gary, Jul 16, 2004
  5. Paul Harris
    Matt Whiting Guest
    I replaced the plugs on my 87 Voyager at 30,000 miles just because I
    felt I should. They still looked fine and the bike didn't run any
    better with the new plugs. I sold it at 46,000, but had I kept it
    probably would have run the current set to at least 40,000. Pulling
    them every 5,000 KM is also way overkill. I didn't touch mine until
    15,000 miles and they still weren't all that bad. Closed the gap and
    little and put them back in.
    Matt
    Matt Whiting, Jul 16, 2004
  6. Paul Harris
    Paul Harris Guest
    Thanks Matt, and others, for your comments.
    PH
    Paul Harris, Jul 16, 2004
  7. Paul Harris
    Ceraboy Guest
    I have reused the compressed spark plug washer on my sleu of
    motorcycles over the years without trouble. Use compressed air to
    blow out the spark plug area before you remove the plug to get rid of
    any debris and then blast the spark with compressed air around the
    washer to remove any debris again. If you are worried about stripping
    the threads be sure to use a small ratchet with a short lever arm (or
    a small 3/8" torque wrench if youre really worried). I use a small
    T-bar plug socket specifically meant for spark plugs and you have to
    Hulk Hogan to do any damage with these.
    Ceraboy, Jul 17, 2004
  8. Paul Harris
    opietaylor69 Guest
    Group: rec.motorcycles.tech Date: Thu, Jul 15, 2004, 3:43pm (EDT-3)
    The use of unleaded fuel has made even standard spark plugs last a very
    long time. 15,000km would be a more realistic milage to check the plugs.
    (Or you could replace them with iridium plugs, which will outlast the
    motor).
    opietaylor69, Jul 19, 2004
  9. They lasted a long time on leaded......
    The Older Gentleman, Jul 19, 2004
  10. Paul Harris
    opietaylor69 Guest
    Re: Question on spark plugs
    Group: rec.motorcycles.tech Date: Mon, Jul 19, 2004, 10:05pm (EDT+5)
    long time.
    True. Providing you occasionally sandblasted off the deposits caused by
    leaded fuel.
    opietaylor69, Jul 20, 2004
  11. What the *hell* are you on about? I don't know anyone who ever
    sandblasted spark plugs. I doubt anyone has done it since the 1930s.....
    Everyone cleans plugs from time to time, but that was to remove
    carbon/oil or whatever......
    Hell, I remember my Dad's old cars and I can't *ever*recall a spark plug
    failure, nor him ever sandblasting them!
    Mind you, if you're using webTV then your grasp of matters technical has
    to be a bit shaky..........;-)
    The Older Gentleman, Jul 20, 2004
  12. I used to have a cigarette-light-socket powered plug cleaner in
    the early '80s... And used it too.
    Of course, that 225 slant-six had a bad valve seal on #5, so
    every three or four months I'd have clean that plug (or have my right
    knee bashed by the shift lever from the miss during acceleration --
    shift lever was physically mounted to the left side of the transmission,
    not to the body centerline).
    Dennis Lee Bieber, Jul 20, 2004
  13. Fair enough - but that would be oil fouling due to the dodgy seal. Not
    lead fouling, which exists only in the fevered brain of opietaylor.
  14. I was only commenting on the use of sandblaster-type plug
    cleaner in the 80s, not the cause of fouling (the Ghost of Chrysler was
    already unleaded [bicentennial edition "Spirit of 76" Dodge Dart, A833
    Overdrive-4, Hurst shifter positioned almost directly beneath the right
    edge of the steering wheel -- a straight down drop got you the knob])
    Dennis Lee Bieber, Jul 21, 2004
  15. Oh yes, fair enough.
    And a nice sounding car - I think......
    The Older Gentleman, Jul 21, 2004
  16. Paul Harris
    opietaylor69 Guest
    Group: rec.motorcycles.tech Date: Tue, Jul 20, 2004, 7:20pm (EDT+5)
    Your cliche'd insults aside, if you are unaware that plugs stay much
    cleaner due to unleaded fuel, then you might want to reappraise your
    ability to post anything useful in a tech forum. If you've never heard
    of bead blasting or sand blasting sparkplugs, you never worked in a
    repair shop in the days of leaded gasoline. And lastly, if you don't
    understand that lead deposits, on their own, could foul plugs, your
    grasp of matters technical is non-existent. As for plugs "lasting", a
    fouled plug can be brought back to servicability, and to a clueless
    moron, that might mean that it "lasted".
    opietaylor69, Jul 21, 2004
  17. Paul Harris
    opietaylor69 Guest
    "Whatever" huh? Now there's a technical term worth grasping. In
    fact, with modern unleaded fuel, and modern (read platinum or iridium)
    sparkplugs, the need to clean plugs is virtually eliminated, providing
    the engine in question is operating properly. If your contention is,
    that sparkplugs in "the good old days" lasted as long (particularly
    with leaded fuel) as modern plugs using unleaded fuel, then you are so
    inept on this subject, so delusional, so misinformed, and so
    completely and totally wrong, that further discussion is pointless.
    Get your head out of the sixties, and do a little research. (Maybe even
    try some of these "new fangled" plugs. ps...if I'm shaky, you're an
    earthquake..:)
  18. Schizoid car... The Hurst shifter, bucket seats, and eagle
    stripe down the sides made it look sporty. The high-torque/low-RPM
    slant-six (only around 95HP, but 170ft-lb @ 1600RPM -- the fast idle was
    at the torque peak!), overdrive transmission (take an early 60's muscle
    car 4-speed, flip the 3-4 linkage so that "3rd" on the lever activates
    "4th", replace "2nd" with a ratio that looks "2.5" and the former "3rd"
    with an overdrive ratio), and a differential ratio in the 2.80 range
    (combined with the overdrive, the top end ratio was down to 2.11:1)
    {It was the last car that was simple enough for me to do the maintenance
    on, hence all the details}
  19. This from the man who is advising people to beware of lead fouling????
  20. Look, please try and post in a comprehensivbel and/or readable fashion.
    In other words, ditch the webTV shite (which really is, I'm sorry to
    say, the posting medium of morons) and find *anything* else.
    All I'm saying is that I'm old enough to have had 15 years' worth of
    riding and driving experience before unleaded fuel became the norm, and
    I have never, ever, ever had a plug foul due to lead deposits.
    Not saying it's impossible - just IME so rare as to not to be worth
    considering.
    There are many, many more things that are more likely to foul plugs.
    And I didn't say I'd never heard of sandblasting plugs - I just pointed
    out that nobody I've ever heard of has done it for ages. Or didn't you
    read the posting?
    You aren't related to the late great Hoyt McKagen, are you?
